unusual projects
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Unusual R/C >> unusual projects
Page: [1] 2 3   next >   >>
Login
unusual projects - 1/25/2004 7:57:29 PM
Ram-bro
Status: offline
I am looking for something different to fly . Our club is having a contest to see who can come up with the most unusal flying contraption. We have the flying witch, cars, stop sign, iron, lawn mowers and parachutists. I need something that will blow there socks off and I am having a brain fart. Lets see what you guys have in your inventory for plans and ideas. The winner of this contest gets $200 butt hat i s not the reason for my interest.
       Post #: 1
RE: unusual projects - 2/1/2004 3:15:23 AM
thenothing
Status: offline
I have seen the flying witch designs online. They made me wonder if somehow doing a flying santa sleigh with reindeers would be possible.
There's also an old Shel Silverstein poem about Ickle me, Pickle me, and Tickle me too. They all flew away in a... flying shoe!
A UFO would be pretty neat too, but I would think they have been done before. I'm very new to the R/C scene though.
Hmm... just to toss out completely random ideas now...
A frog
A giant fly
A book
A brain (with attached spinal cord, hehe)
(in reply to Ram-bro)
       Post #: 2
RE: unusual projects - 2/1/2004 8:26:48 AM
Ram-bro
Status: offline
The flying sleigh and reindeer is a perfect idea. I think I have seen plans for those somewhere out there. Also another great idea would be for the formation flying planes all tied togethr to fly as one. I will look for these plans and see what is out there. See what happens with just a little input. Thanks for the spark
(in reply to thenothing)
       Post #: 3
RE: unusual projects - 2/1/2004 4:46:27 PM
Spaceclam
Status: offline
how about something like this? made it myself. i am 13, so it shouldn't be too hard for you guys to do. and yes, i have flown it and it is flyable. i am sure a homebuilt contraption like this one will win the contest, however it will run you about $400 dollars assuming you have a computer radio with at least 8 programable mixers. of you do not, you will have to go the vtail mixer route and the good ones (i tried the cheap ones and becuase i had to put the masters feeding off the two outputs of a third vtail mixer and they were so innacurate that ther ewas no way i could fly it) will cost you about $120-$150. however, i do believe that you would have a lot of fun doing something like this. if you wish, and are truly interested, i can give you the list of the components i used and possible substitutes.
cheers
Click to see fullsize image.
Click for fullsize
Click for fullsize
_____________________________
Duct tape is like the force. It has a light side, a Dark side, and it holds the universe together.
       Post #: 4
RE: unusual projects - 2/1/2004 5:07:46 PM
Boogie
Status: offline
Maybe a flying skii jumper??
Click for fullsize
Click for fullsize
Click for fullsize
(in reply to Spaceclam)
       Post #: 5
RE: unusual projects - 2/1/2004 11:07:40 PM
Spaceclam
Status: offline
what if there is no snow?
(in reply to Boogie)
       Post #: 6
RE: unusual projects - 2/2/2004 6:42:33 PM
danvel
Status: offline
Hey, SPACECLAM , I love your 4 rotor helicopter. I think you took the idea from the "draganflier" (RCTOYS). Didn't you?
Congratulations anyway; if you made that at the age of 13 you may be designing spaceships for the NASA when you are 25.
Please post the list of components that you used and tell us about the flyability of the machine. Did you use electronic GYROSCOPES?
How stable is it?.
I personally think that you can improve stability by lowering the Center of Gravity (using a taller box instead of that flat one and placing the batteries at the bottom of the box). That can help with the Pitch and Roll stability creating a pendulus effect.
For the Yaw movement maybe you need a Gyroscope after all to compensate for speed diferences beetween the clockwise and counterclockwise rotors unless you are a very good pilot.
Keep up the good work!
       Post #: 7
RE: unusual projects - 2/2/2004 9:56:42 PM
Ram-bro
Status: offline
so tell us about this ski jumper. That is one I know I could handle. You got plans and how does it fly?
