Spad 3 D - with what I have ?? - Quick response pls.
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> S.P.A.D. Aircraft - Coroplast design >> Spad 3 D - with what I have ?? - Quick response pls.
Page: [1]
Login
Spad 3 D - with what I have ?? - Quick response pls. - 2/7/2004 4:22:13 PM
Zafer
Status: offline
Hi everybody,
Back in 3D flying forum, people convinced me for building a SPAD 3D. I made a quick search and I found following items.
Could you please tell me if I can built the SPAD 3D or PQHOR without changing the original plans with shorter wing spans.
And I think I should re-arrange the thickness of the wing since I have thicker coroplast ( 6 mm ).
1- Policarbon sheet 6 mm thick ( couldn't get 4 mm ) which is 29" by 40". That means I can only have a wing span of 29".
2- 0,40 o.s. FP engine.
3- kitchen cutting plastic.
4- Aluminum rail ( U shaped but a little bit narrow )
5- Aluminum sheet 1/2" wide.
6-Some PVC (scarped)
7- Some piano wires.
8- 4 - Hitec 311 servos
9- receiver battery pack (new enough) and 1 receiver,
10 - I have no landing gear material at the moment (sure I will get something).
What do you think now. is this plastic too much (and heavy), and for 29" wing span 0.40 motor is too much. Or can I use sheet in other way ( I mean Can I place the flutes vertical). Will the wing be folding immediately?
Help will be appreciated. Thank you all in advance.
Regards.
Zafer
< Message edited by Zafer -- 2/7/2004 4:20:01 PM >
       Post #: 1
RE: Spad 3 D - with what I have ?? - Quick response pls. - 2/7/2004 5:11:18 PM
novabill
Status: offline
The origonal QHOR was 30" WS and used a .20-.30 engine. If your coro is really stiff (I imagine 6mm is) you should be able to eliminate the MW in the wing. It will probably make up for the weight difference in the coro. Some people have the .40 FP on the small WS planes. If you build it with a 29" WS, you will only be giving up 16" in wing area that can probably be made up with another 3/4" in the cord. Use 5/32" MW for the landing gear and small ultralight wheels. If your servos dont fit into the channell, you can mount them on the sides. Remember, these planes arent designed to fly fast so manage your throttle.
If it were me, I would try it. If you want the SPA3D, use the small QHOR dimensions and the SPA3D build technique.
William
(in reply to Zafer)
       Post #: 2
RE: Spad 3 D - with what I have ?? - Quick response pls. - 2/8/2004 9:57:23 PM
Zafer
Status: offline
Novabill,
I just started building it, Wing is 29" x 20", with a OS .40 FP, As you suggested qhor sized spa3d.
We will see, how it does, I am thinking of using 12,25" x 3,75 prop. Will it be good or Should I use something like 10x6.
I think plane will be a bit tail heavy due to the 6mm. coroplast. I have no idea what it should weight.
I think I will also have some orientation problems since coro is transparent. It is better if I cover it maybe... I will also use shorter fuse ( it will be 30"
It is fun project if it flies I will be glad.
Regards.
Zafer
< Message edited by Zafer -- 2/8/2004 10:00:51 PM >
(in reply to novabill)
       Post #: 3
RE: Spad 3 D - with what I have ?? - Quick response pls. - 2/9/2004 1:06:34 AM
novabill
Status: offline
I'm thinking an 11x4 or 11x5 and they will be 1/2 the price of the 12.25x3.75.
Do'nt worry about balance until you install the radio gear and if it is still tailheavy you can slide the wing back to compensate. Hopefully you can come in around 4#, but I had a 36" that flew well at 5.5#. You save weight with MW landing gear, ultra light wheels, no tail wheel, just a skid and lightening on the motor mount, leave the spinner off and if the wing is really stiff with the 6mm leave out the MW in it. Just be really careful the first few flights and watch for flapping wings. It will fly, do'nt worry about that. And boy will it roll fast too.
