Darrinc
OH, USA Status: offline
Finishing resin is fine, but if you are going to do more layups then get some good laminating resin. Sounds like you are using a male mold, you must like to do bodywork and add weight. If the male mold is done, then wax it and pull a female tool off of it, then you get a perfect part everytime. I would use 2 layers of 2oz glass on 45° since this is a 56" plane and will need to be as lite as possible. (it will be stronger than you think) Wett out the mold then lay in the glass, take a stiff brush and push straight down repeatively on the glass to wett out. Place the second layer and wett out with the brush, then take a paper towel and dab out all the resin you can. Excess resin = weak part If you do one layer at a time then you must take a lot of time to sand between layers. (remove all the shine!!!) You should not have to glass the wing, it only adds weight.
_____________________________
"Make everything like your going to make the front page of NASA Tech Briefs" Go Team Orange! Darrin R Cash
