Tall Paul
CA, USA Status: offline
quote:
ORIGINAL: Strat2003 I wish you guys were at my kitchen table so we could wave our hands around and draw diagrams and stuff....... If I understand correctly, the sum of the forces, or at least lift, for the airplane as a whole, acts through the neutral point? And those forces are the lift, drag, and any pitching moments gernerated by th wing, the tail, and the fuselage? Paul, I noticean "empirical pitching moment factor" and a "downwash factor" in that equation. Where do they come from and how are the arrived at? Thanks again . You noticed! Way back when in my senior aero class the neutral point equation came up, with those same 'fiddle factors". The way I undertand it, these are "derived" by the somewhat circular reasoning that a 10% "static margin" gives a stable airplane. This airplane is stable, therefore it has a 10% static margin. With this answer then, those comparaitve unknowns can be solved for, adjusting their values to get the established answer. Cheaper and easier than running a wind tunnel test, particularly if the new plane isn't that different than the previous. The previoius one flew, so the new one should fly also. . Many aero books will go more into detemining downwash etc, to a getter precision, but you'd be surprised how many full-scales have used the "the old one worked, the new one will too" approach. I've heard the c-119 was done using used this approach.. It wasn't -that- much different from the C-82, ergo it should fly. And it did. With today's overwhelming compuational power of the analytical computer, this TLAR approach is seldom used, except for models, where it still works.