William
(in reply to Zafer)
       Post #: 4
RE: Spad 3 D - with what I have ?? - Quick response pls. - 2/9/2004 9:02:07 PM
Zafer
Status: offline
Hi everyone,
This is how my spa3d comes. I hope it flies when finished
Regards.
Zafer
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 5
RE: Spad 3 D - with what I have ?? - Quick response pls. - 2/10/2004 12:10:17 AM
novabill
Status: offline
Looking great,
It will fly
William
(in reply to Zafer)
       Post #: 6
RE: Spad 3 D - with what I have ?? - Quick response pls. - 2/10/2004 12:27:39 AM
crazycap
Status: offline
Zafer
My first airplane built it with 4mm POLICARBON because the only coroplast that there is here in Argentina is of 2mm.
After several flights the Policarbon and the hinges began to break.
After a lot to look for I finally got coroplast in 4mm.
I suggest you that you make a search in the forum, to see if there is some member of your country and he can inform you where to buy coroplast
BTW good job.
_____________________________
English is not my native language, please excuse me for my English!!!.
       Post #: 7
RE: Spad 3 D - with what I have ?? - Quick response pls. - 2/10/2004 12:50:54 AM
jlguru
Status: offline
Go here:
http://www.spadtothebone.com/SPAD/Mufflers/
and read about Mousse Can Mufflers. Put one
of these on that OS40FP and you will be
making nearly as much power as a 46 motor,
and with better throttle response.
Been there ... done that.
Live long, and prosper
Jerry L. Gubka
(in reply to crazycap)
       Post #: 8
RE: Spad 3 D - with what I have ?? - Quick response pls. - 2/10/2004 2:23:31 AM
ben flyn
Status: offline
The problem with "POLICARBON" or Dupont's "LEXAN" (know as polycarbonite), is when fuel gets on it, the nitro in the fuel will make it brittle. I tried 1/2" thick Lexan for an engine mount and only lasted 1 month before it cracked.
Sorry to tell you this.
(in reply to jlguru)
       Post #: 9
RE: Spad 3 D - with what I have ?? - Quick response pls. - 2/10/2004 5:33:20 AM
novabill
Status: offline
I'm really hard on my spads.
They are lucky to last a month
< Message edited by novabill -- 2/10/2004 12:35:08 AM >
(in reply to ben flyn)
       Post #: 10
RE: Spad 3 D - with what I have ?? - Quick response pls. - 2/10/2004 10:37:28 PM
Zafer
Status: offline
Hi again,
My spa3d is % 90 finished, Here is another photo,
As the whole forum suggested, I have started to look for coroplast in Switzerland and neighboring Germany and France. If I find coroplast I will definitively change the wing , stab and elevator.
I think It will take some time before I go out and try the spa3d since here in switzerland we are having snow and storms every other day.
Thanks and regards.
Zafer
Click for fullsize
       Post #: 11
RE: Spad 3 D - with what I have ?? - Quick response pls. - 2/10/2004 11:39:50 PM
Zafer
Status: offline
You will notice that I have already changed the landing gear. I used an old one from a crashed trainer. That will save me from buying new tires. Since I couldn't find 5/32 music wire I have used aluminum pipe ( 6 mm ) on wing ( at CG and before ailerons) I think they are lighter. I am afraid I have to use stronger wire on elevator control because the one I have used is flexing too much.
If it flies well I will post Flight photos as well.
Thanks and regards.
Zafer
(in reply to Zafer)
       Post #: 12
RE: Spad 3 D - with what I have ?? - Quick response pls. - 2/11/2004 8:08:13 PM
Zafer
Status: offline
Hi guys,
I have finished it at last.
I have covered it with self sticking material. It made a bit heavy. But I have to have something for the orientation, I guess.
Here is another photo.
Regards. Zafer
Click for fullsize
(in reply to Zafer)
       Post #: 13
RE: Spad 3 D - with what I have ?? - Quick response pls. - 2/14/2004 2:07:33 PM
Zafer
Status: offline
Hi,
One more photo
Regards.
Zafer
Click for fullsize
(in reply to Zafer)
