Motor Applications
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> 3D Electric Flying! >> Motor Applications
Page: [1]
Login
Motor Applications - 2/7/2004 9:16:31 PM
mongoosejes
Status: offline
When do I use a direct motor applications verses a gearbox applications? What are the advantages of either set-up?
       Post #: 1
RE: Motor Applications - 2/9/2004 9:04:29 PM
scottm
Status: offline
Gearboxes let a small motor turn a big prop at low rpm. That is better for slow fliers and thick winged fun-flyers. Direct drive is better for higher speeds with more streamlined aircraft.
_____________________________
I spend most of my money on beer, women, and R/C. The rest I just waste.
(in reply to mongoosejes)
       Post #: 2
RE: Motor Applications - 2/10/2004 11:43:20 PM
mongoosejes
Status: offline
So would a gearbox be better for hovering?
(in reply to scottm)
       Post #: 3
RE: Motor Applications - 2/11/2004 12:13:19 AM
scottm
Status: offline
Yes, definitely.
       Post #: 4
RE: Motor Applications - 2/11/2004 12:54:15 AM
mongoosejes
Status: offline
So which motor would be best for a 3DX that weighs 10 oz.? I'm trying to stay with brushed motors.
       Post #: 5
RE: Motor Applications - 2/11/2004 1:16:27 AM
scottm
Status: offline
I am using a GWS 350c on my Live wire (1 lb) with good results. They are cheap and work well enough. You might try a 300c with a low gear ratio, like this:
http://www.aeromicro.com/Catalog/gws_eps-300c__bs__803626.htm
       Post #: 6
RE: Motor Applications - 2/11/2004 1:22:11 AM
mongoosejes
Status: offline
What battery are you using?
       Post #: 7
RE: Motor Applications - 2/11/2004 1:32:30 AM
scottm
Status: offline
A 2100 2S Li-poly. I have a thread going in this same section, check here for the full story:
http://www.rcuniverse.com/forum/Live_Wire_almost_finished%2C_need_help/m_1469611/tm.htm
       Post #: 8
RE: Motor Applications - 2/11/2004 1:49:57 AM
mongoosejes
Status: offline
Thats a nice plane you got there.
The same thing happen to me with a 300-c-D motor, I put a Li-Poly 3sp 1200 mAh it performed great, but after 10 minutes or so It smelt like I roasted it. It was my first time using frying a motor!
I'm going to be heading out to the hobby shop this weekend to get the GWS 350-D motor.
I'll tell you how it goes when I get it.
THANK YOU VERY MUCH!
       Post #: 9
RE: Motor Applications - 2/11/2004 1:53:33 AM
mongoosejes
Status: offline
Do you know if you have to buy a gearbox for a hacker motor?
       Post #: 10
RE: Motor Applications - 2/11/2004 3:49:03 AM
Dr Kiwi
Status: offline
You CAN buy a Hacker for direct drive, but for most applications you'll be better off with the geared versions [the 4.4:1 planetary is the standard box for the smaller Hackers (B20 etc)]. You can also fit them into a variety of aftermarket boxes too.
Cheers, Phil
       Post #: 11
RE: Motor Applications - 2/12/2004 1:00:20 AM
mongoosejes
Status: offline
So I could buy Hacker motor with a gear box.
And which one would you recommend for a 10 oz. airplane with a Li-Poly 3sp 1200 mAh.
I'm looking to do 3D maneuvers.
(in reply to Dr Kiwi)
       Post #: 12
RE: Motor Applications - 2/12/2004 1:53:58 AM
Xlogic
Status: offline
On my 3DX I use the Himax 2025-4200 with a GWS CNC Gearbox 6:1 kit from Bishop Power products http://www.b-p-p.com/products.htm
and a APC 11 X 4.7 prop. Its a lot of bang for the buck and will hover with 5 ticks of throttle on a 3 cell Kokam 1500.
Mike
http://www.ncrcf.org
       Post #: 13
RE: Motor Applications - 2/12/2004 1:55:17 AM
Xlogic
Status: offline
Sorry about the double post
Mike
< Message edited by Xlogic -- 2/11/2004 8:57:35 PM >
(in reply to Xlogic)
       Post #: 14
RE: Motor Applications - 2/12/2004 2:48:31 PM
ravensnest
Status: offline
For a Hacker the 20-15L seems to be the selection with the hacker you can save some moneys going with the Himax and using the GWS gear box. Himax 2015-5400 motor (2015-4100 was not available)
Castle Creations Phoenix 25 ESC
Kokam 1500 mAh 3s1p battery
GWS 12 x 6 Prop
GWS 350 "D" gearbox
Motor mount rings for Himax/GWS Gearbox
Good luck
Eddy
       Post #: 15
