RE: RE: RE: FOCUS II ARF construction by-the-numbers
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pattern Flying >> RE: RE: RE: FOCUS II ARF construction by-the-numbers
Page: <<   < prev  1 2 3 [4] 5 6 7 8 9 10   next >   >>
Login
RE: RE: RE: FOCUS II ARF construction by-the-numbers - 2/13/2004 7:47:09 PM
Pro pattern
Status: offline
Like I have promise here are the pic's.
You'll see way I sad that (PATTERN FREAK )Gregory Winklaar did a excellent job.
Danny Koolman
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Nobody is perfect, I’m nobody
3rd place, is just 2nd best loser
(in reply to Pro pattern)
       Post #: 76
RE: RE: RE: FOCUS II ARF construction by-the-numbers - 2/14/2004 5:28:17 PM
Don Szczur
Status: offline
Tailwheel assembly.
This was very simple, but important to mount correctly to avoid binding with the rudder. The technique I used (similar to that which Dave Guerin did on my last focus) after staring at it for a few days, and after finding a couple of steel wheel collars, included:
1. Slipping the wire through the tailwheel bracket and clipping the wire about flush with the top of the bracket.
2. Clipping the bushing part end off (just after the hole) and slipping it on the top of the tailwheel bracket
3. Putting in the wheel collar (I used a standard 3/32 wheel collar with a 4x40 socket head screw). File a flat notch where the screw meets the wire.
4. mount the wheel and put another 3/32 wheel collar to hold the wheel on. (File a flat where the wheel collar screw fits in there as well).
5. Align the tailwheel assembly so its straight front to back and the wire/wheel collar/bushing center are smack center of the rudder hinge line. Mark two holes and drill 1/16 holes, screw in with two of the supplied #4 screws.
6. align the tailwheel so its straight with the rudder, and then mark the hole of the bushing where it goes into the rudder. Move the tailwheel over, drill a 1/16 hole and then move the bushing tab over and screw in in the hole with another of the supplied #4 screws.
7. Take two steps back and wonder why it took three evenings to mount something so simple.
       Post #: 77
RE: RE: RE: FOCUS II ARF construction by-the-numbers - 2/15/2004 4:45:49 AM
Eric.Henderson
Status: offline
How's this hybrid? Central hobbies mixed with a Sullivan.
Click for fullsize
If it has wings I''ll fly it....
(in reply to Don Szczur)
       Post #: 78
RE: RE: RE: FOCUS II ARF construction by-the-numbers - 2/16/2004 2:20:05 AM
Pro pattern
Status: offline
Hello Don,
I was wondering where precisely did you put the elevator servo? ( measurements )
And with this set-up, did you use the full length of the carbon-fiber pushrod?
Your info will be appreciated.
Danny
(in reply to Eric.Henderson)
       Post #: 79
RE: RE: RE: FOCUS II ARF construction by-the-numbers - 2/17/2004 2:13:38 AM
Don Szczur
Status: offline
Hello- I used the full length pushrod, with about 1 inch or so removed. Attached is diagram, viewed from the fuselage bottom.
Cheers!
Don
Click for fullsize
       Post #: 80
RE: RE: RE: FOCUS II ARF construction by-the-numbers - 2/17/2004 2:19:08 AM
Pro pattern
Status: offline
Thanks a lot Don,
Danny
       Post #: 81
RE: RE: RE: FOCUS II ARF construction by-the-numbers - 2/17/2004 2:46:42 AM
Pro pattern
Status: offline
And also when did you cut (remove) this 1” peace, before or after clueing on the Y
connector for the elevator pushrod. ( before or after you assemble the elevator pushrod
as you shown in post Nr. 46 pic )
Again, Thanks
Danny
       Post #: 82
RE: RE: RE: FOCUS II ARF construction by-the-numbers - 2/18/2004 4:19:21 AM
Don Szczur
Status: offline
Danny,
After doing the steps in post #46. I think it was about an inch or so. I remember thinking that it would not be long enough to mount the servos in the front bay (canopy access) area, so that's why I put the servos from the under-side rear bay. Here were the steps I took: I had everything mounted (servos, pushrod, linkages in the back) and then screwed the clevis on the titanium pushrod end, centered the elevator and servo, and eye-balled the length by holding the Ti/clevis assembly next to the pushrod (marked it) then cut the CF with a dremel.
After putting some thick CA on the Ti end and inserting it into the CF pushrod end, I secured the pushrod to the servo.
Don
       Post #: 83
RE: RE: RE: FOCUS II ARF construction by-the-numbers - 2/18/2004 5:04:20 AM
Eric.Henderson
Status: offline
Don,
I would reccomend using JB weld to hold in the pushrod end. Been doing this for several years with zero failures..
My Focus-2 is about a week of evenings away from being flyable. Need some parts at the WRAM show.
Will be gluing my belly pan into a groove cut into opening
Using OS 1.60RFX with pump...
Nite
Click for fullsize
Click for fullsize
       Post #: 84
RE: RE: RE: FOCUS II ARF construction by-the-numbers - 2/20/2004 6:56:53 PM
rodney tanner
Status: offline
Eric,
Is the pump the OS 140RX part or an aftermarket graft?
Regards
Rodney
       Post #: 85
RE: RE: RE: FOCUS II ARF construction by-the-numbers - 2/22/2004 5:53:03 AM
Eric.Henderson
Status: offline
Sherline lathe and mill adaptation. Not a standard product.
(in reply to rodney tanner)
       Post #: 86
RE: RE: RE: FOCUS II ARF construction by-the-numbers - 2/22/2004 8:24:42 AM
Doug Cronkhite
Status: offline
quote:
ORIGINAL: Eric.Henderson
What does this mean Eric? Did you cut a groove around the entire belly opening to slot the pan into?
Doug Cronkhite
       Post #: 87
RE: RE: RE: FOCUS II ARF construction by-the-numbers - 2/23/2004 1:53:06 AM
Eric.Henderson
Status: offline
Almost Doug.
I cut a piece off the front as far back as the landing gear. Then I cut a groove about 1/8" down for the rest of the belly pan. I also recess the front section by peeling back the covering. Cutting away 1/16" deep to match the belly pan. The rear section will be glued in place.
I'll post some pic's when I get a chance.
Regards,
Eric.
Fresh back from the WRAM show.
       Post #: 88
RE: RE: RE: FOCUS II ARF construction by-the-numbers - 2/23/2004 4:20:54 AM
Eric.Henderson
Status: offline
Part one. The tool is made from a dremmel arbor with two cutting discs. One is a wood cutter and the other a metal cutter to get the right thickness of slot.
The tool runs in a ball bearing pressed into the tool support handle (a srap of ali angle bar). the other two bearings work like a router stand off.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 89
RE: RE: RE: FOCUS II ARF construction by-the-numbers - 2/23/2004 4:24:20 AM
Eric.Henderson
Status: offline
part 2
The area to be cut was doubled up with some 3/8" balsa. the ard part was taht is is an ARF and care had to be taken with the covering.
However it looks tidy and you lose the lip/edge that catches when you clean the bottom.
Click for fullsize
       Post #: 90
RE: RE: RE: FOCUS II ARF construction by-the-numbers - 2/23/2004 4:30:15 AM
Eric.Henderson
