AcroJo
Joined: 1/25/2003 From: Clarks Summit, PA, USA Status: offline
Chuck, the S 100 is a good choice. I see you have done your homework regarding the position of the quick fuel valve. Many have found to simply raise it up from a too low position. Also, if need be, there is approxamatly 5/8 of an inch in there, if you would like to lower the tank right from the get go. On the LG block you don't have to go overboard on it. You will find a full former at the front of the wing, where the wing dowels insert. Forward of that, there is a half former. Between the two formers you will find the LG block, sandwiched between the two. There is one piece of tri stock, from the factory, attached horizontally, joining the LG block to one of the formers, You can feel it with your finger. My recomendation is to add one more piece of tri stock, horizontally, to the other former. Test fit to see that you don't cover the tee nuts, for good reason, which I will explain in a minute. Now cut four more pieces of tri stock and fit them in the cavity, vertically, in each of the corners. Again, this is done by feel or trial and error to get the right length, as I do not remember the dimensions. Finally, you will see where there are two pins, or dowells going through the two formers and the LG block, front to back. Drill and insert one more dowell between the two existing ones. I found this to be very strong and light. Back to the tee nuts, You don't want to cover them or glue them in, as I found that the simple tri stock mods were so strong that on ocassion I would snap the threaded tube of the tee nut from the retaining washer and would need replacement. Its a gentle balance, too strong and a mishap will do unescesary damage to the fuse. Too little and you will knock off the UC, but thats what it was designed to do to save the fuse. Good luck with the build and enjoy. Joe
_____________________________
Stranger in a strange place.
