GWS corsair CG question
Tower Hobbies
Logged in as Guest
  Printable Version
BVM Super Bandit - ARF
Seller:  Wahkit
Details:   $10,000.00   |  12/1/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> GWS corsair CG question
Page: [1]
Login
GWS corsair CG question - 1/27/2004 1:07:14 AM
abearcat
Status: offline
I have a GWS corsair with the stock 350 motor. I have read that the CG should be set forward of the recommended value. What is the best CG point from the leading edge of the wing for STABLE flight. I just want the best chance of flying the thing around until I get used to it then I may try to change things since I am not that experienced and do not have access to skilled flyers to teach me. I would appreciate any input on this. Thank you.
       Post #: 1
RE: GWS corsair CG question - 1/27/2004 1:20:39 AM
HuskerBoy
Status: offline
You need to place this in the Electric Forum to get better response.
I've got the Zero and don't use the package 6 or 7 cell battery pack that comes with the GWS flight pack. I fly with an 8 cell pack of AAA 720Mahr NiMh and NO rudder. Keep as light as possible and the best power boost for ease of flying. The 6 and 7 cell nicads will give barely enough power for flight. If the Corsair is like the Zero with a bamboo chop stick under the wing, then the cg should be about 1/8 or 3/16" in front of the stick. Make sure the prop has the size stamping facing out -- too many pilots said "it won't fly" and they had the prop on backwards.
< Message edited by rreiss -- 1/27/2004 10:49:47 AM >
_____________________________
Randy
AMA# 56432
(in reply to abearcat)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.344RCU2
