Don Szczur
Joined: 1/6/2002 From: Chantilly, VA, USA Status: offline
Mounting Blind nuts on the firewall. When putting the Hyde mount on (without dissassembling the beams) it was difficult getting a drill in for the holes. Here are the steps to get them in. By the way, I found the Hyde ARI mount to be quite expensive, but worth it. I've never had problems with any of the ones I've run, and servos last longer, batteries don't run down as fast and the plane just seems to last longer. 1. With the mount positioned and secured with the 1/'4 x 20 knob in the back, took a drill (just fit in the holes) and hand-turned some holes (the plywood is soft enough). then remove the mount and drill the holes from where the hand-drilled marks are. 2. Now, install the blind nuts (not like I did by hammering in from the back or through a punch for the two on the left side) but by first cutting away some of the triangle stock to clear the blind nuts on the left, then start the screws through the mount, start to tighten (half way) and put in a few drops of CA, then tighten up all the way. 3. Done. I then mounted the box with some CA and put triangle stock behind and in front of the firewall to secure the ply sides; then added the top and bottom. I took a hole-saw (about an inch and a quarter) and drilled a hole in the middle of the top plate to access stuff inside if needed in the future. Next step is hinging. I tried the elevator pushrod and yes, as others have discovered, its a right snug fit in the rear support block. I'm going to drill a hole from the back tail post and enlarge the pushrod support hole some. (then hinge all the surfaces to include the rudder). Going to the hobby shop for some thin CA. Don
