RCRAINMAN
Joined: 2/22/2004 From: Huntsville, AL, USA Status: offline
quote:
ORIGINAL: LancelowDowell If it was just fuel, the cloth would have been just fine. It's kinda neat, but soak a rag in alcohol and burn it. It will burn itself out in a minute or two, and you'll notice the rag is now wet. Since there's quite a bit of water in alcohol, after the alcohol burns off it will leave the rag wet and unburnt. Since airplane fuel is almost all alcohol (the nitro in glow fuel is less explosive/flammible then alcohol) the same thing will happen. No! Sure the alcohol will burn off, but there is a good amount of oil in glow fuel. Pour a quart of oil on a rag and light it on fire and plan on cooking dinner on it Oil burns for a long time (Hannakuh) and will be ignitied by the alcohol already burning! If you want to test this, take a glass beaker of glow fuel (50mL) and set it on fire... once all of the nitro has burned, the oil is now undergoing a sustaned burn and will continue to burn until no oil remains. Sorry, but I was an Engineering student at the University of Alabama and loved to play with fire. And I did do the glow fuel burn test just to see what happens. Extinguish burning glow fuel ASAP! Good job w/ the quick response to that fire.
