After Run Oil And Omega Fuel ( Morgan )
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> After Run Oil And Omega Fuel ( Morgan )
Page: [1]
Login
After Run Oil And Omega Fuel ( Morgan ) - 1/17/2004 3:00:49 AM
BAMAFLY
Status: offline
Noticed on newer label that it says, " Do not use after run oils! " Any comments on this? New formulation? The old labels didn`t say this.
       Post #: 1
RE: After Run Oil And Omega Fuel ( Morgan ) - 1/17/2004 7:05:05 AM
JoeAirPort
Status: offline
Good catch. I just went and looked at the bottle and you're right. I think they say that cause the fuel is supposed to have the stuff already in it, just like the antifoaming agent. Hopefully it doesn't mean that the after run oil mixed with the new Omega fuel harms the engine.
Joe
_____________________________
Joe AP
(in reply to BAMAFLY)
       Post #: 2
RE: After Run Oil And Omega Fuel ( Morgan ) - 1/17/2004 3:03:37 PM
BAMAFLY
Status: offline
That`s my main question as well, Joe. I`ve been using after run oil with my " old " Omega fuel. I`ve sent an e-mail to Morgan asking questions. If I don`t get a response in a couple of days I think it warrants a phone call.
(in reply to JoeAirPort)
       Post #: 3
RE: After Run Oil And Omega Fuel ( Morgan ) - 1/17/2004 5:03:10 PM
Fatboydrvr
Status: offline
I recently discovered something very interesting. I purchasd an OS 90 four stroke brand new in the mid 80's. I bench ran it to break it in a few times. Then a few more for kicks. I was a kid, so I wasn't really into caring for the engines very much. The engine sat around after that in the garage, in the house, various places as it was moved through the years. It was in very humid areas, consequently, the outside had some corrosion, the bolts on the outside also had rust. I recently took the engine apart after all these years, and was blown away to find absolutely no rust on the inside! The bearings had varnish on them from the gumming of the fuel and oil left in it, but the cylinder wall, the ring, the piston, the valves, literally looked like new!! I was quite surprised. Leaves me to believe that whatever these fuel manufacturers put in their fuel for rust prevention works very good. I did never put any type of oil in the engine after I ran it whatsoever.
       Post #: 4
RE: After Run Oil And Omega Fuel ( Morgan ) - 1/18/2004 10:26:11 PM
RaceCity
Status: offline
I would like to see a show of hands of those who actually believe that Morgan (Omega) has
added "ARO" to their fuel, or that it posseses some mystical quality which eliminates the
need for good post-use engine care.
Omega is GREAT fuel. I use lot's of it. I also make a habit of running out the motor at
the end of the day to remove moisture attracting alcohol and then nail the engine with a real
healthy dose of ARO.
Nary a problem. Why should there be?
It's called "MARKETING" and the "DO NOT USE AFTER RUN" is a roundabout way of
promoting their oil package.
Further...fuel manufacturers are reluctant to add anything to the fuel that really doesn't
need to be there. Any additional components mean added cost, added processes and less
burnable mixture....the end result is a product that costs more, and modelers (ARF consumers?) are
notoriously price conscious.
If it ain't nitro (that they can charge a lot for)...they don't want it in there.
Like it or not...That's my take on it.
'Race
< Message edited by RaceCity -- 1/18/2004 10:35:33 PM >
(in reply to Fatboydrvr)
       Post #: 5
RE: After Run Oil And Omega Fuel ( Morgan ) - 1/19/2004 2:57:48 AM
downunder
Status: offline
I wonder if it's because their Omega fuels all have castor blended with the synthetics which would make an ARO redundant? I'm still waiting for them to get their "FAI" fuel right though
(in reply to RaceCity)
       Post #: 6
RE: After Run Oil And Omega Fuel ( Morgan ) - 1/22/2004 3:44:54 AM
3d-aholic
Status: offline
quote:
ORIGINAL: RaceCity
I certainly don't believe they add ARO to their fuel. I'm guessing that they don't think it is needed and might believe it is detrimental in some way....and they don't want to have it blamed on their fuel. I have never heard that ARO was a problem though....but it seems to me that ARO is kinda like a "black art".....people think it does something....but no-one really knows....everyone just has their personal experience.
       Post #: 7
RE: After Run Oil And Omega Fuel ( Morgan ) - 1/22/2004 1:07:48 PM
RaceCity
Status: offline
I certainly don't believe ARO is added to anyone's fuel either. Let me pour a cup of coffee...
