Wet Engine.....
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> Wet Engine.....
Page: [1]
Login
Wet Engine..... - 2/2/2004 7:39:52 PM
hat11
Status: offline
I was driving my RS4 2 yester day and it went out of range, straight into a rather deep puddle.
I think the servos are ok but the engine is full of water, i tried to get most of the water out and need to know what else to before i run it again.
any suggestions would be appericated, thanks
       Post #: 1
RE: Wet Engine..... - 2/2/2004 8:03:36 PM
neap38
Status: offline
lube the engine
_____________________________
www.theipodlottery.com
(in reply to hat11)
       Post #: 2
RE: Wet Engine..... - 2/2/2004 8:04:09 PM
CaNaDiAnRaCeR
Status: offline
Quickly pull the whole engine apart and wipe each peice with paper towel. Your main problems are the bearings, they rust easily in days. Give each bearing a shot of WD-40 and you should be ok. Did and dirt get in the engine too?
(in reply to hat11)
       Post #: 3
RE: Wet Engine..... - 2/2/2004 8:15:56 PM
hat11
Status: offline
no, the engin is dirt free.
should i use some silicon lube if i have it instead of wd40?
thanks
(in reply to CaNaDiAnRaCeR)
       Post #: 4
RE: Wet Engine..... - 2/2/2004 8:18:54 PM
CaNaDiAnRaCeR
Status: offline
I'd recommend using WD-40 first because it displaces any water. Thats what the WD in WD-40 stands for, Water Displacment. you can use some thicker oils after but WD-40 is what you should use first.
(in reply to hat11)
       Post #: 5
RE: Wet Engine..... - 2/3/2004 1:28:07 PM
rs_andy
Status: offline
You shouldn't use silicon products in your engine, they can damage the rubber seals
       Post #: 6
RE: Wet Engine..... - 2/3/2004 1:31:44 PM
ammdrew
Status: offline
you should use marvel mistery oil, wd-40 is great to clean outthe motor but not to lube it.. also after run oil would work.. marvel is easier to come by and cheaper, also what works well is 3 in one oil.. but does not burn off as easy as marvel.
(in reply to rs_andy)
       Post #: 7
RE: Wet Engine..... - 2/3/2004 6:05:42 PM
rclooney
Status: offline
i just run mine and it turned out fine(ish)
(in reply to ammdrew)
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.344RCU2
