thunder21
MD, USA Status: offline
I'm going to leave it as a DIII. The model is so far out of scale that using an incorrect, or unverified, color scheme doesn't bother me a bit. I had to modify the tail skid to match up with the proper OAW outline from the kit and it looks good to me. I'm going to finish the wood only with polyurethane. I'm not going to attempt to duplicate the paneling. With my painting skills, it would just turn out looking horrible anyways. The sheeting was applied in close to scale sections so when the tinting and clear finish is applied it should look acceptable. I'm going to make my own stencils for the crosses. I scanned them in from a book on Albatros fighters. I'll print them out on printer paper, trace them onto the surface and then paint them by hand. I hope to be flying at around 11 lbs. That may be a bit optimistic. Since I'm using a very light finishing method on the tail, I hope to not have to add a lot of weight to the nose to get to balance. I did a preliminary balance as the model is now and it is slightly nose heavy, and that's without the prop. Even if I have to add a pound of weight to the nose to balance, the model has a lot of wing area and the power should still be greater than scale.
