CRUNCH?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC 1/8th Scale Buggies >> CRUNCH?
Page: [1]
Login
CRUNCH? - 1/25/2004 6:42:58 PM
Model Mania
Status: offline
Every time i pull the brakes on my MP7.5 thers a crunch sound from the gears. Its happened before and i ended up replacing the rear diff gears but the rear diff was also jammin but its not jammin now. I thought it was because a bit of grit got into the diff case or somethin but i never found the route of the problem. Anyway ive just replaced the gears and ran 3 tanks through the buggy and its crunchin again. Does anyone have any ideas?. Please help!
       Post #: 1
RE: CRUNCH? - 1/25/2004 6:56:20 PM
lendaddy
Status: offline
could be any of the front/rear/or center spider gears or either the front or rear ring and or pinion gears. Is this an RTR Inferno?
(in reply to Model Mania)
       Post #: 2
RE: CRUNCH? - 1/25/2004 6:57:45 PM
Model Mania
Status: offline
No its a standard MP7.5 kit
(in reply to lendaddy)
       Post #: 3
RE: CRUNCH? - 1/25/2004 7:15:50 PM
sh0wtime
Status: offline
sounds like the ring gear on the outside of your diff slipping on the pinion!
you need to remove the diff then shim it over inside the casing so its pushed against the pinion
you should've got the shims/thin washers in your kit
check the gear & pinion for wear/ missing teeth while its out too
       Post #: 4
RE: CRUNCH? - 1/25/2004 7:17:50 PM
Model Mania
Status: offline
Thanks showtime, will do
(in reply to sh0wtime)
       Post #: 5
RE: CRUNCH? - 1/25/2004 7:25:24 PM
sh0wtime
Status: offline
get in contact with Russ at Top Options for decent prices on Kyosho parts etc in the UK
he does mail order too
       Post #: 6
RE: CRUNCH? - 1/25/2004 7:28:36 PM
Model Mania
Status: offline
I work in a my hobby shop no prob with cheap parts
       Post #: 7
RE: CRUNCH? - 1/25/2004 8:52:26 PM
k-carboy
Status: offline
i had a bearing go out once and caused this very problem. trashed the ring and pinion gears. try aftermarket bearings- way better! this is my biggest complaint with k-cars.
       Post #: 8
RE: CRUNCH? - 1/26/2004 4:39:23 PM
Model Mania
Status: offline
Which bearing was it?
(in reply to k-carboy)
       Post #: 9
RE: CRUNCH? - 1/27/2004 5:55:11 AM
k-carboy
Status: offline
it was the left side rear diff bearing (the one that the diff rides on inside the gear case). evidently there is a problem with dirt getting in there and trashing the bearing. when it goes out the ring and pinion get too much play and start to slip. if you caught it soon enough your gears might be ok. obviously i didnt.
       Post #: 10
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.407RCU2
