CorsairJock
MI, USA Status: offline
quote:
ORIGINAL: Kmot mugenkidd, another excellent point about the 2 vs 4. You are absolutely right, in that when a kit is listed as a 60 to 90 they say .60 two stroke or a .90 four stroke. I think that is what I had in the back of my mind when I added that to the poll. Surely a .60 two stroke weighs less than a .90 four stroke? But still, the fact that for equal displcements, a four stroke weighing less than a two stroke is a significant acheivment in my way of thinking. I have not run the .40 yet. Saito claims it will swing a 11 x 6 with ease. I HAVE run the Saito .30. Saito claims it will swing a 10 x 6 at 10,000 RPM. They also say it is the .30 that thinks it's a .40. I have found both to be true, using 15% nitro, 19% oil fuel. I now have an 11 x 5 on it (the .30, try THAT with your 2 stroke .25 ), and it makes my 3 lb, 10 oz. Cub leap off the ground in a few feet, and from there it will nearly go vertical. It will hold knife edge flight. The old addage that 4 strokes are vastly inferior to 2 strokes when compared on an equal displacement basis are no longer true. The YS .63 is a 4 stroke that will outperform many .60 2 strokes. Then there is the Saito .72 which I mentioned that is in my Corsair: this is a kit which calls for a 2 stroke .60 (minimum). And while I don't claim my .72 is as strong as a .72 2 stroke would be, it is not that far off either. Many of todays kits were designed at a time when there WAS a substantial difference in power between 2 strokes and 4 strokes. Those days are gone.
< Message edited by CorsairJock -- 2/8/2004 12:46:22 AM >
_____________________________
Avatar: Electric Powered, Highly Modified Hangar 9 Corsair
