The Combat Wolverine
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> RC Combat >> The Combat Wolverine Page: [1]
Login
The Combat Wolverine - 1/24/2004 3:39:48 PM
WolverineRC
Status: offline
I am in the process of designing a combat plane for limited production.
What are your Favorite combat plane Features?
What would you like to see in a combat plane?
       Post #: 1
RE: The Combat Wolverine - 1/24/2004 4:09:34 PM
stdun
Status: offline
If you don't survive, you don't win. It has to be able to survive mid-airs. Also wide wings, in the 6' range. Easy to repair and repairable to start with. Fast always helps.
< Message edited by stdun -- 1/24/2004 4:03:46 PM >
(in reply to WolverineRC)
       Post #: 2
RE: The Combat Wolverine - 1/24/2004 7:51:51 PM
thojo
Status: offline
1) The more modular the design the better. Being able to field repair is extremely important. Replacable engine mounts, wings, tail feathers helps speed up repairs between rounds.
2) Protection for rx, battery, servos and fuel tanks. The more that is protected, the less damage suffered during mid-airs and the more likely you'll survive a mid-air to keep flying in the round.
3) In SSC, wingspans over 60" decrease your roll rate, in Open B, the speeds are higher and wingspan isn't is much of a factor.
4) Large vertical stabs to decrease yaw problems when streamers get caught on the ends of the wings..
5) Keep exotic parts out of the kit. If it can't be bought at home depot, leave it out... Most people cannot afford to buy alot of kits for combat. They will buy one, then reproduce it to build their fleets...
(in reply to stdun)
       Post #: 3
RE: The Combat Wolverine - 1/25/2004 2:42:20 AM
combatpigg
Status: online
HI WOLVERINE! BELLINGHAMs not that far away. Any chance you would like to do some streamer chasing? I haven't flown any rulebook RC combat, I mostly fly 1/2A around here with .061s. The action is slower, closer, and less damaging when they hit. I'm also geared up to fly SSC this year. The points THOJO made make a lot of sense. I think the engine mount should only be strong enough to support the engine for vibration free runs, but able to snap away cleanly when the model goes straight in. The other thing would be as low a parts count as possible. Last but not least, the planes that can haul around the most wing span will be better at collecting streamers than a plane with less span. The guys at the top of the AMA food chain all had planes with lots of span.
_____________________________
Led Zeppelin is NOT "old fogie" music.
       Post #: 4
RE: The Combat Wolverine - 1/26/2004 3:55:58 AM
WolverineRC
Status: offline
Hey guys
Thanks For the input,
do you prefer elevon servos mounted in the wing or in the fuse?
Pink Or white foam for the wing cores?
COMBATPIGG:
I'm sure I can get a couple people together for a little fun, However I must warn you, We play rough. we have been flying mostly Gremlins with 25's on them. and have gone through a lot of them.
When do you usually fly combat???
< Message edited by WolverineRC -- 1/26/2004 3:54:20 AM >
(in reply to combatpigg)
       Post #: 5
RE: The Combat Wolverine - 1/26/2004 7:39:36 AM
combatpigg
Status: online
HI WOLVERINE! I've got SEVERAL good running .061 set ups,RTF, and would like to know if you and a couple of buddies are interested in some "little fun". You might be surprised! I can do the .25 style JOUSTING also, but IMHO the action is too high speed and out of control to be much more than a demolition derby. I also have flown AMA C/L COMBAT, [for 18 years] so I'm familiar with 20 second life expectancy planes. For my money, I get more out of events that limit the speed, because the quality of the DOG FIGHTING is better. Not many guys can afford the time, money, and effort it takes to fly club combat on a consistant basis. That's why there are more lookyloos and wannabes than there are DOERS, and participants. That's why I have been promoting 1/2A combat, because the investment in time and money is minimal, and it will still keep you sharp for RULE BOOK COMBAT! Very rarely is one of these planes damaged to the point where they can't be fixed on the spot with some glue and tape. They can haul 30' of streamer good, and your buddies' streamer as well[almost as well]. Let's get together some time[anytime] and do both.25, and 1/2A! BRING IT ON! !!
< Message edited by combatpigg -- 1/25/2004 11:49:09 PM >
       Post #: 6
RE: The Combat Wolverine - 1/26/2004 8:51:33 AM
FHHuber
Status: offline
Survivability says... package the radio in a tight group so there aren't long servo leads that can be hit and ripped out of the RX or servo. (those old 3 ch systems that had the RX, and 3 servos built into one case in the mid 1970's would be ideal on this issue. Just a battery lead.)
If you have a 3 inch lead beteen RX and servo a wing is eventually going to snag it. (usually meaning you had wing sawed off in the mid-air... but its a pain soldering back in a servo lead)
There will never be 100% protection fr any part of a combat plane... and excess armor is just weight to make you slow (and therefore a target)
       Post #: 7
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.516RCU2
