RE: RE: RE: RE: u-can-do 60
Tower Hobbies
Logged in as Guest
  Printable Version
More Resources on the
U-Can-Do 3D ARF - 61
  • 1 Active Classified Ad(s)
  • Read Full Review
  • See User Ratings
  • Suggest Compatible Equip.
  • Check for Retailers
  • Discussions on this Product
  • All Forums >> RC Airplanes >> ARF or RTF >> RE: RE: RE: RE: u-can-do 60
    Page: <<   < prev  6 7 [8] 9 10 11 12 13 14 15   next >   >>
    Login
    RE: RE: RE: RE: u-can-do 60 - 3/7/2004 6:51:29 PM
    autoguns
    Status: offline
    Didja fly???? or did it die.....we at the Ministry of Aeronautic's will pray for you ,under the guidance of Father Joe....
    quote:
    ORIGINAL: lord lucan
    Guys..
    Got dragged into work a lot this last week,and today..but things should be quiet after tomorrow ....so.. booked holls for begining of next week..to start UCD ..! have everything i could possibly need...mowed lawns today so she cant hit me with that one Monday..." because your off..." etc.... then just to get the jucies flowing ...ran the mustang up..... ! Wow that smell again... ...gona put everything on charge ...if its nice tomorrow....!
    < Message edited by autoguns -- 3/7/2004 1:52:24 PM >
    (in reply to lord lucan)
           Post #: 176
    RE: u-can-do 60 - 3/7/2004 7:38:38 PM
    AcroJo
    Status: offline
    Roger, sorry for your loss. Remember the doors of the Ministry are open in your time of need. Let us bow our heads in a moment of silence at this tragic time and also remember past incidences as well. Joe
    _____________________________
    Stranger in a strange place.
    (in reply to rfw1953)
           Post #: 177
    RE: RE: RE: RE: u-can-do 60 - 3/7/2004 8:20:22 PM
    lord lucan
    Status: offline
    Guys..
    Dazzling moring .... light zepher of a breeze..cool...4..maybee 5..c..Peter,(10 years old) is vibrating.... 'Are we going Dad ..?..Are we..? Are we..? Yes,Yes,Yes....Whoa..Hang on.. there a bloody great black cloud scuttling this way...and another...wher's your Mother she's got something to do with this..!
    Anyway ..the clouds got more and more frequent ..then it started raining,then it stopped then the time between 'starting' and 'stopping' got less...and less..continious rain now ,coming down..hitting the ground...going back up six feet.. then coming down again..! Abort mission.
    Not going then..?..She asks..There was springtime in her voice.
    This tank pressure with the YS...what sort of PSI we talkin... i'd heard some horror stories about this...
    Got one of those 'Pucka' O.S ally engine mounts for the UCD ...but i thought it was about an inch to short ...C of G probs...?.... Fuze/cowl mismatch..?
    Had a GP 'Dazzler ' kit unopened & new O.S .52FS on hand...Peter et Moi ripped into that today instead..UCD.. tomorrow/tues ..when the house is quiet..! Dave.
    Click to see fullsize image.
    Click for fullsize
    (in reply to autoguns)
           Post #: 178
    RE: u-can-do 60 - 3/7/2004 8:28:20 PM
    rfw1953
    Status: offline
    Who lost what? Jeff, one other thing. The remote glow only helps when starting the engine. After you remove the glow starter from the remote glow it serves no function. It's simple a power relay to the primary on the engine.
    autoguns - I fuel proof the inside as well, but still don't like exhaust going inside the fuse. Get's everything all oily inside over time. Like you said, to each his own. That’s one of the things I like about RCU. You get different options from many different people. Then you have to select the best for you. We all learn from these discussions.
    I have to admit that I'm not as concerned with the weight thing that some of you are. I don't want a tank in the air either, but then I don't like foam wheels, plastic spinners etc. Trade offs with both approaches. You just have to assemble to suit your specific wants and desires. As for the mount, I purchased a mount for this engine and not real concerned about it being used with other engines. Then again, the fit is perfect, tight and no slop. I have seen guys use both. It's all a matter of what you want.
