rfw1953
Joined: 7/9/2002 From: Hampton Cove, AL, USA Status: offline
Good morning guys. Joe, as always, I learned something new today that I had never thought about. I've never taped the crystal in place, but it sure does make sense now that I know about it. I do use Futaba in nearly all my planes. Using Hitec in the UCD with Futaba Rx. Interestingly enough, the only servo failure I've ever had was with one of the new Hitec's right out of the box. Also had a cracked ceramic filter in a Futaba Rx. once that cost me Giles-II. Futaba said the filter cracked from a hard landing, or from the crash. Go figure! I've never used JR, but many of the guys at our field use JR and very happy with their products. Frankly, it seems that any of the known name brands produce good quality products with few failures, but nothing is ever 100%. Lord L, Joe is a bit more aggressive in placing the tank this far aft, but it appears to work well for him, though he does state that as the fuel drains from the tank this becomes more noticeable concerning the balance of the airplane. If I were going to do this I would first want the CG just a bit nose heavy for the maiden flight, and until I felt comfortable with the plane before moving it back. As the old saying goes, a slightly nose heavy plane will fly just fine, but a tail-heavy airplane won't fly. If you feel comfortable with flying a maiden flight with the tank in a more aggressive CG position then do it, but be prepared for the fuel drain changing the flying characteristics, which could catch a pilot off guard at first. Placing the tank in this position would certainly make the CG check more critical on a plane that has never been flown. I'm not questioning the position of it as much as I am simply wanting to make sure you are prepared for the unexpected with a plane you haven't flown yet. Would hate for you to get it up in the air and find it's squirrelly due to the CG becoming tail heavy as the fuel drains.
_____________________________
Good Luck and Good Flying, Roger
