RE: Albatros D.III Build along
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Albatros D.III - 91
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: Albatros D.III Build along
    Page: <<   < prev  1 [2] 3 4 5 6 7 8 9 10   next >   >>
    Login
    RE: Albatros D.III Build along - 2/16/2004 3:20:55 PM
    BobH
    Status: offline
    J, you can use minwax or deft poly clear over ply veneer and it looks great. This is what I used on the interior portion of my SE5a. Hopefully you can see the results in this photograph. I must admit that the minwax poly was extreemly easy to work with. Im not sure on the nitro effect thought. I have read that Deft is about 6x's more durable. I'm going to find out because I have a Proctor Albi comming and I want to have a clear wood fuse.
    Click to see fullsize image.
    Click for fullsize
    (in reply to jharkin)
           Post #: 26
    RE: Albatros D.III Build along - 2/20/2004 10:20:12 PM
    jharkin
    Status: offline
    SOme more images of the lower wing build...
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
    (in reply to BobH)
           Post #: 27
    RE: Albatros D.III Build along - 2/20/2004 10:21:06 PM
    jharkin
    Status: offline
    The rest of the lower wing sequence
    Click for fullsize
    Click for fullsize
    Click for fullsize
           Post #: 28
    RE: Albatros D.III Build along - 2/21/2004 1:43:20 AM
    BobH
    Status: offline
    Boy, that sure looks like its building fast. Im sure its going to be really nice when finished... !
           Post #: 29
    RE: Albatros D.III Build along - 3/18/2004 1:30:51 PM
    jharkin
    Status: offline
    So you dont think I've stopped building...
    This is where I am at right now. Most of the framing is done, time to start the hard parts (controls,
    sheeting, detailing)
    *Warning* My ugly mug is in the photos. *Warning*
    Click for fullsize
    Click for fullsize
    (in reply to BobH)
           Post #: 30
    RE: Albatros D.III Build along - 3/19/2004 1:16:14 AM
    BobH
    Status: offline
    Boy, that frames pretty fast huh?.. looks like it would be a nice flier! Can't wait to start on my proctor albi.. not for a while tho.
    < Message edited by BobH -- 3/19/2004 1:16:42 AM >
           Post #: 31
    RE: Albatros D.III Build along - 3/19/2004 5:35:14 PM
    jharkin
    Status: offline
    quote:
    ORIGINAL: BobH
    Yes it is coming along fast. However I think progress is going to slow down as I am now into the more time consuming areas - fuse sheeting, detailing, etc. Im still hoping to have it ready for the New England Scale Masters at the end of June but that might be tight if I dont pick up the pace.
    Oh and what I wouldnt give to do a Proctor or Torrance kit... I think I need some more experience and a bigger car first though.
    -Jeremy
    (in reply to BobH)
           Post #: 32
    RE: Albatros D.III Build along - 3/19/2004 11:11:55 PM
    BobH
    Status: offline
    Jeremy, good luck making your deadline. I'm hoping to finish my se5a for the ny scale masters n august! And i think you have sufficient experience for either the proctor or GTM.. those are easier to build than you might think.
           Post #: 33
    RE: Albatros D.III Build along - 5/9/2004 3:35:24 AM
    BobH
    Status: offline
    J. hows the Albatross build comming? I haven't seen a post in some time and I was just wondering how you were doing. Thanks BobH.
           Post #: 34
    RE: Albatros D.III Build along - 5/9/2004 11:37:49 PM
    Feuerwehr
    Status: offline
    I'm also anxious to see how Jeremy is coming along with his albatros. His posts inspired me to go out and order a DIII myself! I started building early last month and am very pleased with kit quality, and how well the laser cut parts fit.
    Like Jeremy I was not sure how to proceed with the wood grain fuselage. I decided against using real plywood after some trial and error practice with scrap 1/32. I reluctantly decided I don't have the requisite skill and patience to do a credible job. (If I could afford a proctor DV maybe I would try a little harder!}
    After looking around for alternatives I decided to go ahead and cover with super coverite then dry brush with minwax honey maple gel stain on top of a coat of rust-oleum almond spray paint over primer. Everything is sealed with minwax clear satin polyurethane. I bench tested this combination and it seems to provide a passable wood grain appearance, although obviously not as nice as real plywood. The photos below show the vertical stabilizer with the "fake" wood grain.
    These are a few "bare bones" fotos. I also did some minor mods to the tail section to provide rudder and horizontal stab "ribs". The aircraft will be finished to simulate one of Ernst Udet's DIII's.
    http://wwi-cookup.com/albatros/diii/Albatros_DIII213216.jpg
    Click for fullsize
    Click for fullsize
    Click for fullsize
    < Message edited by Feuerwehr -- 5/9/2004 11:54:07 PM >
    (in reply to BobH)
           Post #: 35
    RE: Albatros D.III Build along - 5/10/2004 4:26:14 AM
    BobH
    Status: offline
    Your albi looks very goood from the pictures. I think your attempt at a "wood" finish will be fine. Tom Polapink did a rendition of the fake wood using paint kinda like you did and it looked very good. There was a write up about it in one of the issues of RCSI.. Keep us posted of your progress please!!
    < Message edited by BobH -- 5/10/2004 4:27:52 AM >
    (in reply to Feuerwehr)
           Post #: 36
    RE: Albatros D.III Build along - 5/10/2004 2:24:20 PM
    jharkin
    Status: offline
    Hi Bob-
    Im still here. The Albatros has been on hold for a while, unfortunately work priorities have suddenly changed and I now find myself with a lot less time - not to mention that weekends are now spent flying . Right now Ive switched to finishing a sport plane that I was close to covering and taking a bit of a break before I tackle that fuselage sheeting. I hope to be back on track working on it by June and may plan on first flights in the fall. (I work slow)
    I do have more pics... just have to egt around to posting them
    Feuerwehr, Im impressed. 2 months and you look ahead of me - very nice bird. I'll be interested to see how your fuse comes out. I actually did the plywood sheeting on the fin with 1/64 (came out nice) but the fuse is going to be a bear.
    (in reply to BobH)
           Post #: 37
    RE: Albatros D.III Build along - 5/10/2004 2:37:21 PM
    Hot Rod Todd
    Status: offline
    Looks good! I was thinking of doing mine in what I believe to be the same scheme. I don't think I'll get around to building it until this winter though.
    I'll attempt to post the photo.
    Click for fullsize
           Post #: 38
