RE: Sig Mayhem 3D ARF    Gallery
Logged in as Guest
    Search This Thread
Printable Version
More Resources on the
Mayhem 3D
  • 1 Active Classified Ad(s)
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • All Forums >> RC Airplanes >> 3D Flying! >> RE: Sig Mayhem 3D ARF
    Page: <<   < prev  37 38 39 40 41 42 43 44 45 [46]
    Login
    RE: Sig Mayhem 3D ARF - 6/19/2009 12:42 AM
    do335a
    Score: 105
    Last Login: 6/18/2013
    Status: offline
    quote:
    ORIGINAL: frenchie79
    I'm in fear Sig may not be around much longer,
    What is it that you know that I need to learn? What's the scoop that leads you to this fear?? Perhaps I should have made a bunch of templates before the assembly.
    jship, I've had a chance to fly  a 4*-60 on floats powered with an OS 91FX. Nice plane. The Mayhem, however, is something altogether different.
    Hide Signatures
    (in reply to frenchie79)
           Post #: 1126
    RE: Sig Mayhem 3D ARF - 6/19/2009 1:36 AM
    frenchie79
    Score: 100
    Last Login: 8/16/2012
    Status: offline
    I will just say they have had some issues and leave it at that.
    Sig really only has a few planes that  sell and they have been great, but been around a long time with no new designs. The SSE, Mayhem and Four Star series are very popular. I have built them all and have planes on all their Kits- Friends of mine have tried to get plans or get them to offer the Mayhem as a kit but that won't happen. So i'm looking for a wrecked one.
    _____________________________
    Frenchie #193
    www.plattevilleareamodelers.com
    Hide Signatures
    (in reply to do335a)
           Post #: 1127
    RE: Sig Mayhem 3D ARF - 6/20/2009 8:18 AM
    Desert Toad
    Score: 100
    Last Login: 10/22/2011
    Status: offline
    Glad to see this thread is still alive.
    I have been trying my best to learn how to tune my YS 110, and I'm close but every landing so far has been deadstick.  But that's the motor and the operator.  while in the air the plane flies great, seems to have a few tendencies of a pattern plane.  Everything seems so solid and right on track, if I ever get the motor running right it might replace my OMP model as my favorite.
    Hide Signatures
           Post #: 1128
    RE: Sig Mayhem 3D ARF - 6/21/2009 6:21 AM
    jship
    Score: 105
    Last Login: 10/31/2011
    Status: offline
    Maiden the Mayhem to day.  4 Minutes of great flying.  Decided to see how it flew inverted and the engine about died.  Brought it back down, richened it up a little and took it up again.  This time it barely got off the ground.  Brought it around and put in on the run way before it died.  When I went to pick it up, fuel was running out around the wing saddle.    Took the tank out and it was split!
    Well it was a good four minutes of flying.
    A smile is a light on your face that lets people know your heart is home.
    Hide Signatures
    (in reply to Desert Toad)
           Post #: 1129
    RE: Sig Mayhem 3D ARF - 6/21/2009 6:13 PM
    do335a
    Score: 105
    Status: offline
    Although I've had my share of snags with GP tanks that split, I've never had it happen yet with one from Sig.
    Thanks for the heads up. Will keep an eye on it.
    As far as inverted flight goes, I've found that my Mahem does that eaqually well as upright. About the only difference is that you see the plane upside down.
    The OS 1.20 AX is still getting run in so there are changes in throttle setting virtually every flight. A bit of a nuisance but soon that will be past. I just make certain that it is running well enough so that it does not flame out.
    My firend has had his OS 90 flame out very early on every flight. On inspection, we found that the engine was shot. The crank was sloppy, side to side, the bearings were toast, the crank was badly worn and scored, the con rod big end busing was oval and on and on. We'll see what happens with his Mayhem now that he's replace the engine with a new one. We have found though that the plane lands great when deadstick.
    Hide Signatures
    (in reply to jship)
           Post #: 1130
    RE: Sig Mayhem 3D ARF - 6/22/2009 3:33 AM
    jship
    Score: 105
    Status: offline
    I did notice that the Mayhem is a big floter.  It just kept going on and on.  To day I changed prop.  Going to try a 14x6.  Yesterday it flew with a 13x8.  It was to much pitch, ended up at idel about all the time.   I'm runing a old reliable Super Tiger 90.  This engine has had about 20 gal run through it and it still starts first time over.  No dead sticks here.
    john
    Hide Signatures
           Post #: 1131
    RE: Sig Mayhem 3D ARF - 7/14/2009 4:26 PM
    Ivo60
    Score: 100
    Last Login: 10/30/2011
    Status: offline
    hey guys, Ivo here I dont know if I should start A new post, or this is protocol but here goes... I have a Sig mayhem 3-D which I use A 12o saito 4s on it. plenty of power. I use A JR 8103 72 mhz. with a spectrum module to convert to 2.4 . that also is great! for juice I use a 2c 2oooma lipo common sense brand. I have all 3305 fut. servos, even throttle. Knock on wood Ive not had any issues in about 1 full season of flying.I should add that, being this is my fav. plane I am very anal about preflight as I am on all my airplanes. I just thought this might fit this set of threads.lastly I add that this is my only plane of my fleet of about 16 that I use lipo power in. All others I use ni-cads. thanks in Advance for listening! Ivo Rockford Il.
    Hide Signatures
    (in reply to Steve)
           Post #: 1132
    RE: Sig Mayhem 3D ARF - 7/14/2009 11:44 PM
    jship
    Score: 105
    Status: offline
    quote:
    ORIGINAL: jship
    john
    Very unhappy with the 14X6, any suggestions for a prop for a ST 90?
    < Message edited by jship -- 7/14/2009 11:45 PM >
    Hide Signatures
    (in reply to jship)
           Post #: 1133
    RE: Sig Mayhem 3D ARF - 7/15/2009 12:54 AM
    do335a
    Score: 105
    Status: offline
    My friend is running a MA 15-6 on his Mayhem with an OS 91 FX.
    Mine has a MA 16-6 with an OS 120 AX.
    In the manual, Sig suggestes not using any more than 6" pitch.
    Hide Signatures
    (in reply to jship)
           Post #: 1134
    RE: Sig Mayhem 3D ARF - 8/16/2009 7:15 PM
    vtcornercarver
    Score: 100
    Last Login: 1/5/2011
    Status: offline
    remember that pattern pilots have been mounting ALL 2 stroke and 4 stroke engines inverted for years. they run fine, I currently have my YS 1.10 inverted in a Showtime .90 inverted and it will idle at under 1500, and transitions great. Same with OS .46, ASP 1.03, YS .61 , and many more.
    Hide Signatures
    (in reply to robinr767)
           Post #: 1135
    RE: Sig Mayhem 3D ARF - 8/16/2009 7:18 PM
    vtcornercarver
    Score: 100
    Status: offline
    YS engines put the fuel tank under a lot of pressure. that is why the vent line hisses when you release pressure before refueling. pressure is a good thing. it keeps the engine running consistently while flying inverted or verticle. a huge advantage over exhaust pressure engines.
    Hide Signatures
    (in reply to jship)
           Post #: 1136
    RE: Sig Mayhem 3D ARF - 4/23/2013 10:28 PM
    byjoe
    Score: 100
    Last Login: 5/1/2013
    Status: offline
    I have Mayhem fus. I need a wing or a rib to build a wing.Sig does not have any parts.
    Hide Signatures
    (in reply to Steve)
           Post #: 1137
    Mayhem 3D
  • See User Ratings
  • Jump to:
    Google
    SITE MAP!   : :   FORUM RULES
    0.531RCU1
