oops -> RE: Zhen Hua Radio and FMS really works!!! (3/28/2005 6:38:01 AM)
Hi Rweller, They like to fall over on a smooth power-up... That really sucks... I can't fix that either... I think it's because it's so light and you need a little right roll on the swashplate to stop them shooting to the left (To counter the thrust from the tail rotor). I usually get to 80% flying thrust, then "jump" the throttle up a few notches... This yanks it off the deck, and into an unstable hover... Sometimes it goes straight up without a problem, but other times, it goes left or right a bit, and I have to catch it... Usually I get it about 2ft off the ground with that maneuver. Then I drop down a notch or two to get to hover power. It balloons a bit, and at first, I landed on the down-cycle, but after practice, I managed to get it to hold altitude around 2 to 4 feet after liftoff. That gets around the roll to the right or roll to the left problem on takeoff. (The 22A doesn't do that at all, so I think it's a Walkera 4 trait) Once it's up, get it tail in, and get it to hover quick! Make sure there are no walls within 3 metres... They are a bad distraction. Cut some of the remaining tab from the swashplate before making the spring-wire repair. Mine goes in as far as the bearing (almost touches, and is certainly below it) and is hot-melted in about 1.5mm... Almost in the middle of the plastic... Hi Iron1800, You can get signal from the Crystal socket if you like. Anyway, take a photo of the underside (chip side) of the controller. I'll email you so you have a return address. David