I'd love to curl up and listen to the stories of why oiling a motor would be detrimental.
Product Marketing is one thing...mechanics are entirely another.
Folks can believe what they want...do what they want to do.
I'll oil my motors thank you all....
<G>
'Race
AMA 63990
(in reply to 3d-aholic)
       Post #: 8
RE: After Run Oil And Omega Fuel ( Morgan ) - 1/22/2004 2:37:30 PM
Sport_Pilot
Status: offline
Oiling a motor CAN be detrimental if enough moisture is present when the oil is added. Oil floats on top of water. Mineral oil will not mix with water and the water is traped between the oil and the metal parts. If you store nose down the water will flow toward the bearings. If you add oil right after flying there will be some moisture in the engine. Best to run the engine dry and add castor or even synthetic oil as an afterrun oil. Or at least let it sit with the pistion at BDC for a while before adding the afterrun oil.
       Post #: 9
RE: After Run Oil And Omega Fuel ( Morgan ) - 1/22/2004 4:08:26 PM
3d-aholic
Status: offline
quote:
ORIGINAL: RaceCity
I don't know their product --- for all I know some by-product is left over from their fuel which they intend to be useful but under the conditions of some ARO form some reactive product with properties similar to bubble gum.
I sincerely doubt it...but who knows exactly what is in Omega Fuel.
< Message edited by 2MuchThrow -- 1/22/2004 11:10:20 AM >
       Post #: 10
RE: After Run Oil And Omega Fuel ( Morgan ) - 1/22/2004 4:12:09 PM
3d-aholic
Status: offline
Oh, and I'm in marketing and if this is marketing....they need to fire their marketing person.
Morgan:
instead of "Do not use after run oils! "
Try:
"After run oils not needed because of the excellent lubricating qualities of this fuel"
No charge...this time.
< Message edited by 2MuchThrow -- 1/22/2004 11:15:36 AM >
       Post #: 11
RE: After Run Oil And Omega Fuel ( Morgan ) - 1/22/2004 6:26:35 PM
RaceCity
Status: offline
Well...in light of the fact that I run out as much of the fuel as I can at the end of the day
and then hand prop it 'til it just won't even try to emit a "pop"....I feel pretty safe that I'm not
storing my engines in an Oil/Water pickling solution.
Others can take whatever approach they want. Mine has proven itself to me to be quite
effective at preventing problems. Period.
I simply don't buy into the "DO NOT USE ARO" thingie on the bottle. Simple.
Why not? How do they know what my ARO consists of? If the fuel has some weird ingredient
that could be corrosive in the presence of some lubes....it's that FUEL that needs to be fixed...
'Race
AMA 63990
       Post #: 12
RE: After Run Oil And Omega Fuel ( Morgan ) - 1/22/2004 6:38:31 PM
3d-aholic
Status: offline
quote:
ORIGINAL: RaceCity
'Race
They don't...thats the only reason I can deduce they put it on....to protect them from some frivilious lawsuit....the marketing is too bad to suspect thats the reason.
Most of the warnings on the bottle are for lawsuits. I was reading an old bottle yesterday that I was cleaning out so that I could reuse it to store my homebrew in there that said:
Do Not Resuse this Bottle?
I giggled because I know someone somewhere along the line, cleaned out the bottle and is storing their child's cherry kool-aid in there in their refrigerator.
       Post #: 13
RE: After Run Oil And Omega Fuel ( Morgan ) - 1/23/2004 3:37:32 PM
Fuelman
Status: offline
Properly taken care of and run dry at the end of a flying session, any engine using a fuel with a considerable castor content will have less of a need for after run oils than an engine running total synthetic lubes or one with wet fuel left in the engine.
Are you going to hurt anything by adding your favorite after run oil (assuming it's appropriate for that type engine)? NO, you will not, just don't hydro lock the engine the next time you go to start it up.
Several fuel companies, including mine, use lubricants that have some anti-corrosion properties in the synthetic. Castor has always been the best corrosion inhibitor for model fuels.
Hope this helps shed some light on the subject.
Fuelman
Cooper Fuels
< Message edited by Fuelman -- 1/23/2004 3:33:19 PM >
       Post #: 14
RE: After Run Oil And Omega Fuel ( Morgan ) - 1/24/2004 12:03:33 AM
