RE: Albatros D.III Build along
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Albatros D.III - 91
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: Albatros D.III Build along
    Page: <<   < prev  2 3 [4] 5 6 7 8 9 10 11   next >   >>
    Login
    RE: Albatros D.III Build along - 10/22/2004 3:05:27 AM
    bent
    Status: offline
    Here's a dandy link that shows exactly how the Spandaus mount in an Albatros.
    http://wwi-cookup.com/albatros/modelling_hints/profiles_markmiller_spandau.html
    (in reply to flipstart)
           Post #: 76
    RE: Albatros D.III Build along - 10/23/2004 12:32:26 PM
    Rayvyn
    Status: offline
    I just ordered mine the other day and have since been pondering the engine I will use. In speaking with the owner of Funaero he mentioned that while any of the 90 4 strokes would be good, he was sure that the OS 91 was a good fit being that they made a muffler adapter to keep the exhaust in the cowl. In looking around however, I have also seen that many people offer at least some way of doing this so I am a bit unclear as to what drives people to get the different engines... I would first be very interested to hear why some chose the Saito 91 or 100 and extremely interested in hearing from anyone that might have used a YS 91 (fit with supercharge airbox) or the OS 91P (with internal fuel pump)... In the end I realize many will be overpowered but I have needed some reserve power from time to time to get out of trouble and if nothing else, it is a comfort to have... I mostly want reliability to keep it in the air but with all the engines out there, certainly could use some words of wisdom from those of you with experience who know...
    (in reply to bent)
           Post #: 77
    RE: Albatros D.III Build along - 10/24/2004 3:46:33 AM
    flipstart
    Status: offline
    I chose the Saito 91-Saito because of quality-figured any company that only built 4 strokes has to be on the cutting edge to survive-talked to Mike at Funaero and 91 is more than enough power, scale flying at 1/2 throttle, takeoff at 2/3 throttle. Built a in cowl straight pipe for muffler, really has a neat sound and not that much louder, not that stopped up tone that you get with muffler-cut stock nipple in half, brazed 90 degree copper fitting to nipple, and brass pipe out bottom of cowl.
    Would not be too hard to just run brass pipe up and out by mock engine just like the original, but wanted to keep fuel and oil off plane. You will enjoy building the kit - it is top notch. Just a few little glitches between drawings and instructions but parts fit is great. Flipstart
    _____________________________
    REAL AIRPLANES HAVE MACHINE GUNS
    (in reply to Rayvyn)
           Post #: 78
    RE: Albatros D.III Build along - 10/25/2004 2:38:11 AM
    Mustang Fever
    Status: offline
    Nice job on your Alby. I've got my fuse basically done. Using an OS 65 LA with a Pitts muffler. Got a big hole in the side of the cowl for the air to go in, and a bigger one in the bottom for it to go out, hopefully.
    Nice kit. Very high quality wood and laser cutting.
    Click to see fullsize image.
    Click for fullsize
    (in reply to jharkin)
           Post #: 79
    RE: Albatros D.III Build along - 10/25/2004 3:23:31 AM
    FokkerDVII
    Status: offline
    Flipstart, an excellent source for information on the Albatros DIII is from the "Wise Owl Worldwide Publications" Windsock Datafile #19 www.WiseOwlMagazine.com (310) 944-9963 Mike FunAero R/C
    (in reply to Mustang Fever)
           Post #: 80
    RE: Albatros D.III Build along - 10/25/2004 3:28:10 AM
    FokkerDVII
    Status: offline
    OOps, correction on the web site for Wis Owl Publications www.WiseOwlMagazines.com Mike
    (in reply to FokkerDVII)
           Post #: 81
    RE: Albatros D.III Build along - 10/25/2004 10:31:57 AM
    Rayvyn
    Status: offline
    sfcbhunt@hotmail.com is that a fiberglass cowl in that picture or are my eyes playing tricks on me?
           Post #: 82
    RE: Albatros D.III Build along - 11/1/2004 1:31:22 AM
    Mustang Fever
    Status: offline
    Yup. That's the glass cowl from Precision Fiberglass. Fits perfectly.
    Click for fullsize
           Post #: 83
    RE: Albatros D.III Build along - 11/1/2004 2:44:57 PM
    Rayvyn
    Status: offline
    What prop are you guys using for this model with the 91 4 stroke?
           Post #: 84
    RE: Albatros D.III Build along - 11/8/2004 1:07:48 AM
    pjwright
    Status: offline
    Any thoughts out there of converting the DIII to a W4 Seaplane? Same airframe as the DIII, but on floats, I believe I read in the Datafile...
    Also, someone further back in the thread was looking for a 1/4 scale D-Va? You can get a full kit (Pepino plans) for $260 from Kit Cutters [ http://www.kitcutters.com/Pep/PepD5AAlbatross.htm ], or a short kit (as I recall) from Bob Holman at www.bhplans.com.
    Regards...
    pj
           Post #: 85
    RE: Albatros D.III Build along - 11/8/2004 1:15:23 PM
    Hot Rod Todd
    Status: offline
    I believe the Float plane version has the DII wing, lacking the DIII's sesquiplane construction (not that many would know the difference). If you knew you were making it from the start, you could order the DII kit instead of the DIII. I have not started on my Albatros yet, but I'm thinking a 14X6 prop will work fine with a .91 four stroke. Wood of course for that somewhat scale look.
    (in reply to pjwright)
           Post #: 86
    RE: Albatros D.III Build along - 11/18/2004 9:48:38 PM
    Prop Nut
    Status: offline
    Feuerwehr
    I own a small cabinet shop, we do alot of clear coating on Baltic and chineese birch. Your faux wood paint job is very very near perfect to the thin birch veneers we use. Wow. I am impressed. Ok, my two cents worth, gotta go order that kit now. Sheesh, more money not going to my daughters college fund. Maybe I will get lucky and she will drop out of school. Just think of all the RC stuff I can spend her college fund on, Muahaha!
    Scope? Listerine? Or Prop Wash?
    (in reply to Hot Rod Todd)
           Post #: 87
    RE: Albatros D.III Build along - 11/19/2004 2:14:27 PM
    jharkin
    Status: offline
    Wow, my thread seems to have taken on a life of its own!
    Unfortunately my Albatros is still not done... "Life got in the way" as they would say and I had to put the project aside for a year. Now I've got the time to finish it though, and seeing that others have built and flown theirs in the meantime I've got some work to do!!! Great looking planes guys.
    Jeremy
    (in reply to Prop Nut)
           Post #: 88
    RE: Albatros D.III Build along - 11/19/2004 4:47:09 PM
    Dai Phan
    Status: offline
    To JHarkin,
    I am into scale planes but has no time to build. If I provide you the kit, could you build it into ARC for me? Very handsome but reasonable compensation will be offered. Call me at 505-459-7520 if you are or anybody interested. Please, professional builders please. Thanks.
           Post #: 89
