RE: Hobby Lobby Skylark e-Conversion
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
More Resources on the
Skylark ARF - .46
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • All Forums >> Electric Aircraft Universe >> Glow to Electric Conversions >> RE: Hobby Lobby Skylark e-Conversion
    Page: <<   < prev  1 [2] 3   next >   >>
    Login
    RE: Hobby Lobby Skylark e-Conversion - 2/17/2004 2:20 PM
    Greg Covey
    Score: 104
    Last Login: 11/4/2009
    Status: offline
    My finished Skylark needed only the decals added. After the photos were taken, I easily applied the pre-cut, sticky-back decals to the wing, fuselage, and dash.
    Here are some scenarios for battery power on the Skylark. For reference, the stock glow powered plane is RTF at 86oz (5.4 lbs).
    Scenario 1
    16-cells of CP2400 weigh 35.5oz (2.2 lbs). This makes the plane balance at 210mm from the trailing edge instead of the recommended 170mm. It is severely noseheavy. To balance the plane, you need 3oz added to the rudder. This makes the plane Ready-To-Fly (RTF) at 107oz (6.7 lbs). The power system with the APC 14x7 e-prop delivers 105 w/lb drawing a measured 46amps (700w).
    The advantage here is longer flights at the cost of higher wingloading and hotter landings.
    Scenario 2
    16-cells of CP1700 weigh 27oz (1.7lbs). This makes the plane almost properly balanced...very slightly noseheavy. I suspect a very small weight (0.5oz) added to the rudder will balance the plane but I will fly the maiden voyage without it using CP1700 cells. This makes the plane RTF at 96oz (6.0 lbs). The power system provides 117 w/lb.
    The advantage here is lighter wingloading but shorter flights. Alternatively, 1950FAUP cells would provide slightly longer flights and likely balance the plane perfectly.
    Scenario 3
    Once again, Lithium comes to the rescue. By using a 4s3p configuration of Kokam 1500HC cells, the entire pack weighs only 16oz yet almost triples (2.6 times) the duration over the CP1700 cells at 4500mAh. The packs can be moved forward in the fuselage to balance the plane. The plane is RTF at 85oz (5.3 lbs) which is equal to the glow powered flying weight. The power system provides 132 w/lb.
    The advantage here is a light flying weight and long flights. The disadvantage is higher cost.
    Summary
    I will test fly my Skylark using 16-cells of CP1700 and report on its performance. I will likely switch to Lithium cells in the future to provide longer, lighter flights. The nice part about electric power systems is that you can upgrade portions at a time.
    Click to see fullsize image.
    Click for fullsize
    Click for fullsize
    Click for fullsize
    < Message edited by Greg Covey -- 2/17/2004 2:30:21 PM >
    _____________________________
    Visit my Web Hangar at www.gregcovey.com/rc.htm
    Hide Signatures
    (in reply to Greg Covey)
           Post #: 26
    RE: Hobby Lobby Skylark e-Conversion - 2/29/2004 12:55 AM
    Greg Covey
    Score: 104
    Status: offline
    We flew the maiden voyage of the Skylark today and it was a perfect flight!
    On take-off, the plane climbed out at a steep angle and flew like a true pattern ship without any trim changes.
    As expected, the Skylark looked great in the air and was easy to track. At only half throttle, the plane moves along nicely. The Skylark landed like a dream after we performed many aerobatic stunts. We did not attempt to knife edge it for very long due to the heavy cross winds but the sleek, trim design performed very well when we did.
    This plane had my flying team very excited and we look forward to our next voyage when the weather permits. I'll post some flying photos later this week.
    Hide Signatures
           Post #: 27
    RE: Hobby Lobby Skylark e-Conversion - 2/29/2004 7:36 PM
    Greg Covey
    Score: 104
    Status: offline
    Here is a brief 836K video header I made with the Skylark before the maiden voyage. You can hear the cross wind that I mentioned above.
    Skylark Pre-Flight
    < Message edited by Greg Covey -- 2/29/2004 7:38:36 PM >
    Hide Signatures
           Post #: 28
    RE: Hobby Lobby Skylark e-Conversion - 3/3/2004 1:55 PM
    Greg Covey
    Score: 104
    Status: offline
    Our pre-flight check on the Skylark revealed that when applying down pressure to the elevator, the control rod would bend a bit. This may produce a mushy feel on the elevator during certain maneuvers.
    I cut a popsickle stick to proper length and then cut a slot in the side to keep the metal rod from bending to the inside of the fuselage when the servo is pushing the elevator. The wooden stick was epoxied in place.
    I tested the elevator under some holding pressure from my hand and it works great!
    Click for fullsize
    Hide Signatures
           Post #: 29
    RE: Hobby Lobby Skylark e-Conversion - 3/4/2004 12:44 AM
    Greg Covey
    Score: 104
    Status: offline
    I have a real passion for pattern planes. Perhaps it is because they make my flying look better. A true pattern ship almost flies itself and the Skylark did not disapoint!
    The power of the AXI 4120 in this ship really surprised us on takeoff!
    Click for fullsize
    Click for fullsize
    Click for fullsize
    < Message edited by Greg Covey -- 3/8/2004 7:46:27 PM >
    Hide Signatures
           Post #: 30
    RE: Hobby Lobby Skylark e-Conversion - 3/4/2004 2:09 PM
    Greg Covey
    Score: 104
    Status: offline
    The Skylark took off with authority at a 45 degree angle on its maiden voyage. We then turned it into the wind for its first workout.
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Hide Signatures
           Post #: 31
    RE: Hobby Lobby Skylark e-Conversion - 3/5/2004 2:42 PM
    Greg Covey
    Score: 104
    Status: offline
    With no trimming needed on the maiden voyage, we jumped right into a knife edge!
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Hide Signatures
           Post #: 32
    RE: Hobby Lobby Skylark e-Conversion - 3/17/2004 10:52 PM
    kepople
    Score: 100
    Last Login: 12/17/2007
    Status: offline
    Nice looking bird Greg;
    How would you rate its flying characteristics to your Razor?
    I am using the AXI in another plane and am curious about the advertised power vs what it actually can do. The plane will be aroun 7# on 12 cells.
    Is this the motor you will stick with in this pattern plane or are you looking for more power?
    Kirby
    Hide Signatures
           Post #: 33
    RE: Hobby Lobby Skylark e-Conversion - 3/18/2004 5:13 PM
    Greg Covey
    Score: 104
    Status: offline
    Hi Kirby,
    You ask some good questions that I cannot fully answer until I've had more stick time on both planes. The flying season will start here in a few more months and I can't wait to fly the heck out of both planes!
    I can make a few generalizations though. In most cases, size is better. A .60-size beats a .40-size beats a .30-size and so on.
    The Skylark is a true .40-size, pattern flyer and the Razor 3D is a .30-size, cross-functional pattern/3D flyer. Both planes look great and fly great!
    The AXI 4120 had plenty of power to fly the Skylark. It will only get better when I replace them with the new Kokam 2AH (16C) cells to triple my flight duration.
    Regards.
    < Message edited by Greg Covey -- 3/18/2004 8:58:33 PM >
    Hide Signatures
    (in reply to kepople)
           Post #: 34
    RE: Hobby Lobby Skylark e-Conversion - 3/19/2004 8:11 PM
    kepople
    Score: 100
    Status: offline
    Thanks Greg;
    Can you tell me how many amps you are expecting to draw on the 4s 1500 setup?
    Do you have any 14cell packs where you could give me an actual amp reading with the 14x7?
    Kirby
    Hide Signatures
           Post #: 35
    RE: Hobby Lobby Skylark e-Conversion - 3/19/2004 10:23 PM
    Greg Covey
    Score: 104
    Status: offline
    My 16-cell CP1700 pack on the AXI 4120 power system with the APC 14x7 e-prop measured 46amps. I expect the 4s Kokam setup to be close because the voltage drop is much less and on my Monocoupe, which also has a 4120/14, the 4s5p Kokam 1500 pack was stronger in RPMs than the 14-cell 2600mAh FAUP NiMH pack that it replaced.
    Check out my Monocoupe Review for AXI 4120 current on 14-cells.
    < Message edited by Greg Covey -- 3/20/2004 10:04:28 PM >
    Hide Signatures
           Post #: 36
    RE: Hobby Lobby Skylark e-Conversion - 3/20/2004 1:19 AM
    kepople
    Score: 100
    Status: offline
    Thanks Greg;
    Hmmmmm....13x8 on 14 cells 43 amps 14x7 on 16 cells 46 amps? I thought the differnce would be much higher.
    Kirby
    Hide Signatures
           Post #: 37
    RE: Hobby Lobby Skylark e-Conversion - 3/20/2004 10:01 PM
    Greg Covey
    Score: 104
    Status: offline
    Kirby,
    Keep in mind that the cell types were different. The 14-cell pack was higher current delivery 2600mAh FAUP NiMH cells and the 16-cell pack was only CP1700 or CP2400 NiCd cells. The FAUP NiMH cells hold their voltage better under a 40+ amp load.
    Additionally, cell age plays a part. You always want to make your own measurements as a sanity check. The main goal here is a ballpark figure since you get about 10-15% unloading in the air and throttle maintenance can provide additional performance when used by a skilled pilot.
    < Message edited by Greg Covey -- 3/21/2004 5:00:24 PM >
    Hide Signatures
           Post #: 38
    RE: Hobby Lobby Skylark e-Conversion - 4/6/2004 2:51 AM
    HaLfANDhaLF1988
    Score: 100
    Last Login: 4/6/2004
    Status: offline
    does it have unlimited vertical??
    Hide Signatures
           Post #: 39
    RE: Hobby Lobby Skylark e-Conversion - 4/6/2004 3:07 AM
    cafplanekid
    Score: 100
    Last Login: 5/6/2007
    Status: offline
    This airplane is on sale for 99 right now at hobby-lobbby, FYI
    Any chance of a video any time soon?
    Jonathan
    Hide Signatures
    (in reply to HaLfANDhaLF1988)
           Post #: 40
    RE: Hobby Lobby Skylark e-Conversion - 4/6/2004 4:22 PM
    Greg Covey
    Score: 104
    Status: offline
    We haven't been able to fly for a while now. Winter is making its last "hoorah" here even though we are in April now. I'll be happy when all the snow is gone from last Sunday's storm.
    I'll keep you posted after my next flights with the Skylark. It shouldn't be long now and I have some new Kokam 2AH Lithium cells to try in it.
    Hide Signatures
    (in reply to cafplanekid)
           Post #: 41
    RE: Hobby Lobby Skylark e-Conversion - 4/19/2004 7:44 PM
    Greg Covey
    Score: 104
    Status: offline
    Here is a test flight of my Skylark in some rediculous winds that gusted to 25mph. We still had plenty of power to fly with AXI!
    I'll be buying a remote microphone soon.
    Skylark Video 4meg
    < Message edited by Greg Covey -- 4/19/2004 2:48:42 PM >
    Hide Signatures
           Post #: 42
    RE: Hobby Lobby Skylark e-Conversion - 4/20/2004 12:19 AM
    3dandpatternflyer
    Score: 100
    Last Login: 2/17/2009
    Status: offline
    great video!
    Do u have unlimited vertical with that combination?
    The wind sounded very strong..
    thanks
    Hide Signatures
           Post #: 43
    RE: Hobby Lobby Skylark e-Conversion - 4/20/2004 5:05 PM
    Greg Covey
    Score: 104
    Status: offline
    The wind was bad that day, gusting to 25mph.
    The motor can give the plane unlimited vertical but my 4s2p setup with the 14x7 prop was not optimal. Since a 15" prop is too big for the Skylark ground clearance, either a 5s Lithium or 16-18 cell NiCd configuration would give you unlimited vertical runs.
    Alternatively, you can modify the gear mains to increase ground clearance for an APC 15x8 prop.
    < Message edited by Greg Covey -- 4/21/2004 10:39:44 AM >
    Hide Signatures
    (in reply to 3dandpatternflyer)
           Post #: 44
    RE: Hobby Lobby Skylark e-Conversion - 4/27/2004 6:13 PM
    3dandpatternflyer
    Score: 100
    Status: offline
    how many cells is too much for the AXI 4120/14?
    Hide Signatures
           Post #: 45
    RE: Hobby Lobby Skylark e-Conversion - 4/27/2004 7:00 PM
    Greg Covey
    Score: 104
    Status: offline
    Think current, not cell count.
    Optimize your AXI 4120/14 setup so that you are drawing 30-40amps. If you use throttle management, you can benefit by setting up to draw 45-50amps for short bursts of additional power.
    < Message edited by Greg Covey -- 4/27/2004 2:00:59 PM >
    Hide Signatures
           Post #: 46
    RE: Hobby Lobby Skylark e-Conversion - 4/29/2004 6:04 PM
    3dandpatternflyer
    Score: 100
    Status: offline
    can u use a MEC superbox on a AXI?
    Hide Signatures
           Post #: 47
    RE: Hobby Lobby Skylark e-Conversion - 4/29/2004 6:11 PM
    Mike Parsons
    Score: 100
    Last Login: 4/3/2009
    Status: offline
    Yes. I am working on a project that is around 65-70 oz and wanted to use the 2820/10 I had on hand. It will put out around 40 or so Ounces of thrust when used DD, but I need at least 1:1 and cant swing anything smaller than a 16X10. I mounted it in a superbox geared 2:1 and am getting incredible results. I stepped that up to 2.5:1 and the prop to a 17X10 and I am sitting about 80-85 oz of thrust at 35 amps. Well within limits of the AXI. RPM's is the only thing that has not been measured yet, and I am working on that.
    -mike
    Hide Signatures
           Post #: 48
    RE: Hobby Lobby Skylark e-Conversion - 4/29/2004 6:27 PM
    3dandpatternflyer
    Score: 100
    Status: offline
    wow! i never knew that...
    What gear ratio would u suggest for my dad's ModelTech Magic? He has an AXI 2820/10 and uses a 12 x 4 with 14 cells. Flies good, but not enough to hover or unlimited vertical. AUW 4.75 lb
    Opinion??
    Hide Signatures
    (in reply to Mike Parsons)
           Post #: 49
    RE: Hobby Lobby Skylark e-Conversion - 4/29/2004 7:54 PM
    Mike Parsons
    Score: 100
    Status: offline
    I would suggest a 2.5:1 gearing swinging a 14X7E prop on 14 cells. This should yeild about 36 amps with 5.8 pounds of thrust.
    quote:
    ORIGINAL: 3dandpatternflyer
    Opinion??
    Hide Signatures
           Post #: 50
    Skylark ARF - .46
  • See User Ratings
  • Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    Kaango.com Classifieds
    2.078RCU1
