More T6XA Problems
Tower Hobbies
Logged in as Guest
  Printable Version
Futaba 12ZAP 72mhz/FASST complete plus...
Seller:  sevans16
Details:   $1,200.00   |  9/30/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> More T6XA Problems
Page: [1]
Login
More T6XA Problems - 2/6/2004 11:00:48 PM
barkin_bob
Status: offline
Thanks again Stick Jammer for the info. on my mode problem. But I have one more problem with this radio, it's with the throttle trim. When the throttle stick is centered the trim adjustment works fine,but when the stick is moved in either direction the trim adjuster quits working. I tried using the sub-trim but that did not work (just gave me some movement or no movement at half stick). I can't find anything in the manual that would cover this problem. Any suggestions would be helpful. Thanks
_____________________________
       Post #: 1
RE: More T6XA Problems - 2/6/2004 11:28:21 PM
Stick Jammer
Status: offline
The throttle stick action needs to be set to normal. Turn on the transmitter while holding down the two MODE buttons. Then press either MODE button to get to the TREV menu. Use the (+) or (-) key to switch from reversed to normal.
(in reply to barkin_bob)
       Post #: 2
RE: More T6XA Problems - 2/7/2004 12:24:25 AM
barkin_bob
Status: offline
Thats 2 for 2 , thanks again Stick Jammer. That did the trick. Now can you teach me how to fly.( LOL) just joking. HAPPY FLYIN again THANK YOU
(in reply to Stick Jammer)
       Post #: 3
RE: More T6XA Problems - 2/7/2004 12:27:31 AM
Stick Jammer
Status: offline
You're quite welcome and happy flying to you also!
       Post #: 4
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.375RCU1
