Dazzler
OH, USA Status: offline
14th_Reaper, I had the same problems when I tried outfitting my plane with the large Servo horns. Here's the deal I've found out with my experience with my 605's. : With std. 605 Servo's or any other non digital servo, you have a centering issue, but when used with the std size servo horns, they center very well. No non digital centers perfectly, and by putting a longer servo horn on the servo, you are exagerating that non centering effect. The futher you go away from that servo, the worse its gonna get. My suggestion, try your std length servo horns with your plane, and see the difference. BTW, those red ones are too long, even though they are std with the servo. Just my thoughts, and my plane does not require any constant trimming.
_____________________________
Freya YS80