    Good Luck and Good Flying,
    Roger
    (in reply to AcroJo)
           Post #: 179
    RE: RE: RE: RE: u-can-do 60 - 3/7/2004 8:38:33 PM
    autoguns
    Status: offline
    I don't know what kind of pressure the pump is putting out ,but it will turn a sq tank into a round one ,It did split the tank that came with the UCD3D, I found out when the engine didn't want to run right ,,Then I saw the fuel draining from the fuse....Glad I fuel proofed the tank area and radio bay.....Now it has a seamless tank ...Once I un-hooked the fuel line at the ez-fueler on my test stand ,WOW that fuel shot across the shop and the front of my pant's were soaked , man that Nitro is very cold....LOL....JW
    < Message edited by autoguns -- 3/7/2004 3:40:09 PM >
           Post #: 180
    RE: u-can-do 60 - 3/7/2004 8:44:39 PM
    AcroJo
    Status: offline
    Sorry, I was thinking of a remote glo-driver. Totally different issue. Joe
           Post #: 181
    RE: u-can-do 60 - 3/7/2004 9:01:37 PM
    rfw1953
    Status: offline
    Dave, no CG concerns with mine. It was right on the nose with my set-up. The sky blue stripe does not align well with this mount. I mentioned this in a previous thread way back. I had to cut new strips and positioned on the fuse to get the alignment right.
    Click for fullsize
    Roger
           Post #: 182
    RE: u-can-do 60 - 3/7/2004 9:22:16 PM
    AcroJo
    Status: offline
    Hang the stripes, gotta get that engines "back to the wall". Joe
           Post #: 183
    RE: u-can-do 60 - 3/7/2004 10:04:53 PM
    autoguns
    Status: offline
    It's not that I haven't ever used silicon adhesive to seal the opening , I have used it on a couple of plane's...On this one I have the problem of the tank expanding & contracting because of the pressure the pump put out ,...I'm sorry if you were offended by my comment's, that was not my intent ....I also use alum spinner's ...Like I said in my last post ....To each there own......Some like chevy ,some like ford ......And some even like dodge...LOL.....JW quote
    quote:
    ORIGINAL: rfw1953
           Post #: 184
    RE: u-can-do 60 - 3/8/2004 4:48:50 AM
    rfw1953
    Status: offline
    JW, no way my friend. I don't get offended on these sites. Too easy to misinterpret when only using the written word. I wasn't offended at all, and hate that my response suggested such. I really appreciate good feedback and a different POV. Like I said, this helps us all to think more about what we are doing and why we are doing it. Jeff has already made me think more about weight than I have before. Thank you though for being concerned enough to respond as you did.
    Roger
           Post #: 185
    RE: u-can-do 60 - 3/8/2004 5:45:31 AM
    autoguns
    Status: offline
    I'm glad I didn't offend you ,I sometime's don't word thing's very well ,and my insight is not the best ...So I like to keep everyone happy,after all ,we are all here to have fun, and learn from each other's, idea's, experience's, and technique's....you are very welcome,....and Thanx....JW
           Post #: 186
    RE: u-can-do 60 - 3/8/2004 5:34:45 PM
    lord lucan
    Status: offline
    Guys...
    Right... Quick recap over what i hope everyone conciders a reasonable standard of build commitment for this airplane...Hang on though, this realy is a first class kit by GP..Even though it cost over $100 more in U.K. I still think it's well worth it.
    OK.91FS II P on the front..to start with..YS later ..or, as and when neccesary, Neat and tidy O.S tuned pipe to suit, bottom exit...
    New tank, same capacity.. but fits exactly betwee the two formers above the wing..
    Hi-tec servo's all round, torque values to suit,low profiled in wing, Irvine 3mm carbon rods with double-lock ends,
    Beefed up landing gear bay ( Done this allready... 'Voltwatch' covering acces hatch )..
    Fixed stab. Gp mount ...needed the length..for flexi pipe exit off header.
    Du-Bro heavy duty horns..
    O.S remote glow, GP easy fueler.....Futaba ..Tru-Turn..Zinger..all have a part to play...Sullivan Tailwheel ..
    Lastly, Im sure the stock hinges are OK in " Fit,Form,& Function...so lets have faith in 'em..!...all the surfaces they are to fit to were cut and slotted ready for them anyway.
    So ..here we are ..ready to go to build ..! any last minute ' fine tuning ' ? shout up chaps..!
    Oh, Roger,Joe,JW.. Thanks for suggestions,tips,hints & well... loadsa fun..! This is the best . Couple of photo's ...Just for fun..! Oughta go cover the Exta's wings realy but cant wait to get going with the UCD...
    Again , many,many thanks.."Lets go Girls..."...!
    Dave
    Click for fullsize
    Click for fullsize
    Click for fullsize
           Post #: 187
    RE: u-can-do 60 - 3/8/2004 6:03:50 PM
    autoguns
    Status: offline
    LL if you have any doubt about the CA hinge's ,Get some clear monocoat ,cut some strip's out of it ,place over the hinge line.....Just a little added protection.....do the center first at low heat....JW ....PS... sound's like you got the base's covered.....JW
           Post #: 188
