tiggerinmk
Joined: 12/30/2002 From: Milton Keynes, UNITED KINGDOM Status: offline
I bought a pair of H9 Z bend pliers and thought the same way at first, but now I hardly use them. Some wire supplied with ARF's can be brittle and splits if you try to bend it with the pliers, so now I only use the pliers with the thinner more flexible throttle wire.
_____________________________
If you can remain calm, while all around you is chaos... then you probably haven't completely understood the seriousnes
