Cheap Tips and Tricks
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> Traxxas Monster Truck forum >> Cheap Tips and Tricks
Page: [1] 2   next >   >>
Login
Cheap Tips and Tricks - 2/7/2004 2:46:15 PM
zsportmaxx
Status: offline
post cheap tips and tricks
       Post #: 1
RE: Cheap Tips and Tricks - 2/7/2004 3:31:06 PM
wakbrdr
Status: offline
balloon radio box and servos, and shock springs
(in reply to zsportmaxx)
       Post #: 2
RE: Cheap Tips and Tricks - 2/7/2004 5:41:54 PM
mrjason82
Status: offline
Here's two that someone posted a while back and I bookmarked them, haven't used them myself but looked pretty cool...
Shock Balloons- http://www.jagrc.com/water/shock.html
Sping Diff Mod- http://www.jagrc.com/springdiff/springdiff.html
_____________________________
CEN MT2
Sportmaxx w/ 4wd and two speed- FLM chassis, bulkheads, RPM stuff, JR servos, too much other stuff
(in reply to wakbrdr)
       Post #: 3
RE: Cheap Tips and Tricks - 2/7/2004 10:51:43 PM
ntrospeed04
Status: offline
has anyone done that spinrg differential mod?
(in reply to mrjason82)
       Post #: 4
RE: Cheap Tips and Tricks - 2/8/2004 12:00:17 AM
Model Mania
Status: offline
Those are pretty good ideas
(in reply to ntrospeed04)
       Post #: 5
RE: Cheap Tips and Tricks - 2/8/2004 12:21:32 AM
wakbrdr
Status: offline
i though about it but it seemed to me like it would wear out your diff cups faster, just put something very thick in the spider gearsso its hard for them to turn
(in reply to Model Mania)
       Post #: 6
RE: Cheap Tips and Tricks - 2/8/2004 1:04:50 AM
mrjason82
Status: offline
I didn't try the spring thing but I did use the diff locking grease that I got from my LHS. That worked very well and I liked it but on my sportmaxx it blew out the screws. I've found that there is an aluminum diff setup that someone makes and after I get that I will put the diff locking grease back in.
CEN MT2
       Post #: 7
RE: Cheap Tips and Tricks - 2/8/2004 8:47:09 PM
zsportmaxx
Status: offline
check out my reusable glow plugs forum
       Post #: 8
RE: Cheap Tips and Tricks - 2/9/2004 6:31:19 AM
378
Status: offline
thread a zip tie thru the fuel tank lid the hole is already there then thread it into the other end pull it tight and route it up voila fuel tank acces so u can refill with it runnin faster and safer
MY truck: CEN MT2, OS .18 CV-RX w/ 11J carb
Futaba 2DR 2C H AM stick radio on CH90. Alum. rear shocks.
       Post #: 9
RE: Cheap Tips and Tricks - 2/9/2004 5:16:41 PM
jefx
Status: offline
Better yet, take a 2 inch piece of fuel tubing and a 5 inch (or longer) zip tie. Thread the zip tie through the fuel tubing until the head of the zip tie hits the fuel tubing. Take the exposed zip tie and thread it through the hole in the fuel cap. Double back and thread it back up throught the fuel tube so both the head and the tail of the zip tie are sticking out the top. Zip the zip tie as far as you can, then cut off the excess. BAM, a thick and durable fuel lid handle that will stay upright.
(in reply to 378)
       Post #: 10
RE: Cheap Tips and Tricks - 2/9/2004 7:30:51 PM
378
Status: offline
mine is simpler and will stay up if u zip it right and all u need is a zip tie mine uses the body for added support in the event of a rollover tho
(in reply to jefx)
       Post #: 11
RE: Cheap Tips and Tricks - 2/10/2004 12:07:50 AM
memoss
Status: offline
quote:
ORIGINAL: zsportmaxx
Can you poast a link or tell us where it is
       Post #: 12
RE: Cheap Tips and Tricks - 2/10/2004 12:09:49 AM
378
Status: offline
its in the maxx forum someplace
(in reply to memoss)
       Post #: 13
RE: Cheap Tips and Tricks - 2/10/2004 12:12:45 AM
memoss
Status: offline
quote:
ORIGINAL: 378
whats it called?
(in reply to 378)
       Post #: 14
RE: Cheap Tips and Tricks - 2/10/2004 12:14:33 AM
378
Status: offline
i dont remember but i looked at it yesterday so it aint that far back in history ill try to find it u look too
       Post #: 15
RE: Cheap Tips and Tricks - 2/10/2004 12:18:56 AM
memoss
Status: offline
quote:
ORIGINAL: 378
thanks I found it
(in reply to 378)
