oops
Joined: 2/26/2005 From: Perth, AUSTRALIA Status: offline
If you cannot get the Zhen Hua controller working... Some transmitters (especially 5 or 6 channel ones) do not put out the codes... Go into Hyperterminal, and set for the correct com-port, and 19200 baud. No parity, 8 bits, one stop bit. If you see a stream of characters when the controller is turned on, then it's OK. Use PPJOY with Serial and virtual. (It's actually 5 repeating characters which change with the controller inputs). If you see nothing, then you have a fault, or no serial output. 6 Channel transmitters have no output from what I can tell. Then you need to hook into the PPM output from the chip, and run into PPJOY via a parallel port. This involves some soldering. Removing the Xtal only reduces power consumption by disabling the transmitter. It doesn't trigger the signal. David
