RE: Albatros D.III Build along
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Albatros D.III - 91
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: Albatros D.III Build along
    Page: <<   < prev  25 26 27 28 29 30 31 32 33 [34]
    Login
    RE: Albatros D.III Build... - 4/29/2008 2:15:28 PM
    Dai Phan
    Status: offline
    quote:
    ORIGINAL: thunder21
    Here's a shot of the radiator I made. It's made out of styrene sheet, balsa and aluminum tape.
    Hello,
    I really like your engine exhaust. Did you carve out of balsa? DP
    (in reply to thunder21)
           Post #: 826
    RE: Albatros D.III Build... - 4/30/2008 4:02:35 AM
    thunder21
    Status: online
    Thanks. I did carve it out of balsa. Here's a picture.
    Click to see fullsize image.
    Click for fullsize
    (in reply to Dai Phan)
           Post #: 827
    RE: Albatros D.III Build... - 5/1/2008 6:12:57 AM
    thunder21
    Status: online
    I received the leather for the cockpit coaming today. I glued it to 1/4" neoprene coaming and folded an edge on the outside. Then I stitched the edge together. I glued it on the model with canopy glue and a little CA to hold the edges down. I'm pleased with the result-)
    Click for fullsize
    Click for fullsize
           Post #: 828
    RE: Albatros D.III Build... - 5/4/2008 3:48:39 AM
    thunder21
    Status: online
    I took the DIII to the field today to do a range check, check the power system and do some taxi runs. But the winds were 90 degrees to the runway and too gusty for my taste. But I did get the power sytem checked out. It spins the 16x10 prop at 6500 RPM for 1167 Watts. A bit much for a 10 lb biplane so I'll probably go for an 8 pitch prop.
    Click for fullsize
    Click for fullsize
           Post #: 829
    RE: Albatros D.III Build... - 5/11/2008 6:48:40 AM
    thunder21
    Status: online
    I had the maiden flight of my Albators today. The model flys terrific. I switched to a 16x8 prop which lowered the amp draw to about 35 with a max RPM of 6400. Total watts are about 750. The model took off and needed a few clicks of aileron trim. No elevator trim was required. The model flew well at half throttle. Full throttle didn't add a whole lot of speed but helped for loops. Here is the maiden flight video:
    http://www.glue.umd.edu/~markt/Albatros_DIII-Maiden.mov
           Post #: 830
    RE: Albatros D.III Build... - 5/26/2008 4:36:00 AM
    thunder21
    Status: online
    Here are a couple more videos. Is anyone else flying their Albatros still? I'm totally loving this model. It is a blast to fly.
    http://www.glue.umd.edu/~markt/Albatros_DIII-1.MOV
    http://www.glue.umd.edu/~markt/Albatros_DIII-2.wmv
           Post #: 831
    RE: Albatros D.III Buil... - 5/28/2008 6:20:10 PM
    joesigg
    Status: offline
    Where did you get the leather for the cockpit coaming?
           Post #: 832
    RE: Albatros D.III Buil... - 5/28/2008 7:00:04 PM
    Hot Rod Todd
    Status: offline
    On mine I just used fuel tubing, then painted it to look like leather. I also carved the exhaust megaphone out of balsa.
    Click for fullsize
    Click for fullsize
    (in reply to joesigg)
           Post #: 833
    RE: Albatros D.III Buil... - 5/28/2008 7:51:40 PM
    Hot Rod Todd
    Status: offline
    Here's a nice photo of actual coaming if you are interested.
    Click for fullsize
    (in reply to Hot Rod Todd)
           Post #: 834
    RE: Albatros D.III Buil... - 5/29/2008 4:07:28 AM
    thunder21
    Status: online
    http://www.tandyleatherfactory.com/products.asp?dept=287
    quote:
    ORIGINAL: joesigg
           Post #: 835
    RE: Albatros D.III Buil... - 7/21/2008 6:30:32 AM
    thunder21
    Status: online
    Here is a video taken onboard my Albatros today.
    http://www.glue.umd.edu/~markt/Albatros_Onboard.wmv
           Post #: 836
    RE: Albatros D.III Buil... - 7/21/2008 1:57:30 PM
    caribefoto
    Status: offline
    Hot Rod Tod, The picture you posted recently is, I believe, cropped from a photo of Uffz Paul Beaumer seated in his colorful "Edelweiss" Albatross D V. Do you have a copy of the full frame photograph? ................John
    _____________________________
    Well, if crime fighters fight crime and fire fighters fight fire, what do freedom fighters fight?
           Post #: 837
    RE: Albatros D.III Buil... - 7/21/2008 2:05:33 PM
    Hot Rod Todd
    Status: offline
    Sorry, It was a photo I found on the web someplace. I don't have a full copy.
    (in reply to caribefoto)
           Post #: 838
    RE: Albatros D.III Buil... - 7/21/2008 2:24:07 PM
    Dai Phan
    Status: offline
    quote:
    ORIGINAL: caribefoto
    I think that is HR in his early career days. My Albatross is in the color scheme you mentioned. DP
