RE: Cheap Tips and Tricks
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Traxxas Monster Truck forum >> RE: Cheap Tips and Tricks
Page: <<   < prev  1 [2]
Login
RE: Cheap Tips and Tricks - 2/10/2004 6:14:03 PM
jefx
Status: offline
I got an old 2.5 piston on my keychain.
(in reply to allmaxxedout)
       Post #: 26
RE: Cheap Tips and Tricks - 2/11/2004 1:25:13 AM
memoss
Status: offline
I read in some form that if you use Marval Mystery Oil in your fuel it will make it last a lot longer and with lower running temps, but if you do use it only put in 1 or 2 drops per tank
Click to see fullsize image.
Click for fullsize
< Message edited by memoss -- 2/11/2004 1:23:37 AM >
(in reply to jefx)
       Post #: 27
RE: Cheap Tips and Tricks - 2/11/2004 1:46:16 AM
FISCHE
Status: offline
Another fail safe idea is take a small rubber band (childrens' hair bands) and put them over the ball stud on the end of the slide carb and around the air filter opening. this will pull the carb shut with low batteries.
(in reply to memoss)
       Post #: 28
RE: Cheap Tips and Tricks - 2/11/2004 2:11:50 AM
378
Status: offline
the band wont be able to pull a non coreless servo shut
_____________________________
MY truck: CEN MT2, OS .18 CV-RX w/ 11J carb
Futaba 2DR 2C H AM stick radio on CH90. Alum. rear shocks.
(in reply to FISCHE)
       Post #: 29
RE: Cheap Tips and Tricks - 2/12/2004 12:48:00 AM
memoss
Status: offline
To get a new look on your wheels you can use oven cleaner to get the fake crome stuff off and then Dye them any color you want.
I made mine Red.
I used RIT dye
you can also do this to Servo Savers and Bumpers or almost anything that is white if you clean it.
Here's a pic but its not mine
Click for fullsize
< Message edited by memoss -- 2/12/2004 12:51:53 AM >
(in reply to 378)
       Post #: 30
RE: Cheap Tips and Tricks - 2/12/2004 1:30:59 AM
zsportmaxx
Status: offline
spray paint rims after they are cleaned it works too
       Post #: 31
RE: Cheap Tips and Tricks - 2/12/2004 2:32:44 AM
memoss
Status: offline
quote:
ORIGINAL: zsportmaxx
You can do that but mine always scraches off
(in reply to zsportmaxx)
       Post #: 32
RE: Cheap Tips and Tricks - 2/12/2004 5:57:19 PM
retic517
Status: offline
Next time you strip your truck down spray the stock chasis, if you still have one, with Easy off oven cleaner, let it soak 10-20 minutes and rinse. You can you a green scuff pad to remove the rest of the anodization. When its just ugly aluminum get you a can of Never Dull in the auto/boat section of Wal-Mart and polish away. It takes about three hours and some elbo grease but you will get a mirror like finish. for under $10.00.
       Post #: 33
RE: Cheap Tips and Tricks - 2/13/2004 1:59:34 AM
spazzyfry123
Status: offline
quote:
ORIGINAL: retic517
That actually sounds like a great idea, but I'm not really up to take everything apart. I just finished installing a new engine and some other stuff.
I'm white
(in reply to retic517)
       Post #: 34
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
1.203RCU1
