Adding castor oil
Tower Hobbies
Logged in as Guest
  Printable Version
MT FLEX HEADER & CANSTER For MT50,57, 62, Brillelli GT 366, DL50,DA50,G62 ENGINES
Seller:  mistydee0
Details:   $149.00   |  7/17/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> RC Fuels >> Adding castor oil
Page: [1]
Login
Adding castor oil - 2/1/2004 3:39:33 PM
Trung
Status: offline
I have Cool Power 10% and my thread from the other forum said ABC engines need some castor oil. Can I buy some castor oils and mix it with the fuel. I have the fuel in the 1 gallon jug and so far only 20 oz has been used. If i can mix some castor oil then how much oil do i put into the jug. The label said that the fuel contain some rust inhibitor and after run oils should not be used... well I didnt read the label so I did put some after run oil in so would that damage anything? How do you prepare the engine for storage after a day of flying? All I did was pull of the fuel line and let the engien run itself dry, but when i opened the backplate I saw specs of rust on the crankshaft. Whats goin on, I thought the fuel protected the engine from rust. And that was its first run out of the box too.
       Post #: 1
RE: Adding castor oil - 2/2/2004 9:46:15 AM
Red B.
Status: offline
If I'm correctly informed the Coolpower fuel contains 17% synthetic lubricants.
If this is the case I can see no reason why it shouldn't work for ABC-engines.
All my engines (mostly OS, Saito and Super Tigre) are run on fuel containing 15% synthetic lubricant (Aerosynth) and no castor oil.
The exception is the ST 3000 which use only 10% oil. I have done so for the last couple of years and have had no problems whatsoever.
You can mix some castor oil in your fuel as a protection against lean running or if you suspect that your engines will operate at high temperatures (e.g. tightly cowled engines).
Do use some kind of after-run oil to protect the ball bearings against corrosion.
If you send me your e-mail adress I can send you a fuel mixing spreadsheet (MS Excel) that I ise myself when mixing fuel.
/Red B.
< Message edited by Red B. -- 2/2/2004 9:53:07 AM >
(in reply to Trung)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.328RCU1
