Hot Rod Todd
IA, USA Status: offline
Dai Phan, I know your using electric power, but make sure you have plenty of Power. I used to have a Magnum .91 four stroke in mine. I had to run it rich to keep it cool, but it would swing a 14X6 wood zinger at 8500 RPM. It was weak, and I didn't like it. Now I have a YS 1.10 in the plane, which will pull a 15X6 over 10000 RPM, and the plane is much easier to fly. I can cruise around at half throttle, and give it a bit more when I need it in the turns. Mine is a bit heavy with the speaker system, but with a full cockpit and scale details yours might not be too light either.
