HITEC HS 700 SERVOS
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> HITEC HS 700 SERVOS
Page: [1]
Login
HITEC HS 700 SERVOS - 1/22/2004 5:12:56 AM
3dd
Status: offline
MIKE WHEN I TURN ON MY RECIEVER THE RUDDER SERVO WILL CYCLE FULL TURN TO THE RIGHT AND THEN TO THE LEFT AND THEN GO TO CENTER IS THIS A PROBLEM WITH THE JR PCM RECIEVER OR MABY IN THE SERVO
       Post #: 1
RE: HITEC HS 700 SERVOS - 1/22/2004 4:43:25 PM
MikeMayberry
Status: offline
I have not heard of this before. What happens if you use a different servo in that channel or plug the 700 into a different channel?
Mike.
(in reply to 3dd)
       Post #: 2
RE: HITEC HS 700 SERVOS - 1/23/2004 12:29:29 AM
3dd
Status: offline
the servo only does this in the rudder channel and will work properly in onother channel as well
(in reply to MikeMayberry)
       Post #: 3
RE: HITEC HS 700 SERVOS - 1/27/2004 4:31:11 PM
MikeMayberry
Status: offline
So then it's not an issue with the servo. Do other servos do the same thing in that channel?
Mike.
(in reply to 3dd)
       Post #: 4
RE: HITEC HS 700 SERVOS - 1/27/2004 4:51:10 PM
3dd
Status: offline
we checked it out with another servo and it did the same thing so we are going to send the reciever off to jr and have it checked out thanks for the help mike
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.281RCU1
