*finished* f 15 foam core board
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric RC Jets >> *finished* f 15 foam core board Page: [1]
Login
*finished* f 15 foam core board - 1/31/2004 6:46:01 PM
finchero
Status: offline
I saw a pic in one of the jet posts how someone built a f15 kit out of depron. I got to thinking about using wal mart foam core board($2.50 a sheet).
I started a couple nights ago. this stuff is amazingly strong, so no inner supports are needed. once she's finished I'm going to fill in all the cracks with spackle and sand her down. so far I'm pretty impressed with the strength and light weight. so far she weighs 7 oz. I expect she'll be around 11oz when finished which is fine for the brushless pusher prop set up I plan to use. auw should come in around 35oz with a mega 16/15/3 and 3s3p lithium pack.
any of you guys build with this stuff? if not you should give it a try.
will post more pics as I go
p.s. the nose will go on last I plan to make it out of either eps or epp foam, this way in the event of a crash it should hopefully be the only part with major damage
*update* now finished
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by finchero -- 2/25/2004 4:10:45 AM >
       Post #: 1
RE: f 15 foam core board - 1/31/2004 8:05:06 PM
Pilatuspilot
Status: offline
Nice job! I think it was an Su-27 you saw, I saw it to. Made me think of building an F-14 the same way.
(in reply to finchero)
       Post #: 2
RE: f 15 foam core board - 1/31/2004 8:41:07 PM
finchero
Status: offline
just removed the outer layer of paper and reduced the weight by about 2oz. kept the inner layer for strength
(in reply to Pilatuspilot)
       Post #: 3
RE: f 15 foam core board - 2/4/2004 2:07:12 PM
airmcn_2
Status: offline
This stough ruls,!!!! cheap too how did you get the top layer of paper off?
       Post #: 4
RE: f 15 foam core board - 2/4/2004 10:06:15 PM
finchero
Status: offline
takes time to remove and is kind of a pain, but worth it. some people have soaked it over night to remove both sides of paper
(in reply to airmcn_2)
       Post #: 5
RE: f 15 foam core board - 2/5/2004 2:18:44 PM
airmcn_2
Status: offline
WHAT ARE YOU DOOING FOR STRINGERS ALONG THE FUSE AND WINGS?
       Post #: 6
RE: f 15 foam core board - 2/5/2004 4:32:10 PM
finchero
Status: offline
for the wing I have one balsa spar along the leading edge, once they arrive in the mail I'll have one carbon fiber spar along the cg of both wings which will also connect the two. As for stringers in the fuselage, there are none. the plane being built with this board is stronger then balsa and I don't really see the need. the aft end has support boxes for the tailerons. I was thinking maybe a few bulk heads once I strart to build the hatch on the underside, and have the battery placement all figured out.but that's going to be about it.
       Post #: 7
RE: f 15 foam core board - 2/5/2004 6:01:48 PM
airmcn_2
Status: offline
cool, I been using this stough also its pretty nice, where didi you get you plans for the f15 at?
       Post #: 8
RE: f 15 foam core board - 2/5/2004 6:17:05 PM
finchero
Status: offline
I don't use plans. I go off photos that I print from the net and try to keep it as scale as possible. Its not too tuff really. plans are for people in love with balsa and those perfectly scale models. I'm sure I'll be one of those people some day but right now as long as it looks good and flys fast then I'm happy
here's some new photos
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by finchero -- 2/5/2004 6:20:25 PM >
       Post #: 9
RE: f 15 foam core board - 2/5/2004 6:40:04 PM
airmcn_2
Status: offline
That Looks Cool Man!!!! Thanks
       Post #: 10
RE: f 15 foam core board - 2/6/2004 11:43:54 AM
Jules
Status: offline
That looks like a nice F-15 do you have any planes to kit it, and if so how much are you thinking of.
       Post #: 11
RE: f 15 foam core board - 2/17/2004 7:51:10 PM
mjblack
Status: offline
anyone fancy seeing a Depron F-15 realy fly?
visit www.rcelectricflight.com and check out eh new vids.
cheer all,
Mike.
(in reply to Jules)
       Post #: 12
RE: f 15 foam core board - 2/23/2004 5:27:22 PM
finchero
Status: offline
here's a new pic of the f15, little more paint and detail and it should be complete
Click for fullsize
(in reply to mjblack)
       Post #: 13
RE: f 15 foam core board - 2/25/2004 4:14:17 AM
finchero
Status: offline
finished and I'm very proud. I didn't know it would turn out as well as it did. hope it doesn't crash on it's maiden flight . everyone should try to build without plans, it gives you a sence of freedom.
Click for fullsize
Click for fullsize
       Post #: 14
RE: f 15 foam core board - 3/3/2004 2:17:07 AM
