A Glassing Question...?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Tips & Techniques >> A Glassing Question...? Page: [1] 2   next >   >>
Login
A Glassing Question...? - 1/26/2004 8:37:01 PM
Boss248
Status: offline
I want to use 3/4 oz. cloth on a fuse that is solid balsa(no bays) and I remember reading somewhere in RCU where someone used something other than finishing epoxy. I seem to recall they used water based acrylic polyurethane from a can and brushed it on.
I want something that is easy to apply with no or little sanding needed after the cloth/resin has set up. Also I have been trying some different spray paints that I can buy locally but I keep seeing Rusto-leum's name pop up. Can someone that knows FOR SURE please tell me what paint they have found that is fuel proof. I know I can go the PPG route but I have to buy a pint at a time @ $30.00 a pint. I guess I can do the base painting with Rust-oleum or Krylon and get a pint of PPG clear which the paint shop can load into spray cans but I am open to other ideas.
Boss
       Post #: 1
RE: A Glassing Question...? - 1/26/2004 8:51:23 PM
barto
Status: offline
Cafeen is the man to answer your questions
This is his site www.airfieldmodels.com
(in reply to Boss248)
       Post #: 2
RE: A Glassing Question...? - 1/26/2004 11:03:30 PM
HuskerBoy
Status: offline
All the epoxy enamels are fuel proof and I've used Krylon lacquers too.
I'm not a fan of the Rustoleum since it is oil based and it's best to stay with their top colors.
_____________________________
Randy
AMA# 56432
(in reply to barto)
       Post #: 3
RE: A Glassing Question...? - 1/27/2004 1:45:20 AM
Azcat59
Status: offline
One of the easiest ways to stick the light glass to your fuselage is nitrate airplane dope. Sig sells it, and there are other sources. Two coats on the raw wood, few hours apart, light sanding, drape the cloth over part of the fuselage, and apply the dope on top the cloth. It will soak right on through. Give it several coats of dope, very little sanding required, preferably no more than two coats a day. Then give the whole thing three days to chemically cure before you put anything else on.
Follow it up with the grey Rustoleum primer out of the spray can. It sands easily, and is fuel proof. I even use it for the grey color on the bottom of WW II warbirds, but spray on a light coat of Varathane satin finish poly-U to harden the primer slightly and protect any ink lines.
The Rustoleum colors in the spray cans are likewise fuel proof, at least with 10-15% nitro fuel, but I wouldn't pour raw fuel on them and leave it.
Clair
AMA 15654
(in reply to HuskerBoy)
       Post #: 4
RE: A Glassing Question...? - 1/27/2004 6:01:07 AM
FHHuber
Status: offline
You want to avoid the epoxy and/or poly resin... and still want a strengthening layer of cloth to aid in smoothing the aricraft... how about silk and yellow glue
Easy to sand.
LIGHT.
strong.
Inexpensive!
And you mix some yellow glue with talc and water for a fillercoat before your first fuelproofing/coloring coats, for a cheap, easy to sand light filler.
(based on tricks used in the 1930's using white glue. Yellow glue is superior to white for just about everything.)
The use of Nitrate Dope... similar, but more expensive. And you have to deal with the toxic base of the Dope. (which is flamable and smells like nail polish remover) And Dope NEVER stops cureing and never stops shrinking. Yellow glue stops shrinking in 24 hrs. any paint other than a laquer over Dope will eventually crack.
(in reply to Azcat59)
       Post #: 5
RE: A Glassing Question...? - 1/28/2004 12:35:54 AM
Boss248
Status: offline
Does anyone else have any ideas or know about the use of water based poly urethane to go over 3/4 oz. cloth???????
Thanks for all the suggestions guys....
Boss248
Editorial Member
(in reply to FHHuber)
       Post #: 6
RE: A Glassing Question...? - 1/28/2004 1:48:22 AM
CafeenMan
Status: offline
Why does it have to be water-based polyurethane? No matter what you use to apply the cloth, you're going to have to do the same amount of sanding after it dries. There actually isn't much sanding to do if you put the resin or poly on properly.
Work is what I do for the love of it. A job is how I pay for it. :)
Please visit AirfieldModels.com
       Post #: 7
RE: A Glassing Question...? - 1/28/2004 7:41:33 AM
Boss248
Status: offline
Cafeenman...don't get me wrong...I have always used the method you described but I am only looking for an alternative. I have used the dope method and the white glue method all with success but I want to stay open to other ideas.
Boss248
Editorial Member
(in reply to CafeenMan)
       Post #: 8
RE: A Glassing Question...? - 1/28/2004 12:10:45 PM
grahamd1
Status: offline
I think the product your thinking of is Minwax, here in the UK it is no longer available (European rules), so a UK company mixed up an alternative, and added some extras. However its almost the same stuff.
Heres a link to a short article on how to apply it.
http://www.rcworld.co.uk/polyc.htm
I've been using the stuff for almost a year now on several differnt types of model, from all foam to scale WWII warbirds, and would need to be forced to go back to Epoxy. For smaller models (<70" I have now switched to using Tissue paper (shoes come wrapped in the stuff), as this only requires about 3~4 coats, and sanding can be done in minutes with little effort to achieve a very hard smooth finish.
       Post #: 9
RE: A Glassing Question...? - 1/28/2004 1:45:00 PM
Boss248
Status: offline
Thanks Graham...that is the info I was looking for.
Ha ...the 3Styla is not looking to bad either. I have not seen it in ads here in the USA but I guess there are hundreds like it all over the globe.
Boss248
Editorial Member
(in reply to grahamd1)
       Post #: 10
RE: A Glassing Question...? - 1/28/2004 2:31:00 PM
grahamd1
Status: offline
Your welcome, the tail in the pictures is from my BF-109.
       Post #: 11
RE: A Glassing Question...? - 2/1/2004 4:07:36 PM
ZeppelinIII
Status: offline
I have done a couple of models using water-based polyurethane to put down 0.5 oz cloth (0.75 is basically the same)...to answer one question, the reason to use a water-based poly is for clean up, you can just rinse out your brush with water. As to the process, my opinion as too the best approach is to put on a light coat to get the glass down, and it'll take a few different pieces, so do all of them first with a single coat, then add a second light coat once the entire fuse/stab/wing/etc. (whatever you're working on) is done, then add a final coat of polyurethane mixed with corn starch....I prefer to add a heavier coat of that, and then sand more (to help even everything out, but if you put a very light coat of that on you could probably get away with very little sanding....
pic is best example I could find off hand, using that approach on the fuse of a sig Kavelier...
Click to see fullsize image.
Click for fullsize
       Post #: 12
RE: A Glassing Question...? - 2/1/2004 5:37:35 PM
Boss248
Status: offline
Zepp...what do you use for the final color???....I did a test piece and it looks like it will work well but I was wondering about the Corn Starch...is that working as a filler to make sanding and filling of the grain.
I need to know what people are using as a final color or clear coat that is really fuel proof.
Boss248
Editorial Member
(in reply to ZeppelinIII)
       Post #: 13
RE: A Glassing Question...? - 2/1/2004 8:11:54 PM
3dd
Status: offline
the only problem with water based products is the real chance that it will warp balsa planking even after it is glued down.solvent based sanding sealers will work better and will not warp anything.they do stink but the finished plane will be lite and have a good finish
       Post #: 14
RE: A Glassing Question...? - 2/1/2004 9:56:31 PM
Boss248
Status: offline
You have a point...I did notice a warp because I was painting it over 1/16
