oil for home-brew?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> oil for home-brew?
Page: [1]
Login
oil for home-brew? - 1/24/2004 1:45:01 PM
acam37
Status: offline
I've read all the posts for making your own fuel and I would like to know exactly what kind of synthetic oil I can buy at a local auto parts store or maybe a motorcycle shop. The methanol and castor is no problem, but all the synth that I have tried will not mix in methanol. It just goes to the bottom like water in oil. If I have to order the oil or drive a considerable distance then I might as well go to the hobby shop and buy the fuel. I live in Lufkin,Tx which is about 120 miles from houston, which has the nearest H/S. What I'm trying to avoid is using a tank of gas in my car every time I need airplane fuel. one more thing, for a 0% nitro 20% oil mix how many ounces of oil for 1 gallon of methanol. All I've been reading is percentages.
       Post #: 1
RE: oil for home-brew? - 1/24/2004 2:31:12 PM
Jim Thomerson
Status: offline
One gallon is 128 oz.
Jim
(in reply to acam37)
       Post #: 2
RE: oil for home-brew? - 1/24/2004 4:27:04 PM
FlyNBHappy
Status: offline
quote:
ORIGINAL: acam37
102.4 fl oz of methanol + 25.6 fl oz of oil = 128 fl oz of 0% nitro, 20% oil glow fuel (1 gal).
or easier since most oil comes in qt size (32 oz):
160 fl oz of methanol + 1 qt of oil = 192 fl oz of 0% nitro, 20% oil glow fuel (1.5 gal)
and for a larger quantity and even easier:
4 gal of methanol + 1 gal of oil = 5 gal of 0% nitro, 20% oil glow fuel.
< Message edited by Addict2RC -- 1/24/2004 10:33:24 AM >
       Post #: 3
RE: oil for home-brew? - 1/24/2004 4:41:22 PM
FlyNBHappy
Status: offline
quote:
ORIGINAL: acam37
Unless your auto/motorcycle shop stocks synthetic (usually Klotz) that mixes with methanol, none of the car products (ie Mobil 1, Castrol Syntec, etc.) will mix with methanol.
I get my oil (CoolPower oil, light with castor or for all syn, get it without castor) from this site: http://www.tommyskarts.com/Cat.Oils.htm
It is the same stuff that CoolPower sells and at $52/4gal, I believe it is a very good deal
       Post #: 4
RE: oil for home-brew? - 1/24/2004 10:26:53 PM
martyg
Status: online
Addict2RC, what does Tommy's charge you for shipping a case of Coolpower oil?
I take it your experiences dealing with this supplier have been positive?
_____________________________
-- Marty
(in reply to FlyNBHappy)
       Post #: 5
RE: oil for home-brew? - 1/25/2004 1:12:36 AM
FlyNBHappy
Status: offline
Martyg,
Normally, they charge about $20 for a case/4 gal. But for the month of January, it is free shipping. A hell of a deal ($52/4 gal) of Coolpower oil.
Even with the shipping charge, it still beats a lot of places.
(in reply to martyg)
       Post #: 6
RE: oil for home-brew? - 1/25/2004 2:53:43 AM
flipa10
Status: offline
Any idea the difference between light med and heavy, except for the obvious? I wonder which does coolpower use for Rc fuel-light, med or hvy?
       Post #: 7
RE: oil for home-brew? - 1/25/2004 8:39:37 AM
FlyNBHappy
Status: offline
quote:
ORIGINAL: flipa10
Since these oils are labeled for 4-cycle use in karts, light is for stock, med is for modified stock, and heavy for super stock. I've been using the light version with castor and everything seems fine. I'm thinking of ordering some without castor and see if there is a difference.
< Message edited by Addict2RC -- 1/25/2004 2:36:15 AM >
(in reply to flipa10)
       Post #: 8
RE: oil for home-brew? - 1/25/2004 1:15:57 PM
martyg
Status: online
Addict2RC, any idea how much castor in in their light Castor/Synthetic blend oil?
-- Marty
       Post #: 9
RE: oil for home-brew? - 1/26/2004 3:04:41 AM
FlyNBHappy
Status: offline
quote:
ORIGINAL: martyg
Martyg,
I don't know the exact, but I'm guessing it is 70 syn / 30 castor. This is the percentages of their Omega glow fuel.
       Post #: 10
RE: oil for home-brew? - 1/29/2004 3:11:26 AM
flipa10
Status: offline
Just bought 3 gals of the light with castor in quarts because the 1 gals were out. $52, free shipping. I run zero nitro so should make pretty inexpensive fuel.
       Post #: 11
RE: oil for home-brew? - 2/14/2004 11:02:25 PM
BaronSchwab
Status: offline
I am trying to get into homebrewing and have a few questions.
Is 20% oil a 4:1 mix? 4 part meth. 1 part oil.
What kind of castor should be used? The stuff at the pharmacy?
Would a 50/50 castor/syn mix be good?
Thank you for your help.
Non esse sine aircraftus.
       Post #: 12
RE: oil for home-brew? - 2/15/2004 7:28:22 AM
FlyNBHappy
Status: offline
quote:
ORIGINAL: BaronSchwab
Yes, 20% oil by volume is 4 part meth, 1 part oil. This is for FAI fuel (0% nitro).
Don't buy the over the counter castor oil for human consumption. Buy the castor oil you get at a motorcycle/go-kart/racing shop made to mix with methanol (Klotz Benol, Baker's Castor, etc.). Check the Sig website. They sell the Baker's castor oil for about $25/gal. Or check the the go-kart website listed above.
50/50 castor/syn is a good all-around mix. This is a highly debated topic, so just find something that works for you. To keep it simple, I either use 100% castor, or 100% synthetic; whatever is cheaper at purchasing time. I haven't notice much difference in engine performance yet.
< Message edited by Addict2RC -- 2/15/2004 1:31:39 AM >
(in reply to BaronSchwab)
       Post #: 13
RE: oil for home-brew? - 2/15/2004 2:11:59 PM
BaronSchwab
Status: offline
What's the differance in the Castor? I thought you just wanted them to be able to mix.
       Post #: 14
RE: oil for home-brew? - 2/16/2004 11:34:33 AM
FlyNBHappy
Status: offline
I'm assuming you're asking about over the counter castor oil vs. racing castor oil and not between different brands. From previous posts, the racing castor oil goes through a degumned process. Unsure about pharmacy castor oil.
       Post #: 15
RE: oil for home-brew? - 2/16/2004 2:03:41 PM
BaronSchwab
