wingspan99
CO, USA Status: offline
Well it flies really weird but not unflyable. I used rudder to make turns, it keeps it upright, although banked turns makes it look like an X-wing fighter. I suggest using a two-channel gyro from Hobbico on the elevons, it will allow the elevon mixing to pass through, yet give aileron corrections to counter torque pulses from throttle movements. I used one on the X-Ball which needed it more than the PBX-Wing. One thing I discovered is that it will do a very tight rolling circle with the mere application of full aileron one way or the other, in fact it slowly climbs in the circles. I don't have any plans for it, it's all in my head still. If you want a materials kit, I can make one for $35. I can mark up the materials with a pen for cutting elevons, torque doors, etc. Tom
