arx_n_sparx
Joined: 2/9/2004 From: Burlington, ON, Status: offline
A note on power used: I have my PS set at just under 1/2 power (about 11:30 on the dial ) using this http://www.nsrca.org/technical/tip_tricks/foam_cutter/foam_cutting_power_supply.htm My cuts are NOT fast - typically about 5 inches per minute. Slow cuts are nicer cuts, and my kerf (the width of the cut) is small. I have a 4 1/2 foot bow, so we are not talking a wee one. I haven't tried a smaller bow yet, but I know less power will be needed. I haven't measured the resistance (ohms) of the wire, because it's a bogus number while cold - as soon as you put some current on it, the resistance will change (higher). I haven't measured the current either, as it won't be an RMS value, and I don't think my DVM can figure out "true current". I do know the voltage drop reads 14V across the bow, but again, it's not a true sine wave, so that number is subjective. So, to put it into laymans terms: Try it on some scrap foam, and find out what works for you! (hey, you thought I'd be able to give precise #'s? Think again!) It really is a bit of an art, and it's up to you to find just works best for YOUR rig. I had a problem at the start where the wire would literally oscillate up and down (I could see the wire twisting and untwisting as well) creating ripples in the cut. This meant (and I had to ask other people in that *other* forum) that I was cutting too fast/using too much feed speed. Just try your rig, and if you have problems, try posting in foamies "Help, my foam cutter is doing XXXXX! - How do I solve this?" I know i had to take as much friction out of the cutter I use as I could (My cutter just makes my own fan fold in whatever thickness I want, I don't cut "foils" with it). I had my probs at first, and the guys quickly jumped in to solve it for me. I guess I'm humble enough to ask advice when I need it. You've asked your question, so obviously you are humble enough too. You might get lucky and not need to ask again, but it's very reassuring to know that if you have a roblem, the folks here are quite willing to pitch in and help you solve it. I know I'm very grateful to TONS of people, and the only way I can "share the joy" is to put back as much into these forums as I take out - if not more. I love the net....... Brad
