Supernova NIMH Results
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Supernova NIMH Results
Page: [1]
Login
Supernova NIMH Results - 5/29/2002 10:15:55 AM
Jerkey
Status: offline
I have had a FMA SuperNova for about a year give or take a few months. I have been hearing the negativity about the SuperNova's inability to detect NIMH battery peak. So I borrowed a buddies brand new NIMH since I only use NICD"S. Here are the results I got. First the battery is a 1200mah 4 double A cell. I set the charger up manual for NIMH. Charge was set at 1.2A and Discharge was set at 1.0A. It discharged 130 mah in 7 minutes 43 seconds and charged 458mah in 22 minutes 7 seconds. Now I see why SuperNova owners are complaining.
Mike
       Post #: 1
NiNH on Supernova - 5/29/2002 5:32:39 PM
dant-RCU
Status: offline
Jerkey:
Not sure what is happening here. I have a Supernova and now use only NiMH batteries. I have not experienced any problems at all. I do not use the Supernova to discharge I use an Einstien for that and I do believe the Einstien discharges at a less than 1.0A but I don't see that making any difference. I don't have a real reason to "fast discharge" and since I have the Einstien I use that as I can just plug it into a wall socket. I only discharge my packs twice a year to check capacity anyhow (January and June/July) and I follow the "4 years or 80% rule".
I do know that all of the battery clinics that I have read regarding packs (NiMh and NiCad) all state that you MUST fully charge a new pack using the overnight charge rate before any reliable discharge/fast charge data can be obtained. Dave Thacker at Radical RC has an excellent discourse on NiMH batteries. Since you have a "brand new pack" you might want to do the full overnight charge (full being 15-16 hours) then do the cycle/charge on the Supernova.
All of my NiMH packs (Tx and Rx) are 1200 - 1450 Mah. As I stated, I just have not seen a problem with my setup. Then again, maybe there is something that I just am not aware of but this has been my experience.
Dan
edit starts here:
You might also want to send an e-mail to FMA direct. Fred and Tim have been very good about answering questions regarding their products.
< Message edited by dant-RCU -- May 29 2002 12:41PM >
_____________________________
Dan Taylor
American Turf Flyers, Inc.
(in reply to Jerkey)
       Post #: 2
nimh - 5/29/2002 5:44:21 PM
RC Accessory
Status: online
Charge the numh pack for 18-20 hours at a C/10 charge. Once done, then cycle the pack, then charge on the Super Nova.
Your results will be much better, but I doubt if it will put all the capacity back in the pack. What you experienced is whu nimh packs need to be cycled first. If that pack was in a plane or heli, 2nd flight it would have died. That is exactly what happened to friend of mine.
Let us know your results.
       Post #: 3
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.313RCU1
