OMP Yak build    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> OMP Yak build
Page: [1] 2 3 4 5 6 7 8 9 10   next >   >>
Login
OMP Yak build - 2/7/2004 3:42 PM
jmulder
Score: 100
Last Login: 2/11/2011
Status: offline
On the sheeting I used Gluit white glue. I stuck my sheeting down on wax paper using a spray glue. It releases when you are done. I cut the sheets as per instructions and I used left over wood from my scrap box for the canopy so I wouldnt have another seem there.
Click to see fullsize image.
Click for fullsize
Hide Signatures
       Post #: 1
RE: OMP Yak build - 2/7/2004 3:45 PM
jmulder
Score: 100
Status: offline
I also made my sheeting so that the seems would be opposite each other on each side of the fuse.
Hide Signatures
(in reply to jmulder)
       Post #: 2
RE: OMP Yak build - 2/7/2004 3:55 PM
jmulder
Score: 100
Status: offline
The stab and Ele. were very simple to build. I found that the wood was pretty good although some of it was hard. It worked out great though because I used the hardest wood for the LE on my moving surfaces.
Click for fullsize
Hide Signatures
       Post #: 3
RE: OMP Yak build - 2/7/2004 3:58 PM
jmulder
Score: 100
Status: offline
You may notice that I havent glued in my corner braces yet. Im not over looking it I just havent done it yet.
Click for fullsize
Hide Signatures
       Post #: 4
RE: OMP Yak build - 2/7/2004 4:02 PM
jmulder
Score: 100
Status: offline
I must have got one of the first kits out because I didnt have the ele joining wire. I really dont like to use wire on my ele. I like the hardwood setup myself. It just seem to be stiffer in the center than the wire. I always sheet the area over the glue joints.
Hide Signatures
       Post #: 5
RE: OMP Yak build - 2/7/2004 4:05 PM
jmulder
Score: 100
Status: offline
I also enlarged the ele. by 3/8 on the TE.
Hide Signatures
       Post #: 6
RE: OMP Yak build - 2/7/2004 4:07 PM
jmulder
Score: 100
Status: offline
The rudder went together as easily as the rest. As you can easily see I enlarged the rudder pretty good. Dont ask......I just like a RUDDER.
Click for fullsize
Hide Signatures
       Post #: 7
RE: OMP Yak build - 2/7/2004 4:12 PM
jmulder
Score: 100
Status: offline
The corner blocks are not glued in the rudder either. It looks strange without em.
Hide Signatures
       Post #: 8
RE: OMP Yak build - 2/7/2004 4:16 PM
jmulder
Score: 100
Status: offline
The ailerons are built as per plans.
Click for fullsize
Hide Signatures
       Post #: 9
RE: OMP Yak build - 2/7/2004 4:44 PM
jmulder
Score: 100
Status: offline
This is going to be a meaty plane. The 80'' Edge is huge but I got to tell ya....This one aint no baby!!
Hide Signatures
       Post #: 10
RE: OMP Yak build - 2/7/2004 8:36 PM
novabill
Score: 100
Last Login: 5/5/2013
Status: offline
Looking good man,
Thanks for the step by step and pics.
Hide Signatures
       Post #: 11
RE: OMP Yak build - 2/7/2004 8:44 PM
jmulder
Score: 100
Status: offline
Thanks Bro!! More to come....But not today. Working on another one right now......................................John
Hide Signatures
(in reply to novabill)
       Post #: 12
RE: OMP Yak build - 2/7/2004 9:12 PM
STEVE LENZ
Score: 100
Last Login: 11/8/2004
Status: offline
John I am looking to see more. I am going to build the 60 Yak OMP size when I get the bird off the table I am working on . You sad you sheet jointed areas can you explane I could not tell from pic how much you sheet for support?. Thanks for your time and pics giving a report on your build. Keep up the good work. I will be looking Steve
< Message edited by steve L-RCU -- 2/7/2004 6:18:11 PM >
Hide Signatures
       Post #: 13
RE: OMP Yak build - 2/7/2004 10:35 PM
jmulder
Score: 100
Status: offline
The entire fuse is sheeted with 1/16 balsa sheets. I did as the instructions suggested because I thought that would be the best way as well.. The instructions said to cut 4, 36'' sheets into 24'' and 12'' sheets. Or in other words cut 12'' off of one end. Then you have made eight 24'' sheets and eight 12'' sheets from the four 36'' sheets. These sheets, plus the remaining four 36'' sheets are glued together to from the fuse sheeting for both sides of the fuse. If you'll look close in the sheeting picture youll see that there are three seams. The botton sheet has a seam on the right. That is a 24'' sheet and a 12'' sheet on the right of it. The center sheet is two 36'' sheets together with a seam in the middle. The top is a 12'' sheet on the left and a 24'' sheet on the right. The sheeting for the other side of the fuse is opposite of this because I didnt want to have the same seam on both sides at the same place. Just seems to be reasonable to me for strength.
