slow stick questions
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric Training >> slow stick questions
Page: [1]
Login
slow stick questions - 2/1/2004 11:18:50 PM
ccchris
Status: offline
It is built but I have a couple of questions.
1) I have the 300 motor, is the GWS gs100 5 amps speed controller right for this motor? Hobby store said it was ok but some reading has me confused, do I need more capacity? I have a 7 cell 8.4 800mah nimh battery.
2) The horizontal tail is not horizontal to the wing, would shimming it on one side to get the right angle suffice? I have glued it all in place.
and if it matters I am using standard servos and reciever that was from another project that I was not qualified to fly and destroyed, the idea is to learn on the ss and rebuild the other when I am ready.
thanks
       Post #: 1
RE: slow stick questions - 2/2/2004 4:07:32 AM
zagibond
Status: offline
Depending on your prop, I would say that your ESC is a bit small.
As long as the tail does not interfere with the rudder you should be OK, although perpendicular would be better.
Weight is really not a big issue, enjoy
(in reply to ccchris)
       Post #: 2
RE: slow stick questions - 2/2/2004 12:48:31 PM
Matt Kirsch
Status: offline
The GWS ICS100 speed control is a little underrated. It'll take 8 Amps even though it's only rated for 5. The EPS300C drive can draw up to 8 Amps, but you won't be flying at full throttle most of the time anyway.
Proper alignment will make the plane fly better. Do what it takes to get things straightened out. As a newbie, you don't need anything working against you on your first flights.
Don't let zagibond's resposne confuse you. Weight IS important. It's just that the Slow Stick can carry a few extra ounces without it adversely affecting the way the plane flies.
(in reply to zagibond)
       Post #: 3
RE: slow stick questions - 2/2/2004 6:39:48 PM
sierra gold
Status: offline
On the SS the horiz. stab is glued/screwed to the bottom of the rectangular aluminum fuse stick. It should be difficult to not get it flat and horiz. to the fuse. (More glue on one side than the other?)
When you are sighting down the wing and looking back to the stab and seeing a difference, are you sure the wing is centered on the wing supports? It would be much easier to have the wing out of allignment, given its adjustability.
Sierra Gold
< Message edited by Sierra Gold -- 2/2/2004 1:45:40 PM >
(in reply to Matt Kirsch)
       Post #: 4
RE: slow stick questions - 2/6/2004 2:38:54 AM
ccchris
Status: offline
Thanks for the advice, I have found the problem with stabilizer is the rudder mounti s pushing the one side downward. I have rectified that problem.
The next is too get it in the air when the weather co-operates.
Cheers
(in reply to sierra gold)
       Post #: 5
RE: slow stick questions - 2/21/2004 4:29:49 PM
ccchris
Status: offline
I made necessary changes to rudder etc. Replaced standard servos this week with GWS Naro sized ones.
First flight had some problems. Plane lifted off the ground right away but would not climb, seemed to be tail heavy although I found CG per the instructions. After I ajusted the elevator to compensate I was flying (?) 40 feet at a time, the plane was always trying to turn left. Prop finally broke after running the plane into the ground several times. Any reasons for the left turns when everything appears to be lined up. I will be out on the next calm day to try again.
thanks
       Post #: 6
RE: SS crash - 2/23/2004 3:30:00 AM
ccchris
Status: offline
Todays flight was going great until a nose dive straight into the ground. Shaft that prop mounts to is bent, I have straightened as best I could. Still alittle wobbley, will this do damage to engine or gears etc? Is there a replacement shaft available?
Should the SS be able to climb at half throttle? Does not want to unless closer to full power, my CG is still not prefect so not sure if that is hindering flight.
Any help is appreciated.
       Post #: 7
RE: SS crash - 2/23/2004 6:41:37 AM
Time Pilot
Status: offline
You may want to check out the Ultimate Slow Stick thread at www.rcgroups.com. It is a rather gigantic thread--in three parts at that--and will likely tell you more than you wanted to know. You'll find it in the beginners training area. If you can't find it, let me know and I'll get the link.
As far as parts, I know they are available. I don't exactly know what you need but look in motor accesories at www.backyardflying.com.
Haven't shopped here myself, yet.
< Message edited by Time Pilot -- 2/23/2004 1:45:13 AM >
       Post #: 8
RE: slow stick questions - 2/25/2004 2:27:03 AM
Dopesick
Status: offline
quote:
ORIGINAL: Matt Kirsch
The GWS ICS-100 will work fine in a slowstick under 21oz. provided your not too crazy with motors or props. I would say IF you change props a 1080 or 1180 would be the only options with that ESC. I've been flying mine as listed in my profile, with a aiptek pen camera. And the ESC and plane are holding up fine.
< Message edited by Dopesick -- 2/24/2004 9:28:57 PM >
_____________________________
Just another addicted R/C guy.
       Post #: 9
RE: slow stick questions - 2/26/2004 3:39:49 PM
ccchris
Status: offline
Thanks for the info.
Time Pilot I read the threads and found some useful info.
Waiting for a calm day, thought I found the proper shaft at LHS but got home to find I was given the wrong size. Going back with the bent shaft to find a match.
cheers
(in reply to Dopesick)
       Post #: 10
RE: slow stick questions - 3/1/2004 11:19:08 PM
ccchris
Status: offline
I changed the prop to a 1260 and I am starting to get the hang of flying. Doing things beyond my skill level but the plane will loop from level flight effortlessly, I'm having a blast and have not broken anything in awhile.
Shaft still bent but does not seem to affect anything.
Cheers
       Post #: 11
RE: slow stick questions - 3/2/2004 3:45:48 AM
doug6952
Status: offline
I just got a slow stick today. Plan on buiding it wed. night. I have an e starter only flew it a couple of times the other day and crashed many times. I fixed all the damage but I figured I would give the e starter a rest and practice on the slow stick first. From what I have read I really should have gotten the SS first.
       Post #: 12
RE: slow stick questions - 3/10/2004 6:15:27 PM
ccchris
Status: offline
Strangest thing happened last night. Was flying fairly aggressively (having a blast) and the rudder broke apart. Where it connects to the fuselage snapped off, I had glued and reinforced with the plastic piece. I have to make another piece BUT is there another way to make this stronger or do I have to be gentler on the plane? Having too much fun doing touch and go's and loops to go easy.
thanks
Chris
(in reply to doug6952)
       Post #: 13
RE: slow stick questions - 3/10/2004 7:47:04 PM
csisfun
Status: offline
What aggressive? I try to do 3D with this plane with a 300 and it always ends up with broken wing tips, broken aluminium wing joiners, broken props. Touch and go? I haven't really tried that though I have tried catching the plane!!! Too much fun! Just face wind (the plane should hover horiz. with correct wind conditions) and cut throttle and catch!!!
Hahahaahah!!!
As for your rudder, if all else fails, you can cut a rudder and maybe enlarge the control surfaces for yourself. Just follow your SS rudder as a template and cut it out.
With depron, coroplast, correx or whatever it is called in your area.
Makes me wanna fly the SS... it's an addiction!!!
< Message edited by csisfun -- 3/11/2004 3:51:29 AM >
       Post #: 14
RE: slow stick questions - 3/11/2004 4:03:16 PM
ccchris
J
