Hot Rod Todd
IA, USA Status: offline
Sorry, I meant ailerons, not elevons. You mix some rudder into your ailerons to help minimize some of the adverse yaw caused by the flatbottom airfoil and the ailerons being only on the top wing. It makes the plane handle quite a bit better. Of course you could use rudder yourself without the mix, but it is a bit harder. I found that adding some rudder mix makes the plane fly much more like a normal RC aircraft, where if you use no mix the adverse yaw almost requires rudder to make smooth turns.
