need help with charging question
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> need help with charging question
Page: [1]
Login
need help with charging question - 2/1/2004 8:49:15 PM
ALLISONMO2
Status: offline
i found a wall charger in a box that only says 7.2volt 1-4hour quick charger. on the back it says under output 9vdc 500ma. is 500ma the output for one hour? the make is pti. i foound no info on the net so i am hoping someone here has one or is familiar with this general type of charger.
thanks
mike
       Post #: 1
RE: need help with charging question - 2/2/2004 1:05:44 AM
mglavin
Status: offline
The 500mA output is continuous, as long as it plugged into the wall it's charging... Teh 1-4 hour note is based on the size battery under charge. If it was 1000mAh battery it would require two hours to charge if the battery was completley discharged.
_____________________________
Michael Glavin
RCU Community Moderator
Hitec * Multiplex Field Representative
(in reply to ALLISONMO2)
       Post #: 2
RE: need help with charging question - 2/2/2004 1:14:27 AM
ALLISONMO2
Status: offline
thanks
(in reply to mglavin)
       Post #: 3
RE: need help with charging question - 2/2/2004 12:55:26 PM
Red Scholefield
Status: offline
quote:
ORIGINAL: ALLISONMO2
thanks
mike
The 500 mA is what the charger will deliver at a voltage of 9 volts (or in that range). If it is connected to a battery that has a higher charge voltage then the 500 mA will decrease, lower charge voltage and it will increase. If you measure the open circuit voltage and the short circuit current you will get a pretty good idea of the voltage current relationship. It is not exactly a straight line but in most cases good enough for our work.
Red S.
AMA 951 Leader Member
Disclaimer: What I have written here are my thoughts and in no manner shape or form reflect the views of RCU
       Post #: 4
RE: need help with charging question - 2/3/2004 3:35:01 AM
ray c.
Status: offline
Along these lines i have a 12 volt 4.5 A battery for my field box. It is recommended to charge at 500 MaH for 6 hours. How can I determine what other rates of chargers will work. Also do they have to be 12 volt chargers?
(in reply to Red Scholefield)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.906RCU3