Hide Signatures
(in reply to STEVE LENZ)
       Post #: 14
RE: OMP Yak build - 2/7/2004 10:36 PM
jmulder
Score: 100
Status: offline
If that doesnt explain I can take more pics........................John
Hide Signatures
       Post #: 15
RE: OMP Yak build - 2/8/2004 12:36 AM
STEVE LENZ
Score: 100
Status: offline
Ok got it on the sheeting. What engine are you planning to use? SL
Hide Signatures
       Post #: 16
RE: OMP Yak build - 2/8/2004 12:39 AM
jmulder
Score: 100
Status: offline
Either a Saito 100 or a YS 61 on a pipe............John
Hide Signatures
       Post #: 17
OMP Yak right wing - 2/8/2004 6:26 AM
m.gramling
Score: 101
Last Login: 8/30/2012
Status: offline
Here is what I have done on my right wing.
It went together well.
In 1 weeks time
I have the fuselage, almost done,
horizontal stab and elevator done, except for the joiner wire
Vertical stab and rudder complete,
and this much on the right wing.
I lost almost a 1/2 hour trying to fiqure something out that was in the instructions. that I new I read, but I couldn't find it again. but after I figured it out, I saw it in the instructions.
on the right wing, rib-R1, the tab that bolts to fuselage points UP. (Thats the part it took me a little while to figure out.) Then your servo rails in your wing rib are facing up.
On the left wing, when you build it, the rib-R1 the tab that bolts to the fuse points DOWN. then the servo rails in our wing rib are facing down
Click for fullsize
< Message edited by m.gramling -- 2/7/2004 9:29:13 PM >
_____________________________
Everybody wants to go to heaven, but nobody wants to die...
Hide Signatures
       Post #: 18
RE: OMP Yak right wing - 2/9/2004 3:08 AM
STEVE LENZ
Score: 100
Status: offline
John Saito 100 get's my vote I have one on my U-CAN-DO it will be great for that plane. I think yours will build lighter than the U-CAN-DO. I have a new one waiting for a plane after reading flying reports on the YAK. Here a few pic of the real Yak's. And one the air show two years ago here at WA Seafair Sunday I took them from the internet . I got to see it fly What a plane it sold me.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to m.gramling)
       Post #: 19
RE: OMP Yak right wing - 2/9/2004 4:56 PM
AFSalmon
Score: 100
Last Login: 12/8/2011
Status: offline
Nice building thread guys.
One note though as the designer: The rudder has all the authority you can want in the stock size. Making it any bigger might cause the prop to hit the rudder when spinning! ha ha
Mike
Hide Signatures
       Post #: 20
RE: OMP Yak right wing - 2/9/2004 6:57 PM
SMALLFLY-
Score: 100
Last Login: 5/15/2012
Status: offline
How much more would it have had to cost to get both wing panels printed in the plans, having to remember to reverse everything on the second wing seems needlessly complicated to me. Also why not put the wing tube in first before the ribs go down on the bottom spar. Im doing that myself, since the rib holes needs to be sanded a bit to get them to fit doing it after the wing is built can be a pita. Im not really complaining, but I can see where this might be tough for a new builder. So far It has been a fast and relatively easy build for me, The wing is very similar to the HRCMS ecstacy I built almost 2 years ago. But a newbie builder could have problems
Hide Signatures
(in reply to AFSalmon)
       Post #: 21
RE: OMP Yak right wing - 2/9/2004 10:42 PM
tetherite
Score: 100
Last Login: 5/2/2012
Status: offline
Why not just turn the plans over, wipe with little sewing machine oil on the backside (in wing area) and behold! Left wing plans. Then use some wax paper for a seal for the wood!
Just a thot!
Ray
Ray Randolph
E-mail/PayPal; tetherite@earthlink.net
Hide Signatures
(in reply to SMALLFLY-)
       Post #: 22
RE: OMP Yak right wing - 2/9/2004 10:49 PM
AFSalmon
Score: 100
Status: offline
Smallfly,
Yea it would cost almost $100 more just to print that extra wing panel! ha ha, no maybe only 99 bucks but really it's not complicated at all. Both wings are exactly the same except for the servo side and the rear tab of R1. The wings are quad tapered fully symetrical. It's not uncommon to have one wing plan for this style of building. Really the only thing to remember is flipping the R1 over the second time around. The servo bay is thus still built on the first side before flipping the wing over to sheet the other side. Seems pretty clear cut to me but then again I've done so many wings it seems natural to me. Nothing wrong with inserting the socket first either but I would definately not recommend gluing it in place until the rest of the structure is aligned, glued, and secure in place.
Mike
Hide Signatures
       Post #: 23
RE: OMP Yak right wing - 2/10/2004 12:08 AM
SMALLFLY-
Score: 100
Status: offline
One more question because Im not at home to see the info but as your building the right wing the rib guide tips the ribs towards the tip end at 89.5 degrees, when you build the left panel do you reverse that and and lean to the root?
Hide Signatures
       Post #: 24
RE: OMP Yak build - 2/10/2004 3:50 AM
joebob
Score: 100
Last Login: 5/18/2013
Status: offline
I was really interested in this thread because I was planning on getting one of these real soon. Unfortunately, the better half shot down my earnest request. Something about paying bills, I think. The 'NO' ringing in my ears kind of drowned out everything after that. So now, I sit with my tail between my legs, whimpering in the corner. Oh well, maybe one day...
Hide Signatures
       Post #: 25
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.531RCU1
