Traveler
Joined: 8/9/2005 From: Noord Holland, NETHERLANDS Status: offline
Hey yoowicked, Assuming that the seller shipped the right cable for your TX, that leaves the PC, it's software (including the OS), the cable or the TX itself as the likely suspects. If you have access to another PC with a serial port to try it on, that would be a good first step in trying to locate the problem. If it works on another PC, then we know the problem will be in either your PC or software. Instead of the serial sniffer-application that doesn't work on your PC, you can use Hyperterminal, which is included with Windows, to listen for the TX on your serial port. I just tried it with a similar cable to yours and it works. Find Hyperterminal under "Start -> All Programs -> accessories-> Communications". It'll come up with it's "New connection"-dialog, where you first name your new connection. Depending on if you have a dialling-location configured, it will ask you to create one before you can proceed. For what we're doing, it won't be used, though. Fill out your area-code and continue. Next up will be the "connect to"-dialog. Select the COM-port your cable is attached to from the list under "connect using" and hit "OK". On the next dialog-box, leave everything default, except the "bits per second"-number, which should be set to "9600". Hit "OK" again. You should now have an empty Hyperterminal-window and it should say "Connected" at the bottom left. If you turn on your TX, it should start scrolling some characters on the screen, which tells us that there is some serial stream coming from it, which PPJoy should at least be able to see. Let me know how it goes. Grtz, Traveller
