Plwood insert
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Pylon Universe - RC Pylon Racing >> Q-500 Racing >> Plwood insert
Page: <<   < prev  1 [2]
Login
Plwood insert - 2/20/2004 5:41:02 PM
Stand
Status: offline
I think he is not getting that you are inserting a 1/64" strip of plywood strip around the perimeter of the tail in a slot made with your razor saw blade.
Or maybe I've got it wrong because that's what I do.
Stan D.
(in reply to daven)
       Post #: 26
RE: Plwood insert - 2/20/2004 6:06:41 PM
bl10
Status: offline
Guys:
I believe PER is asking how you lay out the 1/64 ply edging so it fits correctly in the slot. As for me I just draw around the tail and cut it with scissors.
Barry
(in reply to Stand)
       Post #: 27
RE: Plwood insert - 7/28/2004 11:54:28 AM
Per_N
Status: offline
quote:
ORIGINAL: bl10
Guys:
Barry
Barry, exactly what meant.
_____________________________
Per
Sweden
(in reply to bl10)
       Post #: 28
RE: Plwood insert - 7/30/2004 1:03:34 AM
Shackas
Status: offline
Dave,
Where did you get your Dereml bit from? I can't get them here in Australia and have been looking for one for years since I stripped my last one out!
Cheers,
Dave
(in reply to Per_N)
       Post #: 29
RE: "Semi" Composite Tail - 7/30/2004 3:08:01 AM
daven
Status: offline
I got this one from my Father-In-Law, but any dealer of decent tools should be able to get one. I wish I had better info about the exact part number, but I don't.
Dave Norman
klasskote.com
supertrc.com
(in reply to Shackas)
       Post #: 30
RE: "Semi" Composite Tail - 7/30/2004 2:53:29 PM
John Z Williams Jr
Status: offline
Hey Duane, I sent you a web site for neopost.... You need it again????
John W.
(in reply to DHG)
       Post #: 31
RE: "Semi" Composite Tail - 7/31/2004 4:27:30 PM
Stand
Status: offline
I don't know if this helps. I found this set at Home Depot in Austin, Texas. It is called an "Accessory ProPak" by Gyros guard. The company name is Gyros Precision Tools, Inc. www.gyrostools.com The "Reorder Number"
is #61-11817. They have all kinds of saw blades and other stuff for Dremels and have online ordering. A little pricy, but worth it.
Stan Douglas
Click to see fullsize image.
Click for fullsize
< Message edited by Stand -- 7/31/2004 4:33:49 PM >
(in reply to daven)
       Post #: 32
RE: "Semi" Composite Tail - 8/2/2004 4:30:03 PM
oddy
Status: offline
Hi Daven:
Great information for all of us who like building our own Q500´s.
My question is How sharp are the leading edge of this V-tails,,,,if possible to include a photo would be great
Victor Arreola. (Oddy)
(in reply to daven)
       Post #: 33
RE: "Semi" Composite Tail - 8/2/2004 5:09:22 PM
daven
Status: offline
Another advantage of imbedding the 1/64" ply into the edge is that it allows you to really sharpen them. Most of the composites have a more rounded shape to them, but I try to bring them to a pretty sharp edge. I will try to get a picture later.
Dave Norman
klasskote.com
supertrc.com
(in reply to oddy)
       Post #: 34
RE: "Semi" Composite Tail - 9/6/2004 2:34:57 PM
daven
Status: offline
I built a tail last night, and tried something a little different. I first tried to put down a coat of rattle can primer on the wax paper before laying up the glass, but that didn't work so well. As the primer dried, it shrunk or something and the wax paper wrinkled up in a few areas.
I then cut and waxed up some mylar slightly larger than the size of the tail and put a coat of primer on the Mylar and let dry.
I then layed up my glass and hinges as described earlier and put the sandwich in the vacumm bag.
I pulled the tail out of the bag this morning, and it turned out absolutely perfect. I have never been able to get such a smooth surface with glass, and the weave is filled in perfectly ready for paint.
I weighed the tail before glassing and priming and it came in at 1.3 oz. After glassing and priming it came out of the bag at 1.7 oz. Should be able to keep it dang close to 2 oz after adding the torque rods.
Dave Norman
klasskote.com
supertrc.com
(in reply to daven)
       Post #: 35
RE: "Semi" Composite Tail - 9/6/2004 2:41:25 PM
daven
Status: offline
Heres a couple of pictures. They don't show how smooth this turned out, but you can see a little glare
Click for fullsize
Click for fullsize
Dave Norman
klasskote.com
supertrc.com
(in reply to daven)
       Post #: 36
Jump to:
