RE: Ever been injured by a spinning prop? Yes or No
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> The Clubhouse >> RE: Ever been injured by a spinning prop? Yes or No
Page: <<   < prev  1 2 [3]
[Poll]
No I have never been injured by a prop (knock on wood)
  35% (93)
Yes and it was caused by a momentary lack of concentration and respect
  59% (157)
Yes from an equipment malfunction (IE: radio glitch, broken prop, etc)
  3% (8)
Yes and it was due to the actions of another modeler.
  1% (4)
Total Votes : 262
(last vote on : 5/16/2009 9:47 PM)
(Poll will run till: -- )
Login
RE: Ever been injured by a spinning prop? Yes or No - 2/17/2004 2:29 PM
racer12306
Score: 100
Last Login: 7/14/2008
Status: offline
i was trying to start my little o.s. on a cold day and the prop stopped in the middle of compression and then it kicked back and hit my finger, no cut just some pain and a blood blister. now i enjoy r/c cars. still go.t the plane but havent been able to get it started
Hide Signatures
(in reply to CCRC1)
       Post #: 51
RE: Ever been injured by a spinning prop? Yes or No - 2/17/2004 11:18 PM
rfw1953
Score: 100
Last Login: 8/25/2007
Status: offline
Not a prop story but certainly related to one of those brain fart moments. I was soldering a metal clevis to the control rod for my Extra. I was using a a bottled propane torch when my hand holding the solder wiggled just enough to cause the still hard solder end to hit the new soft solder on the clevis. This small movement caused the hot molten solder to splatter back at me getting on my shirt. Just before I started the job I removed my glasses and put on safety goggles. None went on the goggle or my face, but this is about as close as I would want to get to the stuff. Glad I had goggles on.
_____________________________
Good Luck and Good Flying,
Roger
Hide Signatures
(in reply to racer12306)
       Post #: 52
RE: Ever been injured by a spinning prop? Yes or No - 2/19/2004 7:50 PM
PJC
Score: 100
Last Login: 5/14/2008
Status: offline
I answered no because I assume you were talking Serious stuff, I've been zapped pretty good by Electrics, and even some rubberband powered stuff... No blood I figure equates to a no...
Hide Signatures
(in reply to CCRC1)
       Post #: 53
RE: Ever been injured by a spinning prop? Yes or No - 2/19/2004 8:33 PM
Pale Rider
Score: 100
Last Login: 6/11/2009
Status: offline
Sliced my ring finger on an APC prop that was on my Saito .72.......IT WASN'T RUNNING!
I had just bolted on the prop in the basement and was checking to see if it was tight. As I turned the prop nut with a ratchet, I was holding the prop in my other hand, I looked down and it was bleeding! Just the pressure from tightening the prop nut was enough to make a bloody mess.
Hide Signatures
(in reply to PJC)
       Post #: 54
RE: Ever been injured by a spinning prop? Yes or No - 2/19/2004 9:11 PM
dicknadine
Score: 100
Last Login: 7/3/2009
Status: offline
after 20 stitch's. 2 left fingers -over 20 stitch's- no foreshortening- I now REMEMBER, A ROUND, STUPID, NOT THRU !!!!
dick/rcflyer
Hide Signatures
(in reply to CCRC1)
       Post #: 55
RE: RE: Ever been injured by a spinning prop? Yes or No - 2/20/2004 12:25 AM
dalolyn
Score: 100
Last Login: 7/4/2009
Status: offline
Came to close but never has happened to me. One flying buddy almost had his finger cut through.Didnt teach him anything though. He is a loner and the way he handles his profole fun flies when starting and tuning its no wonder, it will happen again.Thats why we set up at least 30 to 40 feet away from him. He is not a bad flier though just bad ground habits. I have cut my finger on a master airscrew glass prop forgot to sand the edges.
Hide Signatures
(in reply to dicknadine)
       Post #: 56
RE: RE: Ever been injured by a spinning prop? Yes or No - 2/20/2004 3:22 AM
silvercloud-RCU
Score: 100
Last Login: 1/11/2005
Status: offline
I got wacked about 1 1/2 years ago from a reflex reaction I started the plane and released it and it started to roll toward me and I put my hand down on top of the prop to stop it duh! the plane holder would have stopped it .But got 10 sticthes and nerve damage on the outside egde of my hand and can't feel anything in my pinky so now I make it A point to have sombody help me out.[image][/image]
Hide Signatures
(in reply to dalolyn)
       Post #: 57
RE: RE: Ever been injured by a spinning prop? Yes or No - 2/20/2004 12:09 PM
jettstarblue
Score: 100
Last Login: 2/18/2009
Status: offline
I've been cut, whacked, bruised, split, everything but broken. I've lost enough blood from these little monsters, that I could have given myself transfusions.
The TWO worst were adjusting the NV on a buddy's S.T. 61 and I caught the BACK of my knuckle on the BACK of the prop, and starting (same engine, glad it was not mine) the prop stopped mid arc, and cut a slice out of my middle finger from the second knuckle to the tip, down to the bone. Got a doozy on the back of my right hand from....well I got lots!
I'll post pictures of my mangled hands if it will help anyone.
Jetts
Self employed genius visionary
Hide Signatures
(in reply to silvercloud-RCU)
       Post #: 58
RE: Ever been injured by a spinning prop? Yes or No - 3/21/2004 4:26 AM
Cryhavoc
Score: 100
Last Login: 1/21/2009
Status: offline
Just got back from the emergency rm. Had an OS 160 w/18X6 prop slice up my little finger, take off my third finger at the knuckle and a nice chunk off my middle one. Ouch! BE CAREFUL.
Cryhavoc!
Hide Signatures
(in reply to jettstarblue)
       Post #: 59
RE: Ever been injured by a spinning prop? Yes or No - 3/21/2004 5:32 PM
Dzlstunter
Score: 100
Last Login: 7/2/2009
Status: offline
You need to add a catagory for multiple prop strikes in my case. Not with diesels, either (so far). I have a skin graft from one of them, and a couple of scars, too! All these resulted from adjusting the needle valve on glow two strokes from the side or from the front. I don't do that anymore, and I am obnoxious enough to say something to others when they do--but only once. After that, they are on their own. Dzl
If it doesn't stink, it's not a diesel.
Hide Signatures
(in reply to Mike in DC)
       Post #: 60
RE: Ever been injured by a spinning prop? Yes or No - 3/21/2004 6:00 PM
Nick Hudson
Score: 100
Last Login: 6/28/2009
Status: offline
Funny to see this after last week. I have moved and now in a position in which I'm flying by myself and had a scare last week. I know I shouldn't be flying alone but thats the way it is. I was starting a Sig Wonder on a spool to support it and when it came to life it caught my shirt and wrapped itself into it cutting it about 30 times before dying. I didn't cut myself but it scared the heck out of me and now I'll never fly a hand launch like it again by myself. I just keep thinking what would of happend if it wopuld of got into my gut, even though it would of just caught belly fat.
< Message edited by Nick Hudson -- 3/21/2004 6:02:10 PM >
Hide Signatures
(in reply to SDR-Hammer)
       Post #: 61
RE: Ever been injured by a spinning prop? Yes or No - 3/21/2004 11:45 PM
jedi
Score: 100
Last Login: 12/18/2005
Status: offline
I also have had the "oops, I guess I can't reach through the prop" accident.
Now I am very fearful of that spinning bad boy, and I also teach my students to be fearful of it also.
If you always tell the truth, you never have to remember what you've said.... --Mark Twain
Hide Signatures
(in reply to Nick Hudson)
       Post #: 62
RE: Ever been injured by a spinning prop? Yes or No - 4/8/2004 6:51 AM
kamakasi
Score: 100
Last Login: 10/30/2007
Status: offline
Started in CL and have bashed the knuckles many times due to kick back. I only tried to adjust the needle by reaching through the prop once. I guess I'm a quick learner.
The older I get... The better I was...
Hide Signatures
(in reply to CCRC1)
       Post #: 63
RE: Ever been injured by a spinning prop? Yes or No - 4/8/2004 8:25 AM
Flyboy Dave
Score: 100
Status: offline
On a twin engine plane always start the engine on the other side of the
plane first. I started the engine next to me first....then while starting the other
one, I stuck my left hand into the running one....BAM....goodbye left thumb
nail....(that smarted).
Luckily it was only a .40 size engine and it was idleing.
Dave.
An engineer says.... "That won''''t work".
A mechanic says..."Oh yeah, watch this".
"Old Age, and Treachery will overcome youth and skill".
Revver Bro #4.
Hide Signatures
(in reply to kamakasi)
       Post #: 64
RE: Ever been injured by a spinning prop? Yes or No - 4/21/2004 11:38 AM
a65l
Score: 100
Last Login: 6/17/2009
Status: offline
This is mine, stuck finger in idling Super Tigre .40 because I was worried cheek piece might have broken away from firewall during deadstick into grass. 12 stitches but it's almost completely healed now.
Click to see fullsize image.
Click for fullsize
Hide Signatures
(in reply to Flyboy Dave)
       Post #: 65
RE: Ever been injured by a spinning prop? Yes or No - 4/21/2004 1:15 PM
aaron2874
Score: 100
Last Login: 9/12/2008
Status: offline
My girlfriend grabbed my Zinger 22x10 and popped me on the head for talking too much smack... Does that count?
24 hours in a day. 24 beers in a case. Coincidence? I think not!
Hide Signatures
(in reply to CCRC1)
       Post #: 66
RE: Ever been injured by a spinning prop? Yes or No - 4/21/2004 4:30 PM
FLYBOY
Score: 100
Status: offline
quote:
ORIGINAL: aaron2874
Thats too funny!!!!!
Fly it till the wings come off.
Hide Signatures
(in reply to aaron2874)
       Post #: 67
RE: Ever been injured by a spinning prop? Yes or No - 4/21/2004 11:26 PM
dicknadine
Score: 100
Status: offline
sure done that, 28 stiches to left thumb and 1st finger. tried to adjust needle valve thru the screeming prop. my dr. (a buddie) just about fainted when I showed at his clinic and I had to take photos before he sewed me up. Photos were posted on our field bulletin for a long time. will try to find photos, some place in couple hundred floppies. lost some feeling and use to them -- fortunitly not the diddle finger. dick
Hide Signatures
(in reply to FLYBOY)
       Post #: 68
RE: Ever been injured by a spinning prop? Yes or No - 5/12/2004 12:33 AM
AdamB
Score: 100
Last Login: 1/6/2008
Status: offline
I've been flying many years, when last Friday I started my plane and moved behind her to adjust mixture screw. I reached with my right hand over the plane (screw on left side) and gave her a 1/4 turn rich. Pinky and ring finger started up, rotated right into Tower Hobbies .46.
Motor didn't shut off, and prop didn't break. I sliced a tendon, and needed skin graft on pinky. Ring finger just needed stitches...
Click for fullsize
-Quick 46 Carbon Pro
-Shuttle Plus
Hide Signatures
       Post #: 69
RE: Ever been injured by a spinning prop? Yes or No - 5/12/2004 1:12 AM
FHHuber
Score: 100
Last Login: 5/13/2004
Status: offline
severity of injury varies widely... you can count a "paper cut" type nick from the TE of an APC prop as an injury
Spinning prop... I have had little nicks from the little 0.049 Cox engines, trying to get my clumsy fingers onto the needle valve. Nothing worse than paper cut style from those... but when the glow fuel gets in them... OOOOooow! (the little cuts always seem to hurt worse than the bad ones why?)
Its the "not yet spinning" prop that bit me the deepest... choking an engine with glow attached and it "kicked" back slicing a finger open... then my jerking my hand out allowed the engine to start. (so its debateable... was it spinning? not till after I let go AFTER being cut. ) Just a few stitches...
I have since learned... you don't have the glow attached unless you want the engine to fire. I also learned to never fly alone again that day.
Hide Signatures
       Post #: 70
RE: Ever been injured by a spinning prop? Yes or No - 5/12/2004 6:47 AM
Sir Fliesalot
Score: 100
Last Login: 6/13/2009
Status: offline
Well at least not an old modeler eh? Thanks for bringing that childhood memory back! If you've been around props for long then you've been hit. My most recent smack was a G-62's 22" prop on kick back. I was glad I had my glove on. It felt just like I smashed my finger my a hammer. Luckily I just got a blood blister with that one but it woke me up and it won't happen again (I hope).
Hide Signatures
(in reply to CCRC1)
       Post #: 71
RE: Ever been injured by a spinning prop? Yes or No - 5/12/2004 6:32 PM
H. Wayne S
Score: 100
Last Login: 6/30/2009
Status: offline
I've been poped, sliced, ripped and injured by these prop things just about every way you can imagine. But the one that stands out and I will never forget was when part of the 28 X8 wood prop of a running engine came off during run-up and hit my thumb impeling itself about one inch before the bone stopped it. If I had been standing six inches over it would have gone in my stomach. I never stand next to any engine when the thing is running anylonger.
Hide Signatures
(in reply to Sir Fliesalot)
       Post #: 72
RE: Ever been injured by a spinning prop? Yes or No - 6/29/2004 7:47 PM
miken96-RCU
Score: 100
Last Login: 9/23/2004
Status: offline
Brain Farted and stuck my right hand through the spinning prop to adjust the high end setting. 39 Stitches in 3 fingers later, I learned a VALUABLE lesson!!!! Didn't loose any fingers , but after 1 1/2 years, I still have no feeling in the tip of my thumb or index finger.
Hide Signatures
(in reply to CCRC1)
       Post #: 73
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
10.359RCU1
