RE: Albatros D.III Build along
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
Albatros D.III - 91
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> RC Scale Aircraft >> RE: Albatros D.III Build along
    Page: <<   < prev  3 4 [5] 6 7 8 9 10 11 12   next >   >>
    Login
    RE: Albatros D.III Build along - 1/11/2005 3:47:35 PM
    Hot Rod Todd
    Status: offline
    Thought you'd like to see the tail skid, functions like the full size one.
    Click to see fullsize image.
    Click for fullsize
    (in reply to Hot Rod Todd)
           Post #: 101
    RE: Albatros D.III Build along - 1/11/2005 4:46:35 PM
    silvercloud-RCU
    Status: offline
    Hot rod Todd, will the magnet from the speaker effect the servo motor being that close to each other and where did you find the corrugated plastic for the radiator. Nice work !
    _____________________________
    What goes up must come down softly I hope
           Post #: 102
    RE: Albatros D.III Build along - 1/11/2005 5:19:07 PM
    Hot Rod Todd
    Status: offline
    I doubt that the magnet will bother the servos, but I will test them and shield them if neccessary. My local hobby shop has plastic made for making scale buildings for train sets. One of the plastics looked about right, and worked well.
    (in reply to silvercloud-RCU)
           Post #: 103
    RE: Albatros D.III Build along - 1/11/2005 5:20:02 PM
    Dai Phan
    Status: offline
    Hello,
    I am thinking about building the Albatross DIII. I have build about 15 kits and I would like to know approximately how long it takes to get to ARC assuming I work about 5 hours daily.
    Thank you. Dai Phan
           Post #: 104
    RE: Albatros D.III Build along - 1/13/2005 1:14:20 PM
    Hot Rod Todd
    Status: offline
    Dai Phan, I just got done building the plane, but I don't really know how much time was spent. It goes together fairly easily, so I would guess that you could get to the ARC step in 5 or 6 five hour days. In my case, there was much more work to be done after that. ARC is not near halfway to complete.
    (in reply to Dai Phan)
           Post #: 105
    RE: Albatros D.III Build along - 1/13/2005 3:42:56 PM
    Dai Phan
    Status: offline
    HRT,
    Your plane LOOKS AWESOME !!!! I am a WWI fan and I have a nice fleet of WWI birds. The Albatross is one that I love so I think I probably will order one. Have you flown it yet? I have posted a thread on my O-1 Bird Dog so you may want to take a look. It is on ARF forum.
    Dai Phan
           Post #: 106
    RE: Albatros D.III Build along - 1/13/2005 5:07:08 PM
    Hot Rod Todd
    Status: offline
    I won't be flying it until spring (below zero in Iowa right now). I'm getting the radio equipment and electronics stuffed into the plane now. Here's a photo showing the general paint scheme. It is a plane passed from Manfred to Lothar Richthofen, early 1917. I still have some details to put in yet, but I have all winter to do it.
    Click for fullsize
           Post #: 107
    RE: Albatros D.III Build along - 1/13/2005 10:03:02 PM
    brady_vv
    Status: offline
    Todd,
    Your Albatross looks fantastic! You have come along ways since the last build session in December. Can't wait to see it fly this spring.
    Brady
           Post #: 108
    RE: Albatros D.III Build along - 1/19/2005 4:15:03 PM
    Dai Phan
    Status: offline
    Hello HRT,
    Looks awesome !!! Good luck in flying it ! Dai Phan
    (in reply to brady_vv)
           Post #: 109
    RE: Albatros D.III Build along - 1/21/2005 2:29:26 PM
    flipstart
    Status: offline
    Hey Hot Rod-meant to ask- what type of hinges did you use on your Alba-I used robart 3/16" installed at an angle from the top-they seem to stick up slightly and show more than yours-maybe I did not get them recessed enough. Nice job on your albatross. Also mine came out tail heavy-had to add about 1# of lead under cowl to balance. Flipstart
    REAL AIRPLANES HAVE MACHINE GUNS
           Post #: 110
    RE: Albatros D.III Build along - 1/21/2005 3:49:13 PM
    Hot Rod Todd
    Status: offline
    I used the white dubro pinned hinges and glued them in with Gorilla Glue. Seems like they will work fine. I don't think this plane will put too much stress on the hinges, so I was looking for something that would look good. As I was building the plane, I knew I would be needing to get the CG up front. The Receiver battery is on the firewall, and the two 9V batteries that power the machine gun sound and light are under the forward landing gear cover. It looks like I made still need to add some weight for the maiden. I hope I don't need much, since the electronics, speaker, and batteries for the sound system weigh almost a pound. Still some details to add, but here is a photo of the plane on my dining room table.
    Click for fullsize
    (in reply to flipstart)
           Post #: 111
    RE: Albatros D.III Build along - 1/21/2005 4:03:45 PM
    Hot Rod Todd
    Status: offline
    For anyone building this plane, I thought I'd post some graphics I have found through research. There are two albatros logos as found on the rudder of DIII's as they came from the factory. I'm not sure if the logo was color or just black, so I posted both that I have found. Also there is a Garuda prop logo, which should be fairly accurate if printed on white decal paper and cut out. Fourth photo is a view of my scale radiator, mounted in the center as it would be on early model DIII's.
    Click for fullsize
    Click for fullsize
    Click for fullsize
    Click for fullsize
           Post #: 112
    RE: Albatros D.III Build along - 1/22/2005 5:24:21 PM
    flipstart
    Status: offline
    Hot Rod-that really is a nice lookin' Albatros-nice job-I have redundant battery power with 2 batteries up next to the firewall and still had to add a little over 1# of lead to mine to balance. If it flys ok-may try the machine gun sound system if you think it works ok-can you hear it from the air. flip
           Post #: 113
    RE: Albatros D.III Build along - 1/22/2005 5:45:07 PM
    abufletcher
    Status: offline
    Man oh man does that look nice! I'm thinking of doing a Pfalz DIIIa as a serious scale project and this Funaero DIII might make an excellent "practice plane." Expecially since I don't have much experience with RC model construction. Thanks also for the graphics. They'
