TT2
Joined: 3/19/2002 From: Osborn, MO, USA Status: offline
zippo I made forms from hotwire-cut extruded foam (Dow Grayboard) and vacuum-bagged 8 layers of 1.5 oz fiberglass to the form surface to strengthen it and to leave a glass-smooth finish. I used .014" waxed mylar as a carrier for the glass. My first attempt at making gear for a World Models Extra 300s went OK, but I experienced some buckling on one of the gear legs during layup which resulted in a slight delamination at that point. The buckling was caused by beginning to shape the laminate from the END of one leg instead of forming it from the center...duh! Last night was my second attempt. I used 17 layers of 5.7 oz CF plain weave and West Systems 105/205. After wetting out the CF, I stuck the sandwich in a vacuum bag between two sheets of plexiglass laminated to 3/4" thick melamine (particle board). After pulling a full vacuum (24" hg) for 2 hours, I pulled out the gear 'blank' to begin cutting the shape. I found that the epoxy had 'kicked' a bit more than expected, so cutting the shape was a very difficult task (during my first attempt, I found that cutting the shape was easy). I suppose that by having a thicker layup (I used 12 layers on my first attempt), the epoxy was more prone to exothermic reaction and cured a bit quicker. After I cut the laminate shape I again sandwiched it between the plexiglass / melamine and shoved it back into the vacuum bag just long enough to pull a full 24" hg vacuum. This will smooth-out any deformation that was caused by cutting the laminate. I removed the gear 'blank', shaped it around the form (from the center this time!), and covered it with the same .014" mylar used to laminate the fiberglass to the form. At this point the CF laminate was fairly stiff and didn't conform to the form 100%, but after examining the results this morning, I found that it's still entirely useable and looks VERY nice. A few thoughts: 1. I would have had much better results if I had not let the laminate cure so long. I think that the cure-time to laminate thickness is inversely proportional, and finding the right amount of cure-time will just require further experimentation. 2. I had used plain weave cloth from a 50" wide roll cut on a 45 degree bias. When using a plain weave cloth, orienting the fibers on a bias is nearly twice as strong as orienting them aligned with the gear lengthwise. Since you are using tape, I don't think that you can do this...unless you've found some bias-weave tape. 3. I am considering using uni-directional CF in the future. It's cheaper, easier to wet-out and the fibers would be optimally oriented. One could use a woven cloth on the first and last layers of the laminate to enhance appearance. My process is evolving, and I'm sure that I'll be churning out 100% perfect gear within a few more attempts. I need some for my Cermark Pitts, H9 Edge 540, AeroWorks Freedom 3D, and Sig Fazer. Thanks again for the tip! If you have any more suggestions or questions, please don't hesitate to discuss it here or offline. -Tom
_____________________________
As complexity approaches infinity, mean time before failure approaches zero...
