3000 feet video flight
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Aerial Photography and Video >> 3000 feet video flight
Page: [1]
Login
3000 feet video flight - 1/25/2004 1:01:47 AM
W4UAV
Status: offline
I made it to over 3000 feet today. The GPS overlay board measures the altitude in meters.
It read at its peak 1068 meters. Our field is at 32 meters above sea level. I didnt fly by
video but I had someone watch the video monitor and call out the altitude, I told them not to
stop till it reached four digits! The plane was visible, barely, my eyes were glued to it.
The orange panel on the underside of the wing I added really helped! Its white with an orange
stripe on one wing, orange with a white stripe on the other.
The plane is my faithful SIG LT40 Heavy Lifter (I mean heavy!) The 1072 sq inches of wing
really hauls a load, the OS 46 FX really helps!
I mounted the dipole externally via RG174 coax pointed up and the 1 watt transmitter put out
a clean signal, I am sure it would have gone higher!
ADDED 2 NEW GRABS 1-27
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by KE4UVQ -- 1/27/2004 6:03:05 PM >
_____________________________
Mike Robinett
W4UAV
       Post #: 1
RE: 3000 feet video flight - 1/25/2004 1:08:50 AM
Rotcivv17
Status: offline
Oh my god dude I can't believe a plane can go so high, and how could you see that at 3,000 feet?!?!? Wow thats insane, nice work. How did u bring it down? Idle throttle and straight down?
Victor
(in reply to W4UAV)
       Post #: 2
RE: 3000 feet video flight - 1/25/2004 1:23:51 AM
W4UAV
Status: offline
It was pretty small. After hearing 1000 meters, I cut the throttle to idle and lazily
circled the plane down and brought it in nice and smooth, the LT 40 is a great camera
ship!
Mike Robinett
W4UAV
(in reply to Rotcivv17)
       Post #: 3
RE: 3000 feet video flight - 1/25/2004 1:45:24 AM
BP5589
Status: offline
Mike,
Great job! How long did your flight last?
Bill
http://www.bp55899.com
(in reply to W4UAV)
       Post #: 4
RE: 3000 feet video flight - 1/25/2004 2:04:45 AM
W4UAV
Status: offline
Actually that particular flight only lasted 8 minutes!
I flew three camera flights today, mainly testing the externally mounted
antenna vs. it being mounted directly to the transmitter. Outside worked
out better!
Mike Robinett
W4UAV
(in reply to BP5589)
       Post #: 5
RE: 3000 feet video flight - 1/25/2004 2:24:20 AM
PlaneKrazee
Status: offline
Hi Mike,
Good job.
What transmitter/camera/gps are you using?
KB1DTB
AMA11123
(in reply to W4UAV)
       Post #: 6
RE: 3000 feet video flight - 1/25/2004 2:34:15 AM
W4UAV
Status: offline
Thanks guys!
Heres the skinny:
Transmitter: BlackwidowAV 1000 mw, stock dipole mounted outside on fuselage.
http://www.blackwidowav.com/bwav241000tx.html
Camera: Supercircuits CCD camera 380 line res mounted on servo to look ahead and down (proportional)
http://home.bellsouth.net/p/s/community.dll?ep=87&subpageid=88269&ck=
GPS: Garmin OEM board GPS with GA27 amplified antenna mounted on fuselage tail before vert. stab.
http://www.garmin.com/products/gps15h/
GPS overlay: Intiutive Circuits OSD-GPS unit
http://www.intuitivecircuits.com
Mike Robinett
W4UAV
(in reply to PlaneKrazee)
       Post #: 7
RE: 3000 feet video flight - 1/25/2004 2:53:31 AM
W4UAV
Status: offline
Heres the inside of the LT40
I like to keep a neat cockpit!
Second pic is the transmit dipole-in-a-duck and GPS antenna.
Click for fullsize
Click for fullsize
Mike Robinett
W4UAV
(in reply to W4UAV)
       Post #: 8
RE: 3000 feet video flight - 1/25/2004 3:09:37 AM
Fubar-One
Status: offline
Very nice, very clean. I might try that antenna install for my KSA with the 900mhz gear.
My BWAV experiments have been geared towards a strap on kind of setup for different planes but my KSA is a dedicated video platform. Got a feeling that that antenna setup with a patch antenna on the ground would be a real winner. Just gotta get a patch antenna for 900mhz.
Didnt get a chance to retest the BWAV today since we actually had some of that rain stuff.
I dont think I got the cajones to take my KSA up that high tho...
quote:
ORIGINAL: KE4UVQ
"B Positive to ground, over..."
(in reply to W4UAV)
       Post #: 9
RE: 3000 feet video flight - 1/25/2004 3:15:32 AM
W4UAV
Status: offline
Thanks Dan,
I thought long and hard where to mount it externally. I did an extensive range check
with the transmitter on to make sure it wasnt interfering with the front end of the receiver,
even thought its PCM, front end overload is possible any time theres RF present. All it has
to do is interfere enough to shortten the range a bit, then its fail-safe for sure!
A patch antenna on the ground would work wonders!!!
I dont think youd regret it.
Mike Robinett
W4UAV
(in reply to Fubar-One)
       Post #: 10
RE: 3000 feet video flight - 1/25/2004 3:31:03 AM
IA-Flyer
Status: offline
That’s a very clean layout and I like your GPS antenna, very aerodynamic!
That’s an amazing video signal coming from the bottom end of a dipole, what were you using for your video receiver antenna?
I like that GPS module, does it have waypoint capability, or do you use something different with your u-nav setup?
Thanks!
P.S. Aren’t you ever tempted to fly using the video?
Jim
(in reply to W4UAV)
       Post #: 11
RE: 3000 feet video flight - 1/25/2004 3:43:56 AM
W4UAV
Status: offline
I dont use the PDC-10 or even a Copilot on this plane, thats the UAV demonstrator
plane I have all that on:
http://home.bellsouth.net/p/s/community.dll?ep=16&ext=1&groupid=88932&ck=
No, the GPS OEM15H just sends out data, Im pretty sure they use these units in the Onstar
system for vehicle tracking.
The biggest thing that amazed me was the difference the view was from 1000 meters over the usual
300 meters I was used to flying at, it really looks different. I have flown by video for short periods
at the 300m level, but Ill have to get used to the view from way up there to keep from getting disoriented.
I thought of since I can see the GPS position in the top left corner, creating a virtual box try to stay in
using the coordinates.
Heres the receive setup, thats an 8 db patch antenna.
Click for fullsize
Mike Robinett
W4UAV
(in reply to IA-Flyer)
       Post #: 12
RE: 3000 feet video flight - 1/25/2004 4:10:42 AM
Ensignnolo
Status: offline
Mike,
I took a look at your website, it's nice. Regarding your patch antenna, did you special order one with the correct connector for the BWAV receiver?
Ensignnolo
       Post #: 13
RE: 3000 feet video flight - 1/25/2004 11:25:10 AM
bobo_54501
Status: offline
Thats pretty cool ..!! But it made me think .. Is there a legal limit on how high we can fly ?? Just wondering ??
(in reply to Ensignnolo)
       Post #: 14
RE: 3000 feet video flight - 1/25/2004 1:17:37 PM
W4UAV
Status: offline
quote:
ORIGINAL: Ensignnolo
Ensignnolo
Yes, it has an SMA male already installed.
http://www.blackwidowav.com/patchantenna1.html
Mike Robinett
W4UAV
       Post #: 15
RE: 3000 feet video flight - 1/25/2004 6:49:24 PM