       Post #: 8
RE: unusual projects - 2/3/2004 12:53:09 AM
Spaceclam
Status: offline
i got the idea for four rotors from the draganflyer becuase i figured it would be most stable that way. however, it was originally a school prodject so i figured that i coudln't go wrong that way. i use 4 gws eps300c-c motor system that i have installed ALL capacitors on (you will get a lot of radio glitches if you do not) swinging 4 10x4.5 props, two clockwise and two counter clockwise from www.toddsmodels.com i use a hitec feather for a reciever, 4 hitec 1010 speed controls (they are now discontinued. if you want to attempt this, you need to get one with a bec switch so you can turn only one bec on at a time. a motor arming switch is prefferable too) there are two gws microgyros on there. the problem with them is they are accurate within themselves, but you have to reset the zero point every time you turn them on. currently, i have all the mixes dome in my radio and do not have yaw control. however, i am soon going to go to vtail mixers (i did originally but those wattage mixers are so innacurate it woudln't work) to allow me to have yaw control. the setup is as follows. you hay want to draw this out to help it make sense.
you have 3 mixers, that i will label #1, #2, and #3 and a four channel reciever.
plug the slave of mixer 1 into channel 1
plug the slave of mixer 2 into channel 2
plug the slave of mixer 3 into channel 4
plug the master of mixer 3 into channel 3
plug the master of mixer 1 into one of the outputs of mixer 2
plug the master of mixer 2 into the remaining output of mixer 3.
that will give you pitch, yaw, and roll control. the outputs mixer 1 will control a set of two motors located at opposite ends of the craft. likewise, mixer 2 will opperate the other two in the same fasion.
each set has the props rotating in the opposite direction of the other set. so, rudder would increase the speed of one set and decrease the other, causing the torque to turn the model. all this would have worked, but because i had the master of one innacurate vtail mixer plugged into the output of another innacurate vtail mixer, control was unachievable.
as for stablilty, i would lower the box down more, except i have it designed so that the battery which is configured in a hump position provides the majority of the strength.i used the battery as a center structure to keep the top seperated yet firmly attatched to the bottom plate, while i have pretty makeshift supports along the sides. this has made for one tough design, and i would hate to change it. flight is controllable however. for anybody who has flown an rc helicopter, it is like having an overweight helicopter with a big engine in it. pitch and roll control are responsive, but it is slow to change direction. it is the same way with this, however it is still controllable. the picture is decieving. the battery (a 10 oz high discharde nicad) puts the cg about 1.5 inches below the rotor disks. however, the day after i posted that one of my motor leads came undonein a controlled hover and it instantly flipped over and broke one of the gearbox housings so i am out of comission for a little while. i also installed a rollcage, give nthe fact the thing landed upside down. i will also be ordering the vtails probably within the next week. i will keep you posted. i only get abotu 2 mins of flight time because i am drawing probably at least 30 amps. that is the best estimate i have. at full throttle it will draw almost 8 amps, but i fly at 3/4 throttle. it's been a fun prodject certainly. i will keep you posted. danvel, if you are seriously interrested in making one of these things, they are really fun. i will try and get a flying picture when i get it all together.
       Post #: 9
RE: unusual projects - 2/4/2004 6:55:38 PM
1cheech
Status: offline
i was at an airshow one time and i saw a flying lawnmower. it looked almost just like the real thing and it seemed to fly pretty good.
       Post #: 10
RE: unusual projects - 2/4/2004 6:59:24 PM
Ram-bro
Status: offline
we have a flying lawnmower in the club already......and it does fly well, loops,rolls and nice low trimming passes...lol
(in reply to 1cheech)
       Post #: 11
RE: unusual projects - 2/4/2004 7:25:48 PM
1cheech
Status: offline
just thought that i would let you know.
       Post #: 12
RE: unusual projects - 2/5/2004 12:44:17 AM
Spaceclam
Status: offline
i saw three of them lined up next to eachother at the basin. they were the stupidest looking things i had ever seen. they were very funny..
       Post #: 13
RE: unusual projects - 2/5/2004 6:07:55 PM
danvel
Status: offline
Thank you for the info, Spaceclam.
My plan is to design a small microprocesor-based circuit to integrate the 3 vtail mixers and the motor power drivers using 4 standard FET transistors directly controlled by the microprocessor. I think this is the best way to get good accuracy in the mixing because everything's calculated digitally within the microprocessor and there's no wiring beetween multiple different elements. I want to use only one GYRO directly attached to the rudder channel to get stability for the yaw movement.
Although I don't think this will be very difficult, It can take me a few months because I have very little spare time. If I can get the electronic part to work fine, I'll buy the motors and build the rest of the structure.
