RE: u-can-do 60
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
U-Can-Do 3D ARF - 61
  • 6 Active Classified Ad(s)
  • Read Full Review
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> ARF or RTF >> RE: u-can-do 60
    Page: <<   < prev  54 55 56 57 58 59 60 [61] 62 63   next >   >>
    Login
    RE: u-can-do 60 - 10/27/2006 7:59:20 PM
    jkhorvath
    Status: offline
    I've had my U-Can-Do 60 for a year now, it's time to replace the wheel pants. The original ones are starting to crack. I decided on a new color design for the new wheel pants and would like some feedback on it.
    First pic is the original wheel pant color design that I did a year ago. Second pic is the new wheel pant color design that I am using now. Note also in the second pic that I replaced the wheels and tires with Sullivans. These tires have raised lettering, so I took the time to paint the raised lettering with white appliance epoxy paint. I like the way they came out, but what does this U-Can-Do group think?
    By the way, the OS FS-91 II Surpass w/Pump in the nose of this aircraft took 6 months to break in; and it's just nothing but fun now.
    Click to see fullsize image.
    Click for fullsize
    Click for fullsize
    Click for fullsize
    (in reply to Olle)
           Post #: 1501
    RE: u-can-do 60 - 10/27/2006 8:27:49 PM
    SunShyne
    Status: online
    jkhorvath - looks really nice, how did you create the scheme? Is that paint or a vinyl sticker?
    _____________________________
    http://www.SendTextMessage.net
    Revver Bro #86
    (in reply to jkhorvath)
           Post #: 1502
    RE: u-can-do 60 - 10/28/2006 8:28:09 PM
    AcroJo
    Status: offline
    JK, nice job on 'pimp'n your ride'. The wheel pants are all too often overlooked as a palete to enhance the looks of a model. Great job and the raised white letters seems to finish it off. Now you'll be doing the 'Armor All' thing post flight. Perhaps a little surfing will turn up some aluminum mag wheels. Joe
    Stranger in a strange place.
    (in reply to SunShyne)
           Post #: 1503
    RE: u-can-do 60 - 10/30/2006 2:39:11 PM
    jkhorvath
    Status: offline
    The scheme was done "free-hand" and is based on the color design of the front of the aircraft's fuse. The actual colors are cut out of Monokote Trim Sheets.
    Thanks for the positive feedback folks. I wonder if Sullivan makes the mag wheels I am looking for now. I need the ones that look like they are spinning when you are standing still.
           Post #: 1504
    RE: u-can-do 60 - 10/30/2006 2:43:10 PM
    rajul
    Status: offline
    Very nice! GP should take note of this
    Mike Marks
    RCU Moderator
    Aerofly Support Representative http://www.aerofly.com/index.html
           Post #: 1505
    RE: u-can-do 60 - 10/30/2006 5:07:49 PM
    Kostas1
    Status: offline
    The OS 91 w/o pump is able to hover this great plane?
    I am asking because i think it will be underpowered.
    I am currently flying the 46 version with an OS 91 FX upfront.
    Using a Zinger 15x4 it's easy to hover but i am learning......
    Maybe,
    a new,
    OS 120 AX
    will be the best?
    Click for fullsize
           Post #: 1506
    RE: u-can-do 60 - 10/31/2006 1:19:59 PM
    jkhorvath
    Status: offline
    Kostas1;
    My OS 91 FS w/pump hovers this aircraft now that it's broken in. Actually, I even have a bit of vertical performance. But, when the engine was new, there was no way that it would hover. I am running an APC 15x6.
    I would also recommend the OS 120 AX for the U-Can-Do 60. That engine would seem to have enough power for this aircraft.
    (in reply to Kostas1)
           Post #: 1507
    RE: u-can-do 60 - 10/31/2006 10:30:43 PM
    Kostas1
    Status: offline
    But what about the flight time on stock tank?
    What's the capacity of it?
           Post #: 1508
    RE: u-can-do 60 - 11/1/2006 1:53:26 PM
    jkhorvath
    Status: offline
    My U-Can-Do 60 gets over 20 minutes of flight time using the stock tank (14.2 ounces) and the O.S. FS-91 II Surpass w/Pump.
           Post #: 1509
    RE: u-can-do 60 - 1/16/2007 10:10:02 PM
    zoott
    Status: offline
    Is this the thread for 60 or 46 lol?
           Post #: 1510
    RE: u-can-do 60 - 3/21/2007 5:26:48 PM
    kjelld168804
    Status: offline
    I couldn't bring myself to read all 60 pages of this thread so sorry if this has been asked before.
    I have a UCD 60 with a Saito 125 (inverted), stock tank mounted forward, GP fuel valve...
    I get flooding of the Carb during refueling, was wondering what may be the cause. It seems to not be as bad after the engine is warm...
    Also, when vertical, I lose fuel and the engine dies or comes very close. What can I do to fix this very annoying problem? I assume that the tank is losing pressure but am not sure why or what else it may be.
    Where did you all buy your Irvine hardware? What other RC sites should I check out other than Tower and Horizon?
    REVO 3.3 / RC10T4 / XXX-4 G+ / E Rustler / AXE CP / Flatout Biplane / UCD 60
    Mini Magic / Pulse XT / Showtime 4D / JJ
    (in reply to zoott)
           Post #: 1511
    RE: u-can-do 60 - 5/19/2007 9:27:29 PM
    bc-slowflyer
    Status: offline
    What flight battery is everyone using? I am thinking of using a 1500 2S 20C lipo pack with a voltage regulator. Will this be enough battery for digital servos all around?
    Thanks;
    Rod
    (in reply to kjelld168804)
           Post #: 1512
    RE: u-can-do 60 - 5/19/2007 9:36:19 PM
    AcroJo
    Status: offline
    on another plane I have 5 JR8411s and a standard on throttle. They are running off a 2100 2 cell on reg and after 30 minutes of use it eats up about 1/4 of the batteries capacity. I would think you should have plenty. good luck. Joe
    (in reply to bc-slowflyer)
           Post #: 1513
    RE: u-can-do 60 - 5/19/2007 11:35:47 PM
    bc-slowflyer
    Status: offline
    Thanks for the quick reply Joe. I'll keep the thread posted as to my progress on the build.
    Rod
    (in reply to AcroJo)
           Post #: 1514
    RE: u-can-do 60 - 5/19/2007 11:56:58 PM
    AcroJo
    Status: offline
